Need help with lathe TSB-20.
Eldar
Post napisał: Eldar » 06 lip 2015, 10:31
Hello guys! I need help with TSB-20 model polish lathe. I have no original chuck and I bought 125 mm. And now I need drawing of flange.
Sorry I dont speak Polish/
[ Dodano: 2015-07-06, 10:32 ]
What is parameters of spindle nut? There is metric thread/
[ Dodano: 2015-07-06, 10:51 ]
Spindle end have B22 trap and nut with thread. but i dont now sizes of thread/
[ Dodano: 2015-07-06, 10:54 ]
Potrzebuję pomocy w rysunku!!!
ASOR
Post napisał: ASOR » 06 lip 2015, 11:34
The thread is M46x2 (on the backpate, on the spindle there is a M46x15).
Hre you are the drawing of he spindle end from the technical manual:
It's not very good copy, so if you are not sure about some dimension just ask, I can try to figure it out from my paper copy or measure on the machine. Also please note, that the backplate centers on the big outer taper (8 degrees) and has a driving pin that fits into 13x3,5 slot at the end of the spindle. The pin diameter is 4mm.
Eldar
Post napisał: Eldar » 06 lip 2015, 11:56
Asor, Dziękuję bardzo. będę zamawiać flanca ot warsztat mechaniczny/
Ty masz scanirovane pasportu? może wybulić do depositfailu ale dać linku/
[ Dodano: 2015-07-06, 12:35 ]
[ Dodano: 2015-07-06, 12:38 ]
nie mogę dodat zdjecia
[ Dodano: 2015-07-06, 12:44 ]
[ Dodano: 2015-07-06, 12:45 ]
zdjecia
[ Dodano: 2015-07-06, 12:47 ]
[ Dodano: 2015-07-06, 12:51 ]
ak47
Post napisał: ak47 » 06 lip 2015, 13:00
IF you need manual for this machine just use this link.
http://chomikuj.pl/gemini_tiger81/Ksi*c ... 098064.pdf
Unfortunately you probably will never find manual for this machine in some other language than polish.
Eldar
Post napisał: Eldar » 06 lip 2015, 13:09
[ Dodano: 2015-07-06, 13:11 ]
Thank you, ak47. I will try to translate by Google.
[ Dodano: 2015-07-06, 13:45 ]
If someone have TSB-20 lathe, give me please photo of original backplate (side with thread) with measurements.
prutkyj
Znawca tematu (min. 80)
Post napisał: prutkyj » 08 lip 2015, 20:34
I don't have that kind of lathe but there is a lot of people knowing better russian language than english that might have tsb20. Try ask if you of course know rus. To help you i'll translate down bellow your last question to polish.
On the other hand you have already inner backplate screw measurements. You can try make it and match with your chucks. Here an english movie how to make it.
- Czy ktoś posiada wymiary oryginalnej tarczy zabierakowej do tsb20?
Eldar
Post napisał: Eldar » 31 paź 2015, 12:52
Guys! I still need answers/
rc36
Post napisał: rc36 » 31 paź 2015, 14:06
Post napisał: RomanJ4 » 31 paź 2015, 22:02
