tak oczywiście to jest ten kod, daje cały bo nie jest strasznie długi
N0010 (Filename: Drip 11,6.tap)
N0020 (Post processor: Mach3.scpost)
N0030 (Date:2003-08-31 Time:04:44:43)
N0040 G21 (Units: Metric)
N0050 G40 G90 G91.1
N0060 F1
N0070 (Part: Drip 11,6)
N0080 (Operation: Kieszeń spirala, layer 1, T1: Mill/router, 2 mm średnica, 7,6 mm Deep)
N0090 S1000 (Mill/router, 2 mm średnica)
N0100 T1 M06
N0110 G43 H1
N0120 G00 Z5.0000
N0130 S1000 M03
N0140 X10.0890 Y9.6100
N0150 Z0.5000
N0160 G01 Z-1.000 F100.0
N0170 G02 X9.9032 Y10.3881 Z-1.0000 I-0.0890 J0.3900 F600.0
N0180 G01 X10.0839 Y10.3678 Z-1.000
N0190 X10.1637 Y10.3399
N0200 X10.2352 Y10.2949
N0210 X10.2949 Y10.2352
N0220 X10.3917 Y10.0812
N0230 G02 X10.0890 Y9.6100 Z-1.0000 I-0.3917 J-0.0812
N0240 G01 X10.3783 Y8.3426 Z-1.000
N0250 G02 X9.8980 Y11.6969 Z-1.0000 I-0.3783 J1.6574
N0260 G01 X10.3750 Y11.6432 Z-1.000
N0270 X10.7313 Y11.5185
N0280 X11.0509 Y11.3177
N0290 X11.3177 Y11.0509
N0300 X11.5731 Y10.6444
N0310 G02 X10.3783 Y8.3426 Z-1.0000 I-1.5731 J-0.6444
N0320 G01 X10.6676 Y7.0752 Z-1.000
N0330 G02 X9.9479 Y12.9995 Z-1.0000 I-0.6676 J2.9248
N0340 G01 X10.6662 Y12.9186 Z-1.000
N0350 X11.2989 Y12.6972
N0360 X11.8665 Y12.3405
N0370 X12.3405 Y11.8665
N0380 X12.7251 Y11.2545
N0390 G02 X10.6676 Y7.0752 Z-1.0000 I-2.7251 J-1.2545
N0400 G00 Z5.0000
N0410 X10.0890 Y9.6100
N0420 Z-0.5000
N0430 G01 Z-2.000 F100.0
N0440 G02 X9.9032 Y10.3881 Z-2.0000 I-0.0890 J0.3900 F600.0
N0450 G01 X10.0839 Y10.3678 Z-2.000
N0460 X10.1637 Y10.3399
N0470 X10.2352 Y10.2949
N0480 X10.2949 Y10.2352
N0490 X10.3917 Y10.0812
N0500 G02 X10.0890 Y9.6100 Z-2.0000 I-0.3917 J-0.0812
N0510 G01 X10.3783 Y8.3426 Z-2.000
N0520 G02 X9.8980 Y11.6969 Z-2.0000 I-0.3783 J1.6574
N0530 G01 X10.3750 Y11.6432 Z-2.000
N0540 X10.7313 Y11.5185
N0550 X11.0509 Y11.3177
N0560 X11.3177 Y11.0509
N0570 X11.5731 Y10.6444
N0580 G02 X10.3783 Y8.3426 Z-2.0000 I-1.5731 J-0.6444
N0590 G01 X10.6676 Y7.0752 Z-2.000
N0600 G02 X9.9479 Y12.9995 Z-2.0000 I-0.6676 J2.9248
N0610 G01 X10.6662 Y12.9186 Z-2.000
N0620 X11.2989 Y12.6972
N0630 X11.8665 Y12.3405
