postprocesor Mach dla SheetCam-a, Detekcja pływającą głowicą
- Posty w temacie: 10
To jest postprocesor Mach dla SheetCama-a.
Realizacja detekcji pływającą głowicą (palnikiem) z czujnikiem na probe, z makrem dla Mach-a- M300 (G31 z korektą czujnika G92 Z-?). Do pobrania w oddzielnym temacie.
Plik wkleić do C:\Program Files\SheetCam TNG\Posts
...ewentualnie- skopiować poniższe, edytować dowolny post w SheetCamie- zamienić tym, zapisać.
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("plasma THC300 post processor\n")
ctrl:AppendText("\n")
ctrl:AppendText("Modal G-codes and coordinates\n")
ctrl:AppendText("Comments enclosed with ( and )\n")
ctrl:AppendText("M03/M05 turn the torch on/off\n")
ctrl:AppendText("Incremental IJ\n")
ctrl:AppendText("The torch is referenced at cut start and every 500mm of movement thereafter\n")
ctrl:AppendText("Designed for use with Mach2 and Campbell Designs THC300\n")
ctrl:AppendText("Post variables:\n")
ctrl:AppendText("refdistance - set the distance between each reference\n")
end
-- revision 3/2/07
-- Removed final safety move. This is now done in SheetCam
-- revision 7/10/05
-- Added new arc handling
-- created 27/10/04
-- Based on plasma1.post
function OnInit()
post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
post.Text (" (Filename: ", fileName, ")\n")
post.Text (" (Post processor: ", postName, ")\n")
post.Text (" (Date: ", date, ")\n")
if(scale == metric) then
post.Text (" G21 (Units: Metric)\n") --metric mode
else
post.Text (" G20 (Units: Inches)\n") --inch mode
end
post.Text (" G53 G90 G40\n F1\n S500\n")
dist = 9999999
refdistance = 500 * scale
switchoffset = -0.08
bigarcs = 1 --stitch arc segments together
minArcSize = 0.05 --arcs smaller than this are converted to moves
end
function OnNewLine()
post.Text ("N")
post.Number (lineNumber, "0000")
lineNumber = lineNumber + 10
end
function OnFinish()
post.Text (" M05 M30\n")
end
function OnRapid()
if(math.hypot(endX-currentX , endY-currentY) < 0.001 and endZ < currentZ) then return end
dist = dist + math.hypot(endX-currentX , endY-currentY)
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, "0.0000")
post.ModalNumber (" Y", endY * scale, "0.0000")
post.ModalNumber (" Z", endZ * scale, "0.0000")
post.Eol()
end
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, "0.###")
post.Eol()
end
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
end
post.NonModalNumber (" X", endX * scale, "0.0000")
post.NonModalNumber (" Y", endY * scale, "0.0000")
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, "0.0000")
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, "0.0000")
post.ModalNumber (" F", feedRate * scale, "0.0###")
post.Eol()
end
function OnPenDown()
--[[ post.ModalText (" G00")
post.Eol()]]
if (preheat > 0) then
post.ModalNumber (" Z", cutHeight * scale, "0.0000")
post.Eol()
post.Text(" M801\n G04 P 0.5\n M802\n G04 P0.1\n M902")
post.Text ("\n G04 P")
post.Number (preheat,"0.###")
post.Eol()
end
post.ModalText (" M300\n G00")
post.ModalNumber (" Z", pierceHeight * scale, "0.0000")
post.Text ("\n M03\n")
if (pierceDelay > 0) then
post.Text (" G04 P")
post.Number (pierceDelay,"0.###")
post.Eol()
end
end
function OnPenUp()
post.Text (" M05\n")
end
function OnNewOperation()
post.Text (" (Process: ", operationName, ")\n")
if (plungeRate <= 0) then
post.Warning("WARNING: Plunge rate is zero")
end
if (feedRate <= 0) then
post.Warning("WARNING: Feed rate is zero")
end
end
function OnComment()
post.Text(" (",commentText,")\n")
end
function OnToolChange()
post.Text (" M06 T")
post.Number (tool, "0")
post.Text (" (", toolName, ")\n")
end
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
Dajcie znać czy działa u was poprawnie
end
-- revision 3/2/07
-- revision 7/10/05
-- created 27/10/04
function OnInit()
else
end
dist = 9999999
end
post.Text ("N")
end
function OnFinish()
end
function OnRapid()
post.Eol()
end
function OnMove()
post.Eol()
end
function OnArc()
else
end
post.Text (" I")
post.Text (" J")
post.Eol()
end
post.Eol()]]
post.Eol()
post.Eol()
end
post.Eol()
end
end
function OnPenUp()
end
end
end
end
end
end
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
- Załączniki
- steelbox.rar
- (1.42 KiB) Pobrany 505 razy
Nie wiem jakie masz THC? Musisz wziąć pod uwagę, że jak na końcu nie wyłączysz THC lub nie masz anty-nurkowania to przy pauzie palnik będzie miał więcej czasu żeby pójść w materiał, kolizję.
Poprawiony z pauzą na końcu.
end
-- revision 3/2/07
-- revision 7/10/05
-- created 27/10/04
function OnInit()
else
end
dist = 9999999
end
post.Text ("N")
end
function OnFinish()
end
function OnRapid()
post.Eol()
end
function OnMove()
post.Eol()
end
function OnArc()
else
end
post.Text (" I")
post.Text (" J")
post.Eol()
end
post.Eol()]]
post.Eol()
post.Eol()
end
post.Eol()
end
end
function OnPenUp()
if (endDelay > 0) then
post.Number (endDelay,"0.###")
post.Eol()
end
end
end
end
end
end
end
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
end
-- revision 3/2/07
-- revision 7/10/05
-- created 27/10/04
function OnInit()
else
end
dist = 9999999
end
post.Text ("N")
end
function OnFinish()
end
function OnRapid()
post.Eol()
end
function OnMove()
post.Eol()
end
function OnArc()
else
end
post.Text (" I")
post.Text (" J")
post.Eol()
end
post.Eol()]]
post.Eol()
post.Eol()
end
post.Eol()
end
end
function OnPenUp()
post.Eol()
end
end
end
end
end
end
end
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
