GCC jest kompilatorem w LPCXpresso...ElSor pisze:Ze wstepnie zebranych info to programowac mozna przez:
http://www.keil.com/arm/mdk.asp
http://ics.nxp.com/lpcxpresso/
chyba można te klocki jakoś poukładać
http://vedder.se/tag/lpc1768/
tylko potrzebny będzie jakiś programator/debuger...
[ Dodano: 2012-09-09, 23:52 ]
The LPC17xx include four 32-bit timer/counters. The timer/counter is designed to count
cycles of the system derived clock or an externally-supplied clock. It can optionally
generate interrupts, generate timed DMA requests, or perform other actions at specified
timer values, based on four match registers. Each timer/counter also includes two capture
inputs to trap the timer value when an input signal transitions, optionally generating an
interrupt.
ten LPC ma również 32bity w timerze
tutaj przykład dla timera
http://msys-mv.blogspot.com/2010/11/con ... er-of.html