N0640 X12.3405 Y11.8665
N0650 X12.7251 Y11.2545
N0660 G02 X10.6676 Y7.0752 Z-2.0000 I-2.7251 J-1.2545
N0670 G00 Z5.0000
N0680 X10.0890 Y9.6100
N0690 Z-1.5000
N0700 G01 Z-3.000 F100.0
N0710 G02 X9.9032 Y10.3881 Z-3.0000 I-0.0890 J0.3900 F600.0
N0720 G01 X10.0839 Y10.3678 Z-3.000
N0730 X10.1637 Y10.3399
N0740 X10.2352 Y10.2949
N0750 X10.2949 Y10.2352
N0760 X10.3917 Y10.0812
N0770 G02 X10.0890 Y9.6100 Z-3.0000 I-0.3917 J-0.0812
N0780 G01 X10.3783 Y8.3426 Z-3.000
N0790 G02 X9.8980 Y11.6969 Z-3.0000 I-0.3783 J1.6574
N0800 G01 X10.3750 Y11.6432 Z-3.000
N0810 X10.7313 Y11.5185
N0820 X11.0509 Y11.3177
N0830 X11.3177 Y11.0509
N0840 X11.5731 Y10.6444
N0850 G02 X10.3783 Y8.3426 Z-3.0000 I-1.5731 J-0.6444
N0860 G01 X10.6676 Y7.0752 Z-3.000
N0870 G02 X9.9479 Y12.9995 Z-3.0000 I-0.6676 J2.9248
N0880 G01 X10.6662 Y12.9186 Z-3.000
N0890 X11.2989 Y12.6972
N0900 X11.8665 Y12.3405
N0910 X12.3405 Y11.8665
N0920 X12.7251 Y11.2545
N0930 G02 X10.6676 Y7.0752 Z-3.0000 I-2.7251 J-1.2545
N0940 G00 Z5.0000
N0950 X10.0890 Y9.6100
N0960 Z-2.5000
N0970 G01 Z-4.000 F100.0
N0980 G02 X9.9032 Y10.3881 Z-4.0000 I-0.0890 J0.3900 F600.0
N0990 G01 X10.0839 Y10.3678 Z-4.000
N1000 X10.1637 Y10.3399
N1010 X10.2352 Y10.2949
N1020 X10.2949 Y10.2352
N1030 X10.3917 Y10.0812
N1040 G02 X10.0890 Y9.6100 Z-4.0000 I-0.3917 J-0.0812
N1050 G01 X10.3783 Y8.3426 Z-4.000
N1060 G02 X9.8980 Y11.6969 Z-4.0000 I-0.3783 J1.6574
N1070 G01 X10.3750 Y11.6432 Z-4.000
N1080 X10.7313 Y11.5185
N1090 X11.0509 Y11.3177
N1100 X11.3177 Y11.0509
N1110 X11.5731 Y10.6444
N1120 G02 X10.3783 Y8.3426 Z-4.0000 I-1.5731 J-0.6444
N1130 G01 X10.6676 Y7.0752 Z-4.000
N1140 G02 X9.9479 Y12.9995 Z-4.0000 I-0.6676 J2.9248
N1150 G01 X10.6662 Y12.9186 Z-4.000
N1160 X11.2989 Y12.6972
N1170 X11.8665 Y12.3405
N1180 X12.3405 Y11.8665
N1190 X12.7251 Y11.2545
N1200 G02 X10.6676 Y7.0752 Z-4.0000 I-2.7251 J-1.2545
N1210 G00 Z5.0000
N1220 X10.0890 Y9.6100
N1230 Z-3.5000
N1240 G01 Z-5.000 F100.0
N1250 G02 X9.9032 Y10.3881 Z-5.0000 I-0.0890 J0.3900 F600.0
N1260 G01 X10.0839 Y10.3678 Z-5.000
N1270 X10.1637 Y10.3399
N1280 X10.2352 Y10.2949
