Fusion 360 problem z postprocesorem do LinuxCNC
RobiszToŹle
Re: Fusion 360 problem z postprocesorem do LinuxCNC
Posiada ktoś postprocesor do linuxcnc na tokarkę?
Segitarius
Cześć kochani. Podbijam temat. Czy posiadacie postprocesor do Fusiona dla Linux CNC na 3 oraz 4 osie?
Jesli na frezarke to ten u mnie działa również na 4 osie.
Tylko ma usunięte G28 !!!
Kod: Zaznacz cały
Copyright (C) 2012-2014 by Autodesk, Inc.
All rights reserved.
HAAS post processor configuration.
$Revision: 40489 $
$Date: 2015-12-18 09:40:28 +0100 (fr, 18 dec 2015) $
FORKID {241E0993-8BE0-463b-8888-47968B9D7F9F}
description = "LinuxCNC - frezarka";
vendor = "Kamar";
vendorUrl = "N/A";
legal = "Copyright (C) 2012-2014 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 24000;
extension = "ngc";
programNameIsInteger = true;
setCodePage("ascii");
capabilities = CAPABILITY_MILLING;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.01, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(355);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
allowSpiralMoves = true;
highFeedrate = (unit == IN) ? 500 : 5000;
// user-defined properties
properties = {
writeMachine: true, // write machine
writeTools: true, // writes the tools
useG28: false, // disable to avoid G28 output
useM6: true, // disable to avoid M6 output - preload is also disabled when M6 is disabled
preloadTool: false, // preloads next tool on tool change if any
showSequenceNumbers: true, // show sequence numbers
sequenceNumberStart: 10, // first sequence number
sequenceNumberIncrement: 5, // increment for sequence numbers
sequenceNumberOnlyOnToolChange: false, // only output sequence numbers on tool change
optionalStop: true, // optional stop
separateWordsWithSpace: true, // specifies that the words should be separated with a white space
useRadius: true, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words.
useParametricFeed: false, // specifies that feed should be output using Q values
showNotes: false, // specifies that operation notes should be output
useG0: true, // allow G0 when moving along more than one axis
useSubroutines: false, // specifies that subroutines should be generated
useG187: false, // use G187 to set smoothing on the machine
homePositionCenter: false, // moves the part in X in center of the door at end of program (ONLY WORKS IF THE TABLE IS MOVING)
dwellInSeconds: true, // specifies the unit for dwelling: true:seconds and false:milliseconds.
var gFormat = createFormat({prefix:"G", decimals:1});
var mFormat = createFormat({prefix:"M", decimals:0});
var hFormat = createFormat({prefix:"H", decimals:0});
var dFormat = createFormat({prefix:"D", decimals:0});
var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var rFormat = xyzFormat; // radius
var abcFormat = createFormat({decimals:3, forceDecimal:true, scale:DEG});
var feedFormat = createFormat({decimals:(unit == MM ? 2 : 3), forceDecimal:true});
var pitchFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var toolFormat = createFormat({decimals:0});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-1000
var milliFormat = createFormat({decimals:0}); // milliseconds // range 1-9999
var taperFormat = createFormat({decimals:1, scale:DEG});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({prefix:"Z"}, xyzFormat);
var aOutput = createVariable({prefix:"A"}, abcFormat);
var bOutput = createVariable({prefix:"B"}, abcFormat);
var cOutput = createVariable({prefix:"C"}, abcFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var inverseTimeOutput = createVariable({prefix:"F", force:true}, feedFormat);
var pitchOutput = createVariable({prefix:"F", force:true}, pitchFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
var dOutput = createVariable({}, dFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I", force:true}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J", force:true}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K", force:true}, xyzFormat);
var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91
var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G93-94
var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-21
var gCycleModal = createModal({}, gFormat); // modal group 9 // G81, ...
var gRetractModal = createModal({force:true}, gFormat); // modal group 10 // G98-99
// fixed settings
var firstFeedParameter = 100; // the first variable to use with parametric feed
var useInverseTimeFeed = false; // enable to use inverse-time feed for multi axis
var forceResetWorkPlane = false; // enable to force reset of machine ABC on new orientation
var WARNING_WORK_OFFSET = 0;
// collected state
var sequenceNumber;
var currentWorkOffset;
var forceSpindleSpeed = false;
var activeMovements; // do not use by default
var currentFeedId;
var maximumCircularRadiiDifference = toPreciseUnit(0.005, MM);
var subprograms = [];
var maximumLineLength = 80; // the maximum number of charaters allowed in a line
Writes the specified block.
function writeBlock() {
if (properties.showSequenceNumbers && !properties.sequenceNumberOnlyOnToolChange) {
if (sequenceNumber > 99999) {
sequenceNumber = properties.sequenceNumberStart;
writeWords2("N" + sequenceNumber, arguments);
sequenceNumber += properties.sequenceNumberIncrement;
} else {
writeWords(arguments);
Writes the specified block - used for tool changes only.
function writeToolBlock() {
if (properties.showSequenceNumbers) {
} else {
Writes the specified optional block.
