Morbidelli / SCM Tria 7500 (6000/4000) postprocesor do AlphaCam
josue
Re: Morbidelli / SCM Tria 7500 (6000/4000) postprocesor do AlphaCam
Witam, próbowałem tego, co zaproponowałeś, ale nie udało się. Wysłałem ci e-mail z plikami wygenerowanymi przez oprogramowanie. Doceniam twoje wsparcie Pozdrawiam
RokJene
Making a Rifle Stock
With This great POSTPROCESSOR and Alphacam, i made a Rifle stock last year.
Thanks one more time to: Zbigniew Borowski , for this postprocessor.
My Friend has made his own design. It is a hunting rifle. We made a rotating center and the rifle then spins manual around this center. Then can you lock in 90°. Maybe someone will have some ideas how to start something. I use Morbidelli author 510 and the largest program that he can read is about 2000 lines. The whole stock had 36000 lines. But this is not problem. You always do just sections. Here are some pictures of working a Stock:
Maybe this solution with rotating center is not the best. Because when the stock was thiner, also was not so strong. Than i had problems in the middle. Then i had to make additional support to fix it in the middle. If i would do it one more time, i wouldnt make this "rotating center" but i would rather use like mikrojoints (minimal 20-30mm) and positioning holes where this stock could be fixed directly on a solid surface, and in the end this "mikrojoints" would be cut off manualy.
Rodolfo
Existe alguna nueva actualización del postprocesador? Estoy buscando algo similar en alphacam para un Biesse con controlador rt480 cni.
muhammad_nur.hossen
I need help : Morbidelli 503 Tria 7500
juanmancu
Hello everyone.
First of all, many thanks to Zbigniew Borowski for all the files and information, a few days ago I bought an old Morbidelli author 504 and all the information has been of great help.
But I have a problem: I have alphacam 2023 and TriaPost7500 Postprocessor for Alphacam v1.05.msi installed but when I try to generate the code I get the error: "Error 94 occurred at runtime: invalid use of Null".
I read that in version 1.4 that had been fixed that problem, so I tried installing that version just in case, but the same error appears.
How can I solve that error?
I have windows 11 64 bit.
Thank you!
Juan
Thank you!
Juan
boro76
- Posty w temacie: 44
TriaPost7500 Postprocessor for Alphacam v1.06.msi >>>>>https://bit.ly/3IFL3z6
boro76
TriaPost7500 Postprocessor for Alphacamv1.06.2 >>>>>https://bit.ly/3WCBpFh
- usunięty błąd: w instalacji 1.06 pojawił się błąd, który powodował, że stan kontrolek nie był zapisywany po zamknięciu okna postprocesora.
- poprawiono dodatek TriaRS232, aby odnajdował standardowy folder zapisywania plików ustawiony w postprocesorze. (1.06 lub nowszy)
boro76
TriaPost7500 Postprocessor for Alphacam v1.07 >>>>https://bit.ly/4eTCLlI
- dodano obsługę głębokiego wiercenia z wycofaniem (cykle użytkownika , lokalnie/liniowo)
- dodano możliwość zmiany punktu zerowego materiału (lewy górny róg dla Morbidelli, lewy dolny róg dla SCM)
- dodano możliwość usunięcia wartości S (obroty wrzeciona) w linii G0 dla narzędzi montowanych na wrzecionach bez regulacji obrotów (obroty stałe) poprzez wprowadzenie wartości [TPD(1)] = 1 w danych narzędzia
[TPD(1)] = 0 > G0 X10.00 Y20.00 Z10.00 S18.000 V2 T11
[TPD(1)] = 1 > G0 X10.00 Y20.00 Z10.00 V2 T11
Rodolfo
Hola,tuve un problema con la compu y se borro todo. Alguien me podria brindar alphacam 2017 o 2024 si ya esta con crack
adasko12
Witam, troszkę z innej beczki przy kompilacji pliku .xxl z parametrami np " L ZMY = DY-5 " są one traktowane jako błąd i pomijane. Używałem CNV75NEW.exe CNV75.exe wyskakują błedy przy parametrach,
zostaje tylko to co zadeklarowane jako ruch, CNVRT.exe nic nie konwertuje.
Maszynka Morbidelli AUTHOR 510 TRIA 7500V, próbowałem konwertować winxiso.exe, maszyna w ogóle nie czyta pliku. Po zapisie w XILOGu też nie czyta, ma ktoś jakieś pomysły, wskazówki ? Może coś źle robię ?