N1290 X10.2949 Y10.2352
N1300 X10.3917 Y10.0812
N1310 G02 X10.0890 Y9.6100 Z-5.0000 I-0.3917 J-0.0812
N1320 G01 X10.3783 Y8.3426 Z-5.000
N1330 G02 X9.8980 Y11.6969 Z-5.0000 I-0.3783 J1.6574
N1340 G01 X10.3750 Y11.6432 Z-5.000
N1350 X10.7313 Y11.5185
N1360 X11.0509 Y11.3177
N1370 X11.3177 Y11.0509
N1380 X11.5731 Y10.6444
N1390 G02 X10.3783 Y8.3426 Z-5.0000 I-1.5731 J-0.6444
N1400 G01 X10.6676 Y7.0752 Z-5.000
N1410 G02 X9.9479 Y12.9995 Z-5.0000 I-0.6676 J2.9248
N1420 G01 X10.6662 Y12.9186 Z-5.000
N1430 X11.2989 Y12.6972
N1440 X11.8665 Y12.3405
N1450 X12.3405 Y11.8665
N1460 X12.7251 Y11.2545
N1470 G02 X10.6676 Y7.0752 Z-5.0000 I-2.7251 J-1.2545
N1480 G00 Z5.0000
N1490 X10.0890 Y9.6100
N1500 Z-4.5000
N1510 G01 Z-6.000 F100.0
N1520 G02 X9.9032 Y10.3881 Z-6.0000 I-0.0890 J0.3900 F600.0
N1530 G01 X10.0839 Y10.3678 Z-6.000
N1540 X10.1637 Y10.3399
N1550 X10.2352 Y10.2949
N1560 X10.2949 Y10.2352
N1570 X10.3917 Y10.0812
N1580 G02 X10.0890 Y9.6100 Z-6.0000 I-0.3917 J-0.0812
N1590 G01 X10.3783 Y8.3426 Z-6.000
N1600 G02 X9.8980 Y11.6969 Z-6.0000 I-0.3783 J1.6574
N1610 G01 X10.3750 Y11.6432 Z-6.000
N1620 X10.7313 Y11.5185
N1630 X11.0509 Y11.3177
N1640 X11.3177 Y11.0509
N1650 X11.5731 Y10.6444
N1660 G02 X10.3783 Y8.3426 Z-6.0000 I-1.5731 J-0.6444
N1670 G01 X10.6676 Y7.0752 Z-6.000
N1680 G02 X9.9479 Y12.9995 Z-6.0000 I-0.6676 J2.9248
N1690 G01 X10.6662 Y12.9186 Z-6.000
N1700 X11.2989 Y12.6972
N1710 X11.8665 Y12.3405
N1720 X12.3405 Y11.8665
N1730 X12.7251 Y11.2545
N1740 G02 X10.6676 Y7.0752 Z-6.0000 I-2.7251 J-1.2545
N1750 G00 Z5.0000
N1760 X10.0890 Y9.6100
N1770 Z-5.5000
N1780 G01 Z-7.000 F100.0
N1790 G02 X9.9032 Y10.3881 Z-7.0000 I-0.0890 J0.3900 F600.0
N1800 G01 X10.0839 Y10.3678 Z-7.000
N1810 X10.1637 Y10.3399
N1820 X10.2352 Y10.2949
N1830 X10.2949 Y10.2352
N1840 X10.3917 Y10.0812
N1850 G02 X10.0890 Y9.6100 Z-7.0000 I-0.3917 J-0.0812
N1860 G01 X10.3783 Y8.3426 Z-7.000
N1870 G02 X9.8980 Y11.6969 Z-7.0000 I-0.3783 J1.6574
N1880 G01 X10.3750 Y11.6432 Z-7.000
N1890 X10.7313 Y11.5185
N1900 X11.0509 Y11.3177
N1910 X11.3177 Y11.0509
N1920 X11.5731 Y10.6444