function writeOptionalBlock() {
var words = formatWords(arguments);
if (words) {
writeWords("/", "N" + sequenceNumber, words);
} else {
writeWords2("/", arguments);
function formatComment(text) {
return "(" + String(text).replace(/[\(\)]/g, "") + ")";
Output a comment.
function writeComment(text) {
writeln(formatComment(text.substr(0, maximumLineLength - 2)));
function onOpen() {
if (true) {
var aAxis = createAxis({coordinate:0, table:true, axis:[-1, 0, 0], cyclic:true, preference:1});
machineConfiguration = new MachineConfiguration(aAxis);
setMachineConfiguration(machineConfiguration);
optimizeMachineAngles2(1); // map tip mode
if (!machineConfiguration.isMachineCoordinate(0)) {
aOutput.disable();
if (!machineConfiguration.isMachineCoordinate(1)) {
bOutput.disable();
if (!machineConfiguration.isMachineCoordinate(2)) {
cOutput.disable();
if (highFeedrate <= 0) {
error(localize("You must set 'highFeedrate' because axes are not synchronized for rapid traversal."));
return;
if (!properties.separateWordsWithSpace) {
setWordSeparator("");
writeln("%");
if (programName) {
var programId;
try {
programId = getAsInt(programName);
} catch(e) {
error(localize("Program name must be a number."));
return;
if (!((programId >= 1) && (programId <= 99999))) {
error(localize("Program number is out of range."));
return;
// old machines only support 4 digits
var oFormat = createFormat({width:5, zeropad:true, decimals:0});
/* Artur 21.08.2017
writeln(
"O" + oFormat.format(programId) +
conditional(programComment, " " + formatComment(programComment.substr(0, maximumLineLength - 2 - ("O" + oFormat.format(programId)).length - 1)))
} else {
error(localize("Program name has not been specified."));
return;
// dump machine configuration
var vendor = machineConfiguration.getVendor();
var model = machineConfiguration.getModel();
var description = machineConfiguration.getDescription();
if (properties.writeMachine && (vendor || model || description)) {
writeComment(localize("Machine"));
if (vendor) {
writeComment(" " + localize("vendor") + ": " + vendor);
if (model) {
writeComment(" " + localize("model") + ": " + model);
if (description) {
writeComment(" " + localize("description") + ": " + description);
// dump tool information
if (properties.writeTools) {
var zRanges = {};
if (is3D()) {
var numberOfSections = getNumberOfSections();
for (var i = 0; i < numberOfSections; ++i) {
var section = getSection(i);
var zRange = section.getGlobalZRange();
var tool = section.getTool();
if (zRanges[tool.number]) {
zRanges[tool.number].expandToRange(zRange);
} else {
zRanges[tool.number] = zRange;
var tools = getToolTable();
if (tools.getNumberOfTools() > 0) {
for (var i = 0; i < tools.getNumberOfTools(); ++i) {
var tool = tools.getTool(i);
var comment = "T" + toolFormat.format(tool.number) + " " +
"D=" + xyzFormat.format(tool.diameter) + " " +
localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
comment += " - " + getToolTypeName(tool.type);
writeComment(comment);
if (false /*properties.useDynamicWorkOffset*/) {
var failed = false;
var dynamicWCSs = {};
for (var i = 0; i < getNumberOfSections(); ++i) {
var description = section.hasParameter("operation-comment") ? section.getParameter("operation-comment") : ("#" + (i + 1));
if (!section.hasDynamicWorkOffset()) {
error(subst(localize("Dynamic work offset has not been set for operation '%1'."), description));
failed = true;
var o = section.getDynamicWCSOrigin();
var p = section.getDynamicWCSPlane();
if (dynamicWCSs[section.getDynamicWorkOffset()]) {
if ((Vector.diff(o, dynamicWCSs[section.getDynamicWorkOffset()].origin).length > 1e-9) ||
(Matrix.diff(p, dynamicWCSs[section.getDynamicWorkOffset()].plane).n1 > 1e-9)) {
error(subst(localize("Dynamic WCS mismatch for operation '%1'."), description));
failed = true;
} else {
dynamicWCSs[section.getDynamicWorkOffset()] = {origin:o, plane:p};
if (failed) {
return;
if (false) {
// check for duplicate tool number
var sectioni = getSection(i);
var tooli = sectioni.getTool();
for (var j = i + 1; j < getNumberOfSections(); ++j) {
var sectionj = getSection(j);
var toolj = sectionj.getTool();
if (tooli.number == toolj.number) {
if (xyzFormat.areDifferent(tooli.diameter, toolj.diameter) ||
xyzFormat.areDifferent(tooli.cornerRadius, toolj.cornerRadius) ||
abcFormat.areDifferent(tooli.taperAngle, toolj.taperAngle) ||
(tooli.numberOfFlutes != toolj.numberOfFlutes)) {
error(
subst(
localize("Using the same tool number for different cutter geometry for operation '%1' and '%2'."),
sectioni.hasParameter("operation-comment") ? sectioni.getParameter("operation-comment") : ("#" + (i + 1)),
