Kod: Zaznacz cały
[RS274NGC]
PARAMETER_FILE = sim-lathe.var
SUBROUTINE_PATH = ../../../nc_files/ngcgui_lib/lathe:../../../nc_files/ngcgui_lib/utilitysubs
USER_M_PATH = ../../../nc_files/ngcgui_lib/mfiles
To ja odpalałem zgodnie z poradnikiem czyli cud że mi odpalało tyleOczywiście zakładam, że wybierasz konfiguracje z podkatalogu sim - inne ci nie odpalą.
Kod: Zaznacz cały
[EMC]
VERSION = Ngcgui-lathe
MACHINE = ngcgui-lathe
[RS274NGC]
SUBROUTINE_PATH = /home/miki/emc2/nc_files/ngcgui_lib/lathe:/home/miki/emc2/nc_files/ngcgui_lib/testsuite2.5/utilitysubs
USER_M_PATH = /home/miki/emc2/nc_files/ngcgui_lib/mfiles
[DISPLAY]
PROGRAM_PREFIX = /home/miki/emc2/nc_files
# Note: TKPKG (one or more) specifies tcl/tk apps to embed in axis tab pages
TKPKG = Ngcgui 1.0
OPEN_FILE = auto.ngc
NGCGUI_FONT = Helvetica -12 normal
# for startup NGCGUI_PREAMBLE, NGCGUI_SUBFILE, NGCGUI_POSTAMBLE, TTT_PREAMBLE
# items, specifly:
# a) absolute filename (start with /)
# b) relative filename: search directories specified by
# [DISPLAY]PROGRAM_PREFIX and [RS274NGC]SUBROUTINE_PATH
NGCGUI_PREAMBLE = start.ngc
NGCGUI_SUBFILE = walec.ngc
NGCGUI_SUBFILE = stozek.ngc
NGCGUI_SUBFILE = polkula.ngc
NGCGUI_SUBFILE = roztaczanie.ngc
# specify "" for a custom tab page
NGCGUI_SUBFILE = ""
NGCGUI_OPTIONS = noiframe
DISPLAY = axis
LATHE = 1
EDITOR = gedit
CYCLE_TIME = 0.100
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
MAX_SPINDLE_OVERRIDE = 1.0
INTRO_TIME = 0
TOOL_EDITOR = tooledit
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.001
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 50000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = /usr/share/doc/emc2/examples/sample-configs/sim/core_sim.hal
HALFILE = /usr/share/doc/emc2/examples/sample-configs/sim/axis_manualtoolchange.hal
HALFILE = /usr/share/doc/emc2/examples/sample-configs/sim/simulated_home.hal
HALFILE = /usr/share/doc/emc2/examples/sample-configs/sim/lathe.hal
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 10.0
MAX_VELOCITY = 30.333334
DEFAULT_ACCELERATION = 2000.0
MAX_ACCELERATION = 5000.0
#X
[AXIS_0]
TYPE = LINEAR
HOME = 0.000
BACKLASH = 0.000
INPUT_SCALE = 4000
OUTPUT_SCALE = 1.000
MIN_LIMIT = -100.0
MAX_LIMIT = 5.0
FERROR = 0.050
MIN_FERROR = 0.010
HOME_OFFSET = 1.0
HOME_SEARCH_VEL = 5.0
HOME_LATCH_VEL = 1.0
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = NO
HOME_SEQUENCE = 0
HOME_IS_SHARED = 0
#Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
BACKLASH = 0.000
INPUT_SCALE = 4000
MIN_LIMIT =-200.0
MAX_LIMIT = 5.0
FERROR = 0.050
MIN_FERROR = 0.010
HOME_OFFSET = 1.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
HOME_IS_SHARED = 0
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = lathe.tbl
TOOL_CHANGE_POSITION = 50 0 50
TOOL_CHANGE_WITH_SPINDLE_ON = 1
Problem zapewne polega na tym, że w programie skonfigurowanym jako symulator nie można uruchomić konfiguracji dla rzeczywistych maszyn.blue_17 pisze:Sytuacja wygląda tak że program się uruchamia wybieram konfigurację pyta czy zapisać skrót na pulpicie daje tak i wyłącza się
po próbie odpalenia z pulpitu nic się nie dzieje,
po odpaleniu z terminala wyświetla żeby sprawdzić błędy wpisując dmesg
Kod: Zaznacz cały
[EMC]
[RS274NGC]
SUBROUTINE_PATH = /home/blue/emc2-dev/nc_files/ngcgui_lib/lathe:/home/blue/emc2-dev/nc_files/ngcgui_lib/utilitysubs
#../../../nc_files/ngcgui_lib/lathe:../../../nc_files/ngcgui_lib/utilitysubs
USER_M_PATH = /home/blue/emc2-dev/nc_files/ngcgui_lib/mfiles
#= ../../../nc_files/ngcgui_lib/mfiles
[DISPLAY]
PROGRAM_PREFIX = /home/blue/emc2-dev/nc_files
#../../../nc_files
TKPKG = Ngcgui 1.0
# items, specifly:
NGCGUI_PREAMBLE = lathe_std.ngc
NGCGUI_SUBFILE = id.ngc
NGCGUI_SUBFILE = od.ngc
NGCGUI_SUBFILE = taper-od.ngc
NGCGUI_SUBFILE = ""
DISPLAY = axis
LATHE = 1
EDITOR = gedit
CYCLE_TIME = 0.100
INTRO_TIME = 5
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.001
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 50000
[HAL]
HALFILE = /home/blue/emc2-dev/configs/sim/core_sim.hal
HALFILE = /home/blue/emc2-dev/configs/sim/axis_manualtoolchange.hal
HALFILE = /home/blue/emc2-dev/configs/sim/simulated_home.hal
HALFILE = /home/blue/emc2-dev/configs/sim/lathe.hal
[TRAJ]
AXES = 3
COORDINATES = X Z
LINEAR_UNITS = inch
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 1.0
MAX_VELOCITY = 3.333334
DEFAULT_ACCELERATION = 20.0
MAX_ACCELERATION = 20.0
[AXIS_0]
TYPE = LINEAR
HOME = 0.000
BACKLASH = 0.000
INPUT_SCALE = 4000
MIN_LIMIT = -10.0
MAX_LIMIT = 10.0
FERROR = 0.050
MIN_FERROR = 0.010
HOME_OFFSET = 1.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
HOME_IS_SHARED = 1
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
BACKLASH = 0.000
INPUT_SCALE = 4000
MIN_LIMIT = -10.0
MAX_LIMIT = 10.0
FERROR = 0.050
MIN_FERROR = 0.010
HOME_OFFSET = 1.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
HOME_IS_SHARED = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_CHANGE_POSITION = 1 0 1
Kod: Zaznacz cały
sudo apt-get remove nazwa_pakietu_1 nazwa pakietu_2
Nie ma czegoś takiego.blue_17 pisze:Jak teraz można usunąć zbędne pakiety potrzebne do kompilacji EMC ??
Kod: Zaznacz cały
sudo apt-get -s install nazwa_pakietu_1 nazwa pakietu_2
sudo apt-get -s remove nazwa_pakietu_1 nazwa pakietu_2
