Ustawienia podczas startu maszyny
easy2002
Post napisał: easy2002 » 16 sty 2013, 20:37
Witam Kolegów
Parametr jest ustawiony na 3
MD 20150 GCODE_RESET_VALUES[14]=3
Moje sterowanie to model FM-NC
i takie informacje znalazłem w instrukcji
Description:
Definition of G codes which become active on runup and reset or at part program
end depending on MD 20110 RESET_MODE_MASK (up to software version 4) and
MD 20152: GCODE_RESET_MODE (from software version 5) and at part program start
depending on MD 20112 START_MODE_MASK.
The index of the G codes in the respective groups must be programmed as the
default value.
For a list of the G groups with the G functions they contain, please refer to
References:
/PG/, Programming Manual, Fundamentals
Title Group Default
setting on 840D/810D/ FM-NC
GCODE_RESET_VALUES[0] 1 2 (G01)
GCODE_RESET_VALUES[1] 2 0 (inactive)
GCODE_RESET_VALUES[2] 3 0 (inactive)
GCODE_RESET_VALUES[3] 4 1 (START FIFO)
GCODE_RESET_VALUES[4] 5 0 (inactive)
GCODE_RESET_VALUES[5] 6 1 (G17)
GCODE_RESET_VALUES[6] 7 1 (G40)
GCODE_RESET_VALUES[7] 8 1 (G500)
GCODE_RESET_VALUES[8] 9 0 (inactive)
GCODE_RESET_VALUES[9] 10 1 (G60)
GCODE_RESET_VALUES[10] 11 0 (inactive)
GCODE_RESET_VALUES[11] 12 1 (G601)
GCODE_RESET_VALUES[12] 13 2 (G71)
GCODE_RESET_VALUES[13] 14 1 (G90)
GCODE_RESET_VALUES[14] 15 2 (G94)
GCODE_RESET_VALUES[15] 16 1 (CFC)
GCODE_RESET_VALUES[16] 17 1 (NORM)
GCODE_RESET_VALUES[17] 18 1 (G450)
GCODE_RESET_VALUES[18] 19 1 (BNAT)
GCODE_RESET_VALUES[19] 20 1 (ENAT)
GCODE_RESET_VALUES[20] 21 1 (BRISK)
GCODE_RESET_VALUES[21] 22 1 (RTCPOF)
GCODE_RESET_VALUES[22] 23 1 (CDOF)
GCODE_RESET_VALUES[23] 24 1 (FFWOF)
GCODE_RESET_VALUES[24] 25 1 (ORIWKS)
GCODE_RESET_VALUES[25] 26 2 (RMI)
GCODE_RESET_VALUES[26] 27 1 (ORIC)
GCODE_RESET_VALUES[27] 28 1 (WALIMON)
GCODE_RESET_VALUES[28] 29 1 (DIAMOF)
GCODE_RESET_VALUES[29] 30 1 (COMPOF)
GCODE_RESET_VALUES[30] 31 1 (inactive)
GCODE_RESET_VALUES[31] 32 1 (inactive)
GCODE_RESET_VALUES[32] 33 1 (FTCOF)
GCODE_RESET_VALUES[33] 34 1 (OSOF)
GCODE_RESET_VALUES[34] 35 1 (SPOF)
GCODE_RESET_VALUES[35] 36 1 (PDLAYON)
GCODE_RESET_VALUES[36] 37 1 (FNOORM)
GCODE_RESET_VALUES[37] 38 1 SPF1)
GCODE_RESET_VALUES[38] 39 1 (CPRECOF)
GCODE_RESET_VALUES[39] 40 1 (CUTCONOF)
GCODE_RESET_VALUES[40] 41 1 (LFOF)
GCODE_RESET_VALUES[41] 42 1 (TCOABS)
GCODE_RESET_VALUES[42] 43 1 (G140)
GCODE_RESET_VALUES[43] 44 1 (G340)
GCODE_RESET_VALUES[44] 45 1 (SPATH)
GCODE_RESET_VALUES[45] 46 1 (LFTXT)
GCODE_RESET_VALUES[46] 47 1 (G290 SINUMERIK_MODE)
GCODE_RESET_VALUES[47] 48 3 (G462)
GCODE_RESET_VALUES[48] 49 1 (CP)
GCODE_RESET_VALUES[49] 50 1 (ORIEULER)
GCODE_RESET_VALUES[50] 51 1 (ORIVECT)
GCODE_RESET_VALUES[51] 52 1 (PAROTOF)
GCODE_RESET_VALUES[52] 53 1 (TOROTOF)
GCODE_RESET_VALUES[53] 54 1 (ORIROTA)
GCODE_RESET_VALUES[54] 55 1 (RTLION)
GCODE_RESET_VALUES[55] 56 1 (TOWSTD)
GCODE_RESET_VALUES[56] 57 1 (FENDNORM)
GCODE_RESET_VALUES[57] 58 1 (RELIEVEON)
GCODE_RESET_VALUES[58] 59 1 (DYNNORM)
GCODE_RESET_VALUES[59] 60 1 (WAPCS0)
GCODE_RESET_VALUES[60] 61 1 (ORISOF)
GCODE_RESET_VALUES[69] 70 1 (not defined)
20152 GCODE_RESET_MODE
Description:
This MD is only evaluated if bit 0 is set in $MC_RESET_MODE_MASK!