sectionj.hasParameter("operation-comment") ? sectionj.getParameter("operation-comment") : ("#" + (j + 1))
return;
// absolute coordinates and feed per min
//writeBlock(gAbsIncModal.format(90), gFormat.format(54), gFormat.format(64), gFormat.format(50), gPlaneModal.format(17), gFormat.format(40), gFormat.format(80), gFeedModeModal.format(94), gFormat.format(91.1), gFormat.format(49));
writeBlock(gAbsIncModal.format(90), gFormat.format(54), gFormat.format(64), gPlaneModal.format(17), gFormat.format(40), gFormat.format(80), gFeedModeModal.format(94), gFormat.format(91.1), gFormat.format(49));
switch (unit) {
case IN:
writeBlock(gUnitModal.format(20));
break;
case MM:
writeBlock(gUnitModal.format(21));
break;
function onComment(message) {
writeComment(message);
/** Force output of X, Y, and Z. */
function forceXYZ() {
xOutput.reset();
yOutput.reset();
zOutput.reset();
/** Force output of A, B, and C. */
function forceABC() {
aOutput.reset();
bOutput.reset();
cOutput.reset();
function forceFeed() {
currentFeedId = undefined;
feedOutput.reset();
/** Force output of X, Y, Z, A, B, C, and F on next output. */
function forceAny() {
forceXYZ();
forceABC();
forceFeed();
function writeG187() {
if (hasParameter("operation-strategy") && (getParameter("operation-strategy") == "drill")) {
writeBlock(gFormat.format(187)); // reset G187 setting to machine default
} else if (hasParameter("operation:tolerance")) {
var tolerance = Math.max(getParameter("operation:tolerance"), 0);
if (tolerance > 0) {
var stockToLeaveThreshold = toUnit(0.1, MM);
var stockToLeave = 0;
var verticalStockToLeave = 0;
if (hasParameter("operation:stockToLeave")) {
stockToLeave = xyzFormat.getResultingValue(getParameter("operation:stockToLeave"));
if (hasParameter("operation:verticalStockToLeave")) {
verticalStockToLeave = xyzFormat.getResultingValue(getParameter("operation:verticalStockToLeave"));
var workMode;
if ((stockToLeave > stockToLeaveThreshold) && (verticalStockToLeave > stockToLeaveThreshold)) {
workMode = 1; // roughing
} else {
if ((stockToLeave != 0) || (verticalStockToLeave != 0)) {
workMode = 2; // default
} else {
workMode = 3; // fine
writeBlock(gFormat.format(187), "P" + workMode, "E" + xyzFormat.format(tolerance)); // set tolerance mode
} else {
} else {
function FeedContext(id, description, feed) {
this.id = id;
this.description = description;
this.feed = feed;
function getFeed(f) {
if (useInverseTimeFeed) {
forceFeed();
if (activeMovements) {
var feedContext = activeMovements[movement];
if (feedContext != undefined) {
if (!feedFormat.areDifferent(feedContext.feed, f)) {
if (feedContext.id == currentFeedId) {
return ""; // nothing has changed
forceFeed();
currentFeedId = feedContext.id;
return "F#" + (firstFeedParameter + feedContext.id);
currentFeedId = undefined; // force Q feed next time
return feedOutput.format(f); // use feed value
function initializeActiveFeeds() {
activeMovements = new Array();
var movements = currentSection.getMovements();
var id = 0;
var activeFeeds = new Array();
if (hasParameter("operation:tool_feedCutting")) {
if (movements & ((1 << MOVEMENT_CUTTING) | (1 << MOVEMENT_LINK_TRANSITION) | (1 << MOVEMENT_EXTENDED))) {
var feedContext = new FeedContext(id, localize("Cutting"), getParameter("operation:tool_feedCutting"));
activeFeeds.push(feedContext);
activeMovements[MOVEMENT_CUTTING] = feedContext;
activeMovements[MOVEMENT_LINK_TRANSITION] = feedContext;
activeMovements[MOVEMENT_EXTENDED] = feedContext;
++id;
if (movements & (1 << MOVEMENT_PREDRILL)) {
feedContext = new FeedContext(id, localize("Predrilling"), getParameter("operation:tool_feedCutting"));
activeMovements[MOVEMENT_PREDRILL] = feedContext;
++id;
if (hasParameter("operation:finishFeedrate")) {
if (movements & (1 << MOVEMENT_FINISH_CUTTING)) {
var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:finishFeedrate"));
activeMovements[MOVEMENT_FINISH_CUTTING] = feedContext;
++id;
} else if (hasParameter("operation:tool_feedCutting")) {
var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:tool_feedCutting"));
++id;
if (hasParameter("operation:tool_feedEntry")) {
if (movements & (1 << MOVEMENT_LEAD_IN)) {
var feedContext = new FeedContext(id, localize("Entry"), getParameter("operation:tool_feedEntry"));
activeMovements[MOVEMENT_LEAD_IN] = feedContext;
++id;
if (hasParameter("operation:tool_feedExit")) {
if (movements & (1 << MOVEMENT_LEAD_OUT)) {
var feedContext = new FeedContext(id, localize("Exit"), getParameter("operation:tool_feedExit"));
activeMovements[MOVEMENT_LEAD_OUT] = feedContext;
++id;
if (hasParameter("operation:noEngagementFeedrate")) {
