http://allegro.pl/karta-graficzna-gefor ... 08067.html
Tu masz kartę, która w porółnaniu do tej zaproponowanej do Ciebie jest bezgłośna
No i dwa monitory podłączysz.
Kod: Zaznacz cały
# counting the spindle encoder in software
loadrt encoder num_chan=1
# simulate the encoder
loadrt sim_encoder num_chan=1
loadrt limit2 count=1
addf limit2.0 servo-thread
# Beginning of threading related stuff
# spindle speed control
net spindle-speed-cmd motion.spindle-speed-out => limit2.0.in
net spindle-speed-limited limit2.0.out => sim-encoder.0.speed
# simulate spindle mass
setp limit2.0.maxv 500.0 # rpm/second
# spindle encoder
# connect encoder signals to encoder counter
net spindle-phase-A sim-encoder.0.phase-A => encoder.0.phase-A
net spindle-phase-B sim-encoder.0.phase-B => encoder.0.phase-B
net spindle-phase-Z sim-encoder.0.phase-Z => encoder.0.phase-Z
# assume 120 ppr = 480 counts/rev for the spindle
setp sim-encoder.0.ppr 120
# iocontrol output is in rpm, but sim-encoder speed is rps
setp sim-encoder.0.scale 60
# scale encoder output to read in revolutions
# (that way thread pitches can be straightforward,
# a 20 tpi thread would multiply the encoder output
# by 1/20, etc)
setp encoder.0.position-scale 480
# encoder reset control
# hook up motion controller's sync output
net spindle-index-enable motion.spindle-index-enable <=> encoder.0.index-enable
# report our revolution count to the motion controller
net spindle-pos encoder.0.position => motion.spindle-revs
# for spindle velocity estimate
loadrt lowpass count=1
loadrt scale count=1
net spindle-rps-raw encoder.0.velocity lowpass.0.in
net spindle-rps-filtered lowpass.0.out scale.0.in motion.spindle-speed-in
net spindle-rpm-filtered scale.0.out
setp scale.0.gain 60
setp lowpass.0.gain .07
addf lowpass.0 servo-thread
addf scale.0 servo-thread
# for at-speed detection
loadrt near
addf near.0 servo-thread
setp near.0.scale 1.1
setp near.0.difference 10
net spindle-speed-cmd => near.0.in1
net spindle-rpm-filtered => near.0.in2
net spindle-at-speed near.0.out motion.spindle-at-speed
net spindle-fwd <= motion.spindle-forward
addf encoder.capture-position servo-thread
addf sim-encoder.update-speed servo-thread
addf sim-encoder.make-pulses base-thread
addf encoder.update-counters base-thread
