Szukam MOSFETa
markcomp77
Posty w temacie: 11
Post napisał: markcomp77 » 24 kwie 2006, 22:17
IrekN pisze: H8S2148
trochę trudno znaleść jakieś informacje na temat tego ustrojtwa... google mało pokazują :(
o - znalazłem :) :
http://www.renesas.com/fmwk.jsp?cnt=h8s ... 40b_group/
duży procek - 100 nóżek...
ciekawe jaka cena?
i gdzie jest dostępny?
oraz
czy GCC na to jest?
jarekk
Posty w temacie: 12
#42
Post napisał: jarekk » 24 kwie 2006, 23:01
No to ja jeszcze dodam :-) ( dwa przetworniki D/A)
Description
The M3062GF8N of single-chip microcomputers are built using the high-performance silicon gate CMOS
process using a M16C/60 Series CPU core and are packaged in a 100-pin plastic molded QFP. These
single-chip microcomputers operate using sophisticated instructions featuring a high level of instruction
efficiency. With 1M bytes of address space, low voltage (2.7V to 3.6V), they are capable of executing
instructions at high speed. They also feature a built-in multiplier and DMAC, making them ideal for controlling
office, communications, industrial equipment, and other high-speed processing applications.
Features
• Memory capacity..................................ROM 64K bytes
RAM 8K bytes
• Shortest instruction execution time ......100ns (f(XIN)=10MHZ, VCC=2.7V to 3.6V)
• Supply voltage .....................................2.7V to 3.6V (f(XIN)=10MHZ, without software wait)
• Low power consumption ......................30.0mW (VCC = 3V, f(XIN)=10MHZ, without software wait)
• Interrupts .............................................. 25 internal and 8 external interrupt sources, 4 software
interrupt sources; 7 levels (including key input interrupt)
• Multifunction 16-bit timer ...................... 5 output timers + 6 input timers
• Serial I/O ..............................................5 channels
(3 for UART or clock synchronous, 2 for clock synchronous)
• DMAC ..................................................2 channels (trigger: 24 sources)
• A-D converter.......................................10 bits X 8 channels (Expandable up to 10 channels)
• D-A converter....................................... 8 bits X 2 channels
• CRC calculation circuit ......................... 1 circuit
• Watchdog timer.................................... 1 line
• Programmable I/O ...............................87 lines
• Input port ..............................................
_______
1 line (P85 shared with NMI pin)
• Memory expansion .............................. Available (to a maximum of 1M bytes)
• Chip select output ................................ 4 lines
• Clock generating circuit ....................... 2 built-in clock generation circuits
(built-in feedback resistor, and external ceramic or quartz oscillator)
Krzysiek
Post napisał: Krzysiek » 24 kwie 2006, 23:38
http://www.hobbycnc.hu/English.htm?Cach ... l=no-cache
może warto się przyjrzeć temu... jest na PIC'u
zawsze jest to coś sprawdzonego i udoskonalonego(poprawionego).
niestety 134Euro+przesyłka(za płytkę złożoną i zaprogramowanego PIC'a)
ale może coś da się podejrzeć...;)
Szopler
Post napisał: Szopler » 24 kwie 2006, 23:40
Ale to dla unipolarnych jest...
Krzysiek
Post napisał: Krzysiek » 24 kwie 2006, 23:45
o nie doczytałem..sorki -mój błąd :oops:
IrekN
#46
Post napisał: IrekN » 26 kwie 2006, 21:34
markcomp77 pisze: duży procek - 100 nóżek...
ciekawe jaka cena?
oraz
czy GCC na to jest?
Jest firma w Gliwicach będąca przedstawicielem, prowadzi wsparcie, szkolenia jak trzeba :)
Jest dostępne free całe środowisko z firmy KPIT o ile pamiętam (http://www.kpitgnutools.com/).
Ceny... hmm..., nienajnizsze byly, a jakie teraz sa nie mam pojecia. Płaciłem chyba 70pln za niego. Trzeba by sprawdzic.
Poza tym są inne prostsze kostki i znacznie, znacznie tansze - popatrz po serii Tiny.
Mnie zauroczył przeznaczeniem - typowa przemysłówka ;-)
__
Pzd, Irek.N.
__
Pzd, Irek.N.
Wróć do „Elektronika CNC”