if (movements & (1 << MOVEMENT_LINK_DIRECT)) {
var feedContext = new FeedContext(id, localize("Direct"), getParameter("operation:noEngagementFeedrate"));
activeMovements[MOVEMENT_LINK_DIRECT] = feedContext;
++id;
} else if (hasParameter("operation:tool_feedCutting") &&
hasParameter("operation:tool_feedEntry") &&
var feedContext = new FeedContext(id, localize("Direct"), Math.max(getParameter("operation:tool_feedCutting"), getParameter("operation:tool_feedEntry"), getParameter("operation:tool_feedExit")));
++id;
if (hasParameter("operation:reducedFeedrate")) {
if (movements & (1 << MOVEMENT_REDUCED)) {
var feedContext = new FeedContext(id, localize("Reduced"), getParameter("operation:reducedFeedrate"));
activeMovements[MOVEMENT_REDUCED] = feedContext;
++id;
if (hasParameter("operation:tool_feedRamp")) {
if (movements & ((1 << MOVEMENT_RAMP) | (1 << MOVEMENT_RAMP_HELIX) | (1 << MOVEMENT_RAMP_PROFILE) | (1 << MOVEMENT_RAMP_ZIG_ZAG))) {
var feedContext = new FeedContext(id, localize("Ramping"), getParameter("operation:tool_feedRamp"));
activeMovements[MOVEMENT_RAMP] = feedContext;
activeMovements[MOVEMENT_RAMP_HELIX] = feedContext;
activeMovements[MOVEMENT_RAMP_PROFILE] = feedContext;
activeMovements[MOVEMENT_RAMP_ZIG_ZAG] = feedContext;
++id;
if (hasParameter("operation:tool_feedPlunge")) {
if (movements & (1 << MOVEMENT_PLUNGE)) {
var feedContext = new FeedContext(id, localize("Plunge"), getParameter("operation:tool_feedPlunge"));
activeMovements[MOVEMENT_PLUNGE] = feedContext;
++id;
if (true) { // high feed
if (movements & (1 << MOVEMENT_HIGH_FEED)) {
var feedContext = new FeedContext(id, localize("High Feed"), this.highFeedrate);
activeMovements[MOVEMENT_HIGH_FEED] = feedContext;
++id;
for (var i = 0; i < activeFeeds.length; ++i) {
var feedContext = activeFeeds[i];
writeBlock("#" + (firstFeedParameter + feedContext.id) + "=" + feedFormat.format(feedContext.feed), formatComment(feedContext.description));
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
function setWorkPlane(abc) {
if (!machineConfiguration.isMultiAxisConfiguration()) {
return; // ignore
if (!((currentWorkPlaneABC == undefined) ||
abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z))) {
return; // no change
//onCommand(COMMAND_UNLOCK_MULTI_AXIS);
writeBlock(
gMotionModal.format(0),
conditional(machineConfiguration.isMachineCoordinate(0), "A" + abcFormat.format(abc.x)),
conditional(machineConfiguration.isMachineCoordinate(1), "B" + abcFormat.format(abc.y)),
conditional(machineConfiguration.isMachineCoordinate(2), "C" + abcFormat.format(abc.z))
//onCommand(COMMAND_LOCK_MULTI_AXIS);
currentWorkPlaneABC = abc;
var closestABC = false; // choose closest machine angles
var currentMachineABC;
function getWorkPlaneMachineABC(workPlane) {
var W = workPlane; // map to global frame
var abc = machineConfiguration.getABC(W);
if (closestABC) {
if (currentMachineABC) {
abc = machineConfiguration.remapToABC(abc, currentMachineABC);
} else {
abc = machineConfiguration.getPreferredABC(abc);
} else {
try {
abc = machineConfiguration.remapABC(abc);
currentMachineABC = abc;
} catch (e) {
error(
localize("Machine angles not supported") + ":"
+ conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x))
+ conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y))
+ conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z))
var direction = machineConfiguration.getDirection(abc);
if (!isSameDirection(direction, W.forward)) {
error(localize("Orientation not supported."));
if (!machineConfiguration.isABCSupported(abc)) {
error(
localize("Work plane is not supported") + ":"
var tcp = false;
if (tcp) {
setRotation(W); // TCP mode
} else {
var O = machineConfiguration.getOrientation(abc);
var R = machineConfiguration.getRemainingOrientation(abc, W);
setRotation(R);
return abc;
function onSection() {
var insertToolCall = isFirstSection() ||
currentSection.getForceToolChange && currentSection.getForceToolChange() ||
(tool.number != getPreviousSection().getTool().number);
var retracted = false; // specifies that the tool has been retracted to the safe plane
var newWorkOffset = isFirstSection() ||
(getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
var newWorkPlane = isFirstSection() ||
!isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis());
if (insertToolCall || newWorkOffset || newWorkPlane) {
// stop spindle before retract during tool change
if (insertToolCall && !isFirstSection()) {
onCommand(COMMAND_STOP_SPINDLE);
// retract to safe plane
retracted = true;
if (properties.useG28) {
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(0));
} else {
//writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), "Z" + xyzFormat.format(0)); - Artur 21.02.2020
writeBlock(gAbsIncModal.format(90));
zOutput.reset();
if (forceResetWorkPlane && newWorkPlane) {
forceWorkPlane();
setWorkPlane(new Vector(0, 0, 0)); // reset working plane
writeln("");
if (hasParameter("operation-comment")) {
var comment = getParameter("operation-comment");
if (comment) {
if (insertToolCall) {
forceWorkPlane();
// onCommand(COMMAND_STOP_SPINDLE);
// onCommand(COMMAND_COOLANT_OFF);
if (!isFirstSection() && properties.optionalStop) {
onCommand(COMMAND_OPTIONAL_STOP);
if (tool.number > 256) {
warning(localize("Tool number exceeds maximum value."));
var lengthOffset = tool.lengthOffset;
if (lengthOffset > 256) {
error(localize("Length offset out of range."));
return;
//writeBlock(mFormat.format(998));
if (properties.useM6) {
writeBlock("T" + toolFormat.format(tool.number),
gFormat.format(43),
hFormat.format(lengthOffset),
mFormat.format(6));
} else {
//writeBlock("T" + toolFormat.format(tool.number), gFormat.format(43), hFormat.format(lengthOffset));
writeBlock(gFormat.format(43));
if (tool.comment) {
writeComment(tool.comment);
var showToolZMin = false;
if (showToolZMin) {
if (is3D()) {
var zRange = currentSection.getGlobalZRange();
var number = tool.number;
for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) {
if (section.getTool().number != number) {
break;
zRange.expandToRange(section.getGlobalZRange());
writeComment(localize("ZMIN") + "=" + zRange.getMinimum());
if (properties.preloadTool && properties.useM6) {
var nextTool = getNextTool(tool.number);
if (nextTool) {
writeBlock("T" + toolFormat.format(nextTool.number));
} else {
// preload first tool
var section = getSection(0);
var firstToolNumber = section.getTool().number;
if (tool.number != firstToolNumber) {
writeBlock("T" + toolFormat.format(firstToolNumber));
isFirstSection() ||
(rpmFormat.areDifferent(tool.spindleRPM, sOutput.getCurrent())) ||
(tool.clockwise != getPreviousSection().getTool().clockwise)) {
if (tool.spindleRPM < 1) {
error(localize("Spindle speed out of range."));
return;
if (tool.spindleRPM > 99999) {
warning(localize("Spindle speed exceeds maximum value."));
writeBlock(
sOutput.format(tool.spindleRPM), mFormat.format(tool.clockwise ? 3 : 4)
// wcs
var workOffset = currentSection.workOffset;
if (workOffset == 0) {
warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET);
workOffset = 1;
if (workOffset > 0) {
if (workOffset > 6) {
var p = workOffset; // 1->... // G59 P1 is the same as G54 and so on
if (p > 254) {
error(localize("Work offset out of range."));
} else {
if (workOffset != currentWorkOffset) {
writeBlock(gFormat.format(59), "P" + p); // G59 P
currentWorkOffset = workOffset;
} else {
writeBlock(gFormat.format(53 + workOffset)); // G54->G59
forceXYZ();
if (machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
// set working plane after datum shift
if (currentSection.isMultiAxis()) {
forceWorkPlane();
cancelTransformation();
var abc = currentSection.getInitialToolAxisABC();
writeBlock(
} else {
var abc = getWorkPlaneMachineABC(currentSection.workPlane);
setWorkPlane(abc);
} else { // pure 3D
var remaining = currentSection.workPlane;
if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
error(localize("Tool orientation is not supported."));
return;
setRotation(remaining);
// set coolant after we have positioned at Z
setCoolant(tool.coolant);
forceAny();
/* if (properties.useG187) {
writeG187();
//writeBlock(gFeedModeModal.format(currentSection.isMultiAxis() ? 93 : 94));
var initialPosition = getFramePosition(currentSection.getInitialPosition());
if (!retracted) {
if (getCurrentPosition().z < initialPosition.z) {
writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
if (insertToolCall || retracted) {
if (lengthOffset > 200) {
return;
writeBlock(gPlaneModal.format(17));
if (!machineConfiguration.isHeadConfiguration()) {
writeBlock(
gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
writeBlock(
gFormat.format(43),
zOutput.format(initialPosition.z),
} else {
writeBlock(
gFormat.format(43),
yOutput.format(initialPosition.y),
} else {
var x = xOutput.format(initialPosition.x);
var y = yOutput.format(initialPosition.y);
if (!properties.useG0 && x && y) {
// axes are not synchronized
writeBlock(gAbsIncModal.format(90), gMotionModal.format(1), x, y, getFeed(highFeedrate));
} else {
writeBlock(gAbsIncModal.format(90), gMotionModal.format(0), x, y);
if (properties.preloadTool) {
if (nextTool) {
} else {
if (properties.useSubroutines) {
var subprogram = getAsInt(programName) + 1 + getCurrentSectionId();
