No ale czy aby na pewno? Co sadzicie o tym pomyśle ? Przykłady poniżej...
1. zetka skok 150mm - 660zl ...
https://pl.aliexpress.com/item/Linear-A ... 2e0eieKMss
2.zetka skok 200mm - 1100zl ...
https://pl.aliexpress. com/item/cnc-Electric-slider-1605-Ball-screw-linear-slider-steel-frame-heavy-load-z-axis-stroke-100mm/32664187109.html?spm=a2g0s.8937460.0.0.38f52e0eG0BVSL
3.Duże Obciążenie Osi 1500...
https://pl.aliexpress.com/item/Du-e-Obc ... Pv9DCG&s=p
