Przystawka dłutująca/piłująca do małej frezarki(NT30)
Post napisał: RomanJ4 » 29 kwie 2025, 21:14
wraz z rysunkami wykonawczymi części
https://www.homemadetools.net/forum/slo ... ily-106757
File Type: pdf Albero_centrale.pdf (65.8 KB, 10 views) https://www.homemadetools.net/forum/att ... 1745855471
File Type: pdf Assieme_STOZZA_3.pdf (236.3 KB, 5 views) https://www.homemadetools.net/forum/att ... 1745855485
File Type: pdf Asta_spinta.pdf (91.0 KB, 4 views) https://www.homemadetools.net/forum/att ... 1745855493
File Type: pdf Banjo.pdf (79.7 KB, 3 views) https://www.homemadetools.net/forum/att ... 1745855500
File Type: pdf Braccio_banjo.pdf (69.1 KB, 4 views) https://www.homemadetools.net/forum/att ... 1745855506
File Type: pdf Camicia.pdf (71.6 KB, 5 views) https://www.homemadetools.net/forum/att ... 1745855513
File Type: pdf Cono_NT30_1.pdf (38.0 KB, 4 views) https://www.homemadetools.net/forum/att ... 1745855521
File Type: pdf Coperchio_frontale.pdf (83.2 KB, 7 views) https://www.homemadetools.net/forum/att ... 1745855536
File Type: pdf Coperchio_sup.pdf (94.4 KB, 4 views) https://www.homemadetools.net/forum/att ... 1745855536
File Type: pdf Corpo_superiore.pdf (130.1 KB, 3 views) https://www.homemadetools.net/forum/att ... 1745855545
File Type: pdf Lardone_3.pdf (49.6 KB, 3 views) https://www.homemadetools.net/forum/att ... 1745855555
File Type: pdf Manovella.pdf (95.4 KB, 4 views) https://www.homemadetools.net/forum/att ... 1745855562
File Type: pdf Nottolino_D10.pdf (37.8 KB, 4 views) https://www.homemadetools.net/forum/att ... 1745855570
File Type: pdf Perno_banjo.pdf (36.7 KB, 4 views) https://www.homemadetools.net/forum/att ... 1745855579
File Type: pdf Perno_rotazione_2.pdf (40.9 KB, 3 views) https://www.homemadetools.net/forum/att ... 1745855586
File Type: pdf Piolo_rimando.pdf (73.3 KB, 4 views) https://www.homemadetools.net/forum/att ... 1745855598
File Type: pdf Porta_lima.pdf (89.9 KB, 3 views) https://www.homemadetools.net/forum/att ... 1745855606
File Type: pdf Spessore_Ruota15T.pdf (74.0 KB, 4 views) https://www.homemadetools.net/forum/att ... 1745855625
File Type: pdf Supporto_asta.pdf (69.9 KB, 5 views) https://www.homemadetools.net/forum/att ... 1745855650
qqaz
Re: Przystawka dłutująca/piłująca do małej frezarki(NT30)
Post napisał: qqaz » 30 kwie 2025, 09:54
dobry materiał dydaktyczny do omówienia sensowności rozwiązań zastosowanych w warunkach amatorskiego podejścia do obróbki wiórowej. I zwykłego pomyślunku że jednak coś nie teges gdy miękkie z miękkim się łączy jako węzeł siłowy.
A ma warunki dla wykonania sensownego urządzenia.
Ale widać że to amerykański stomatolog klejący z zapałek trójmasztowy galeon do postawienia na półce. Ładne. Prawie.
Magnusgwyneth
Post napisał: Magnusgwyneth » 08 maja 2025, 12:40
qqaz pisze: ↑
30 kwie 2025, 09:54
A ma warunki dla wykonania sensownego urządzenia. Baseball Bros Game
Zgadzam się, że amatorskie podejście do obróbki wiórowej może prowadzić do nietrafionych rozwiązań, szczególnie gdy miękkie materiały są łączone w miejscach, które powinny być mocniejsze. Z drugiej strony, taka kreatywność i chęć eksperymentowania mogą prowadzić do interesujących wyników, mimo że nie zawsze są one idealne pod względem technicznym. Czasami warto spojrzeć na takie podejścia z przymrużeniem oka, zwłaszcza jeśli efekty są estetycznie zadowalające.
rc36
Post napisał: rc36 » 08 maja 2025, 22:55
Mam tu coś lepszego, przyrząd do nacinania rowków smarowych.
Wróć do „WARSZTAT”