// call subprogram
var comment = "";
var block = formatWords(mFormat.format(98), "P" + oFormat.format(subprogram));
writeBlock(
block,
conditional(comment, formatComment(comment.substr(0, maximumLineLength - 2 - block.length - 1)))
redirectToBuffer();
writeln("O" + oFormat.format(subprogram));
function onDwell(seconds) {
if (seconds > 99999.999) {
warning(localize("Dwelling time is out of range."));
seconds = clamp(0.001, seconds, 99999.999);
writeBlock(gFeedModeModal.format(94), gFormat.format(4), "P" + milliFormat.format(seconds * 1000));
function onSpindleSpeed(spindleSpeed) {
writeBlock(sOutput.format(spindleSpeed));
function onCycle() {
function getCommonCycle(x, y, z, r) {
forceXYZ(); // force xyz on first drill hole of any cycle
return [xOutput.format(x), yOutput.format(y),
zOutput.format(z),
"R" + xyzFormat.format(r)];
function onCyclePoint(x, y, z) {
var forceCycle = false;
switch (cycleType) {
case "tapping-with-chip-breaking":
case "left-tapping-with-chip-breaking":
case "right-tapping-with-chip-breaking":
forceCycle = true;
if (!isFirstCyclePoint()) {
writeBlock(gCycleModal.format(80));
if (forceCycle || isFirstCyclePoint()) {
repositionToCycleClearance(cycle, x, y, z);
// return to initial Z which is clearance plane and set absolute mode
var F = cycle.feedrate;
var P = (cycle.dwell == 0) ? 0 : clamp(1, cycle.dwell * 1000, 99999999); // in milliseconds
case "drilling":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(81),
getCommonCycle(x, y, z, cycle.retract),
feedOutput.format(F)
break;
case "counter-boring":
if (P > 0) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(82),
"P" + secFormat.format(P),
} else {
writeBlock(
break;
case "chip-breaking":
// cycle.accumulatedDepth is ignored
if (P > 0) {
expandCyclePoint(x, y, z);
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(73),
"Q" + xyzFormat.format(cycle.incrementalDepth),
break;
case "deep-drilling":
if (P > 0) {
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(83),
// conditional(P > 0, "P" + secFormat.format(P)),
break;
case "tapping":
if (tool.type == TOOL_TAP_LEFT_HAND) {
} else {
if (!F) {
F = tool.getTappingFeedrate();
writeBlock(mFormat.format(29), sOutput.format(tool.spindleRPM));
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(84),
break;
case "left-tapping":
break;
case "right-tapping":
if (!F) {
writeBlock(
break;
case "fine-boring":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(76),
"Q" + xyzFormat.format(cycle.shift),
break;
case "back-boring":
var dx = (gPlaneModal.getCurrent() == 19) ? cycle.backBoreDistance : 0;
var dy = (gPlaneModal.getCurrent() == 18) ? cycle.backBoreDistance : 0;
var dz = (gPlaneModal.getCurrent() == 17) ? cycle.backBoreDistance : 0;
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(87),
getCommonCycle(x - dx, y - dy, z - dz, cycle.bottom),
"I" + xyzFormat.format(cycle.shift),
"J" + xyzFormat.format(0),
break;
case "reaming":
if (P > 0) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(89),
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(85),
break;
case "stop-boring":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(86),
break;
case "manual-boring":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(88),
break;
case "boring":
if (P > 0) {
writeBlock(
} else {
writeBlock(
break;
default:
} else {
if (cycleExpanded) {
} else {
var _x = xOutput.format(x);
var _y = yOutput.format(y);
var _z = zOutput.format(z);
if (!_x && !_y && !_z) {
switch (gPlaneModal.getCurrent()) {
case 17: // XY
xOutput.reset(); // at least one axis is required
break;
case 18: // ZX
zOutput.reset(); // at least one axis is required
break;
case 19: // YZ
yOutput.reset(); // at least one axis is required
break;
writeBlock(_x, _y, _z);
function onCycleEnd() {
if (!cycleExpanded) {
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
pendingRadiusCompensation = radiusCompensation;
function onRapid(_x, _y, _z) {
var x = xOutput.format(_x);
var y = yOutput.format(_y);
var z = zOutput.format(_z);
if (x || y || z) {
if (pendingRadiusCompensation >= 0) {
error(localize("Radius compensation mode cannot be changed at rapid traversal."));
return;
if (!properties.useG0 && (((x ? 1 : 0) + (y ? 1 : 0) + (z ? 1 : 0)) > 1)) {
writeBlock(gMotionModal.format(1), x, y, z, getFeed(highFeedrate));
} else {
writeBlock(gMotionModal.format(0), x, y, z);
forceFeed();
function onLinear(_x, _y, _z, feed) {
// ensure that we end at desired position when compensation is turned off
xOutput.reset();
yOutput.reset();
var f = getFeed(feed);
if (x || y || z) {
var d = tool.diameterOffset;
if (d > 200) {