This MD used to determine for each entry in MD $MN_GCODE_RESET_VALUES (therefore
for each G group) whether, in the case of a reset/part program end, the
setting according to $MC_GCODE_RESET_VALUES is taken again ( MD = 0 ), or the
current setting is retained ( MD = 1 ).
Example:
Here the basic setting for the 6th G group (current level) is read out of
the machine data $MC_GCODE_RESET_VALUES at each reset / part program end:
$MC_GCODE_RESET_VALUES[5]=1 ;Reset value of the 6th G group is M17
$MC_GCODE_RESET_MODE[5]=0 ;Basic setting for 6th G group corresponds, after
;reset / part program end
;to $MC_GCODE_RESET_VALUES[5]
However, if the current setting for the 6th G group (current level) is to be
retained after reset / part program end, then the following setting results:
$MC_GCODE_RESET_MODE[5]=1 ;Current setting for 6th G group
;is retained
;even after reset / part program end
... z poważaniem ....pozdrawiam --- Doceń to że, poświęciłem Ci trochę czasu !!! wciśnij "pomógł" to nic nie kosztuje ;-) ---
JAG2525
#22
Post napisał: JAG2525 » 23 sty 2013, 20:19
witam easy2002 wpisz w programie G603 i nie bedzie szarpania
DRAGOO
#23
Post napisał: DRAGOO » 24 sty 2013, 18:18
Żeby po załączeniu i resetowaniu maszyny była funkcja G64 to trzeba tak zmienić
Dana maszynowa 20150
GCODE_RESET_VALUES[9] 10 2 (G64)
TEORIA I PRAKTYKA NIE ZAWSZE IDĄ W PARZE
easy2002
Post napisał: easy2002 » 27 sty 2013, 11:27
Witam Wszystkich Serdecznie
i na wstępnie muszę przeprosić za zamieszanie
chyba z pospiechu lub nie uwagi .. źle napisałem pierwszy post ...
Więc opisze jeszcze raz jaki dokładnie mam problem ...
W bliżej nie wyjaśnionych okolicznościach maszyna z funkcji G60 którą zawsze pamiętała po włączeniu oraz nie kasował po naciśnięciu "reset" - zmieniła sobie funkcję G60 na G64
Teraz po włączeniu zasilania mam funkcję G64 i jeśli wywołam z programu G60
to maszyna pracuje normalnie lecz po naciśnięciu przycisku " Reset"
wstawia automatycznie G64
parametry które podałem wyżej są aktualnie wpisane
Jeszcze raz przepraszam za zamieszanie
I proszę o pomoc
zależy mi na tym aby funkcja G60 była i po włączeniu maszyn i po naciśnięciu reset
z góry dziękuję za pomoc oraz dziękuję wszystkim którzy wypowiadali się wcześniej ..
DRAGOO
#25
Post napisał: DRAGOO » 27 sty 2013, 13:10
Witam spróbuj zmienic ta dane co napisałem wyżej wpisując od 1 do 3 po wpisaniu wcisnij reset .