N1930 G02 X10.3783 Y8.3426 Z-7.0000 I-1.5731 J-0.6444
N1940 G01 X10.6676 Y7.0752 Z-7.000
N1950 G02 X9.9479 Y12.9995 Z-7.0000 I-0.6676 J2.9248
N1960 G01 X10.6662 Y12.9186 Z-7.000
N1970 X11.2989 Y12.6972
N1980 X11.8665 Y12.3405
N1990 X12.3405 Y11.8665
N2000 X12.7251 Y11.2545
N2010 G02 X10.6676 Y7.0752 Z-7.0000 I-2.7251 J-1.2545
N2020 G00 Z5.0000
N2030 X10.0890 Y9.6100
N2040 Z-6.5000
N2050 G01 Z-7.600 F100.0
N2060 G02 X9.9032 Y10.3881 Z-7.6000 I-0.0890 J0.3900 F600.0
N2070 G01 X10.0839 Y10.3678 Z-7.600
N2080 X10.1637 Y10.3399
N2090 X10.2352 Y10.2949
N2100 X10.2949 Y10.2352
N2110 X10.3917 Y10.0812
N2120 G02 X10.0890 Y9.6100 Z-7.6000 I-0.3917 J-0.0812
N2130 G01 X10.3783 Y8.3426 Z-7.600
N2140 G02 X9.8980 Y11.6969 Z-7.6000 I-0.3783 J1.6574
N2150 G01 X10.3750 Y11.6432 Z-7.600
N2160 X10.7313 Y11.5185
N2170 X11.0509 Y11.3177
N2180 X11.3177 Y11.0509
N2190 X11.5731 Y10.6444
N2200 G02 X10.3783 Y8.3426 Z-7.6000 I-1.5731 J-0.6444
N2210 G01 X10.6676 Y7.0752 Z-7.600
N2220 G02 X9.9479 Y12.9995 Z-7.6000 I-0.6676 J2.9248
N2230 G01 X10.6662 Y12.9186 Z-7.600
N2240 X11.2989 Y12.6972
N2250 X11.8665 Y12.3405
N2260 X12.3405 Y11.8665
N2270 X12.7251 Y11.2545
N2280 G02 X10.6676 Y7.0752 Z-7.6000 I-2.7251 J-1.2545
N2290 (Operation: Na zewnątrz, Obrys, T1: Mill/router, 2 mm średnica, 7,5 mm Deep)
N2300 G00 Z5.0000
N2310 X11.2495 Y3.3158
N2320 Z0.5000
N2330 G01 Z-1.000 F100.0
N2340 G03 X11.2495 Y3.3158 Z-1.0000 I-1.2495 J6.6842 F600.0
N2350 G01 Z-2.000 F100.0
N2360 G03 X11.2495 Y3.3158 Z-2.0000 I-1.2495 J6.6842 F600.0
N2370 G01 Z-3.000 F100.0
N2380 G03 X11.2495 Y3.3158 Z-3.0000 I-1.2495 J6.6842 F600.0
N2390 G01 Z-4.000 F100.0
N2400 G03 X11.2495 Y3.3158 Z-4.0000 I-1.2495 J6.6842 F600.0
N2410 G01 Z-5.000 F100.0
N2420 G03 X11.2495 Y3.3158 Z-5.0000 I-1.2495 J6.6842 F600.0
N2430 G01 Z-6.000 F100.0
N2440 G03 X11.2495 Y3.3158 Z-6.0000 I-1.2495 J6.6842 F600.0
N2450 G01 Z-7.000 F100.0
N2460 G03 X11.2495 Y3.3158 Z-7.0000 I-1.2495 J6.6842 F600.0
N2470 G01 Z-7.500 F100.0
N2480 G03 X11.2495 Y3.3158 Z-7.5000 I-1.2495 J6.6842 F600.0
N2490 G00 Z5.0000
N2500 M05
N2510 M05 M30