warning(localize("The diameter offset exceeds the maximum value."));
switch (radiusCompensation) {
case RADIUS_COMPENSATION_LEFT:
dOutput.reset();
writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, dOutput.format(d), f);
break;
case RADIUS_COMPENSATION_RIGHT:
dOutput.reset();
writeBlock(gMotionModal.format(1), gFormat.format(42), x, y, z, dOutput.format(d), f);
break;
default:
writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f);
} else {
writeBlock(gMotionModal.format(1), x, y, z, f);
} else if (f) {
if (getNextRecord().isMotion()) { // try not to output feed without motion
forceFeed(); // force feed on next line
} else {
writeBlock(gMotionModal.format(1), f);
function onRapid5D(_x, _y, _z, _a, _b, _c) {
if (!currentSection.isOptimizedForMachine()) {
error(localize("This post configuration has not been customized for 5-axis simultaneous toolpath."));
return;
return;
var a = aOutput.format(_a);
var b = bOutput.format(_b);
var c = cOutput.format(_c);
if (!properties.useG0) {
writeBlock(gMotionModal.format(1), x, y, z, a, b, c, getFeed(highFeedrate));
} else {
writeBlock(gMotionModal.format(0), x, y, z, a, b, c);
forceFeed();
/** Returns the inverse time for the given feed. */
function getInverseTime(length, feed) {
if (feed <= 0) {
error(localize("Invalid feed."));
return 0;
var inverseTime = feed/length; // length is the tip distance
if (inverseTime > 45000) { // TAG: limit given by CNC control
inverseTime = 45000;
return inverseTime; // unit in 1/min
var maximumLength = spatial(1, MM); // user-defined
var maximumSweep = toRad(5); // user-defined
var maximumSweepPerMin = toRad(2000); // user-defined
function onLinear5D(_x, _y, _z, _a, _b, _c, feed) {
return;
error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
return;
var start = getCurrentPosition();
var end = new Vector(_x, _y, _z);
var startABC = new Vector(
aOutput.isEnabled() ? aOutput.getCurrent() : 0,
bOutput.isEnabled() ? bOutput.getCurrent() : 0,
cOutput.isEnabled() ? cOutput.getCurrent() : 0
var endABC = new Vector(_a, _b, _c);
// TCP positions
var _start = machineConfiguration.getOrientation(startABC).multiply(start);
var _end = machineConfiguration.getOrientation(endABC).multiply(end);
var length = Vector.diff(_end, _start).length;
// TAG: increase feed for small sweeps and decrease feed for big sweeps
var sweep = 0;
if (aOutput.isEnabled()) {
sweep = Math.max(sweep, Math.abs(_a - startABC.x));
if (bOutput.isEnabled()) {
sweep = Math.max(sweep, Math.abs(_b - startABC.y));
if (cOutput.isEnabled()) {
sweep = Math.max(sweep, Math.abs(_c - startABC.z));
var sweepTimeLimit = sweep/maximumSweepPerMin; // min - lower limit // TAG: if we have 2 rotary axes then we might want to limit them independently
var numberOfSegments = Math.max(Math.ceil(length/maximumLength), 1); // TAG: for non-TCP we need tolerance for sweep
// writeln("DEBUG! length=" + xyzFormat.format(length) + " sweep=" + abcFormat.format(sweep) + " #segments=" + numberOfSegments + " linear feed=" + feedFormat.format(feed));
for (var i = 1; i <= numberOfSegments; ++i) {
var u = i * 1.0/numberOfSegments;
var p = Vector.lerp(_start, _end, u); // TCP position
var abc = Vector.lerp(startABC, endABC, u);
var a = aOutput.format(abc.x);
var b = bOutput.format(abc.y);
var c = cOutput.format(abc.z);
var q = machineConfiguration.getOrientation(abc).getTransposed().multiply(p); // mapped position
var x = xOutput.format(q.x);
var y = yOutput.format(q.y);
var z = zOutput.format(q.z);
var radius = Math.sqrt(p.y * p.y + p.z * p.z); // rotation around X-axis // TAG: for side milling we need to add flute length or stepdown if defined
// TAG: slow down feed for big radii - increase feed for small radii
var inverseTime = getInverseTime(length, feed) * numberOfSegments;
if (1/inverseTime < (sweepTimeLimit/numberOfSegments)) { // too fast
inverseTime = 1/(sweepTimeLimit/numberOfSegments);
var f = inverseTimeOutput.format(inverseTime);
if (x || y || z || a || b || c) {
writeBlock(gFeedModeModal.format(93), gMotionModal.format(1), x, y, z, a, b, c, f);
} else { // without inverse time feed
writeBlock(gMotionModal.format(1), x, y, z, a, b, c, f);
} else if (f) {
} else {
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
if (isSpiral()) {
var startRadius = getCircularStartRadius();
var endRadius = getCircularRadius();
var dr = Math.abs(endRadius - startRadius);
if (dr > maximumCircularRadiiDifference) { // maximum limit
linearize(tolerance); // or alternatively use other G-codes for spiral motion
return;
error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
return;
if (isFullCircle()) {
if (properties.useRadius || isHelical()) { // radius mode does not support full arcs
return;
switch (getCircularPlane()) {
case PLANE_XY:
writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
default:
} else if (!properties.useRadius) {
case PLANE_XY:
writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
default:
} else { // use radius mode
var r = getCircularRadius();
if (toDeg(getCircularSweep()) > (180 + 1e-9)) {
r = -r; // allow up to <360 deg arcs
case PLANE_XY:
writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
break;
default:
var currentCoolantMode = COOLANT_OFF;
function setCoolant(coolant) {
if (coolant == currentCoolantMode) {
return; // coolant is already active
var m = undefined;
if (coolant == COOLANT_OFF) {
if (currentCoolantMode == COOLANT_THROUGH_TOOL) {
m = 89;
} else if (currentCoolantMode == COOLANT_AIR) {
m = 84;
} else if (currentCoolantMode == COOLANT_AIR_THROUGH_TOOL) {
m = 74;
} else {
m = 9;
writeBlock(mFormat.format(m));
return;
if (currentCoolantMode != COOLANT_OFF) {
setCoolant(COOLANT_OFF);
switch (coolant) {
case COOLANT_FLOOD:
m = 8;
break;
case COOLANT_THROUGH_TOOL:
m = 88;
break;
case COOLANT_AIR:
m = 83;
break;
case COOLANT_AIR_THROUGH_TOOL:
m = 73;
break;
default:
warning(localize("Coolant not supported."));
if (currentCoolantMode == COOLANT_OFF) {
return;
coolant = COOLANT_OFF;
m = 9;
currentCoolantMode = coolant;
var mapCommand = {
COMMAND_STOP:0,
COMMAND_OPTIONAL_STOP:1,
COMMAND_END:2,
COMMAND_SPINDLE_CLOCKWISE:3,
COMMAND_SPINDLE_COUNTERCLOCKWISE:4,
COMMAND_STOP_SPINDLE:5,
COMMAND_ORIENTATE_SPINDLE:19,
COMMAND_LOAD_TOOL:6,
COMMAND_COOLANT_ON:8,
COMMAND_COOLANT_OFF:9
function onCommand(command) {
switch (command) {
case COMMAND_STOP:
writeBlock(mFormat.format(0));
forceSpindleSpeed = true;
return;
case COMMAND_COOLANT_ON:
setCoolant(COOLANT_FLOOD);
return;
case COMMAND_COOLANT_OFF:
return;
case COMMAND_START_SPINDLE:
onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
return;
case COMMAND_LOCK_MULTI_AXIS:
//writeBlock(mFormat.format(10)); // lock A-axis motion
//writeBlock(mFormat.format(12)); // lock B-axis motion
return;
case COMMAND_UNLOCK_MULTI_AXIS:
//writeBlock(mFormat.format(11)); // unlock A-axis motion
//writeBlock(mFormat.format(13)); // unlock B-axis motion
return;
case COMMAND_BREAK_CONTROL:
return;
case COMMAND_TOOL_MEASURE:
return;
var stringId = getCommandStringId(command);
var mcode = mapCommand[stringId];
if (mcode != undefined) {
writeBlock(mFormat.format(mcode));
} else {
onUnsupportedCommand(command);
function onSectionEnd() {
if (((getCurrentSectionId() + 1) >= getNumberOfSections()) ||
(tool.number != getNextSection().getTool().number)) {
onCommand(COMMAND_BREAK_CONTROL);
forceAny();
function onClose() {
writeln("");
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(0)); // retract
zOutput.reset();
if (properties.useG28 && !machineConfiguration.hasHomePositionX() && !machineConfiguration.hasHomePositionY()) {
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0)); // return to home
} else {
var homeX;
if (machineConfiguration.hasHomePositionX()) {
homeX = "X" + xyzFormat.format(machineConfiguration.getHomePositionX());
var homeY;
if (machineConfiguration.hasHomePositionY()) {
homeY = "Y" + xyzFormat.format(machineConfiguration.getHomePositionY());
//writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), homeX, homeY);
writeBlock(gAbsIncModal.format(90), gMotionModal.format(0), homeX, homeY);
onImpliedCommand(COMMAND_END);
onImpliedCommand(COMMAND_STOP_SPINDLE);
writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
function onTerminate() {
var outputPath = getOutputPath();
var programFilename = FileSystem.getFilename(outputPath);
var programSize = FileSystem.getFileSize(outputPath);
var postPath = findFile("setup-sheet-excel-2007.cps");
var intermdiatePath = FileSystem.replaceExtension(outputPath, "cnc");
var a = "--property unit 0"; // use 0 for inch and 1 for mm
if (programName) {
a += " --property programName \"'" + programName + "'\"";
if (programComment) {
a += " --property programComment \"'" + programComment + "'\"";
a += " --property programFilename \"'" + programFilename + "'\"";
a += " --property programSize \"" + programSize + "\"";
a += " --noeditor --log temp.log \"" + postPath + "\" \"" + intermdiatePath + "\" \"" + outputPath + ".xlsx\"";
execute(getPostProcessorPath(), a, false, "");
Segitarius
BinskyDrew
Tak, istnieje postprocesor dla LinuxCNC, który jest przeznaczony do tokarek.Segitarius pisze: ↑12 lis 2020, 22:40Cześć kochani. Podbijam temat. Czy posiadacie postprocesor do Fusiona dla Linux CNC na 3 oraz 4 osie?
blossom word game
