THC w linuxcnc
jarenio
Posty w temacie: 11
Post napisał: jarenio » 23 sie 2012, 15:47
a mi wypierniacza:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
plazma.hal:78: Pin 'thcup.z-fb-out' does not exist
4576
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
:neutral:
plik plazma.hal
Kod: Zaznacz cały
# Wygenerowane przez Stepconf o Wed Aug 24 20:04:16 2011
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD traj_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hal_parport cfg="0x378 out  "
setp parport.0.reset-time 1600
loadrt stepgen step_type=0,0,0
loadrt thcud
addf thcud servo-thread
addf parport.0.read base-thread
addf stepgen.make-pulses base-thread
addf parport.0.write base-thread
addf parport.0.reset base-thread
addf stepgen.capture-position servo-thread
addf motion-command-handler servo-thread
addf motion-controller servo-thread
addf stepgen.update-freq servo-thread
#net spindle-cmd <= motion.spindle-speed-out
#net spindle-on <= motion.spindle-on
net coolant-flood <= iocontrol.0.coolant-flood
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net coolant-flood => parport.0.pin-16-out
net xenable => parport.0.pin-17-out
net estop-ext <= parport.0.pin-10-in
#net home-z <= parport.0.pin-13-in
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 30000
setp stepgen.0.dirsetup 30000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
#net home-z => axis.2.home-sw-in
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 30000
setp stepgen.1.dirsetup 30000
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 30000
setp stepgen.2.dirsetup 30000
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd thcud.z-pos-in <= axis.2.motor-pos-cmd
net thc-pos-cmd thcud.z-pos-out => stepgen.2.position-cmd
net stepgen.2.position-fb axis.2.motor-pos-fb <= thcup.z-fb-out
#net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
#net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net estop-out <= iocontrol.0.user-enable-out
net estop-ext => iocontrol.0.emc-enable-in
loadusr -W hal_manualtoolchange
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net TorchProbe parport.0.pin-15-in => motion.probe-input
net TorchUp thcud.torch-up <= parport.0.pin-13-in
net TorchDown thcud.torch-down <= parport.0.pin-11-in
net ArcOK thcud.arc-ok <= parport.0.pin-12-in
net CurVel thcud.current-vel <= motion.current-vel
net spindle-on motion.spindle-on => parport.0.pin-01-out
net spindle-on thcud.torch-on
setp thcud.requested-vel 40
setp thcud.vel-tol 10
setp thcud.correction-vel 0.0001
Pozdrawiam; Jarek
ArturM
Post napisał: ArturM » 23 sie 2012, 17:09
jarenio pisze:a mi wypierniacza:
4576
No ładne. Na tyle ładne ze nie wiem o co chodzi :D
Te pierwsze 'Can not find...' to ja bym obstawiał że z winy pliku INI - może weź nasz i zmodyfikuj wg swojego.
a to:
Kod: Zaznacz cały
to już całkiem dziwne - nie zabuntował się o moduł thcud - czyli moduł chyba zainstalowany - a skoro burzy sie o pina to ja bym obstawiał że masz inny thcud.comp zainstalowany - chociaż to z-fb-out było chyba w oryginale - ja nie bardzo teraz pamiętam co w nim zmieniałem i ile z tych zmian zostało - trzebaby porównac oba pliki.
Ale na dzięn dobry to ja bym użył tego INI i tego thcud.comp co były w zipie - jeżeli LinuxCNC wstanie i nie będzie się burzył to będziemy walczyć ze zmianami.
jarenio
Posty w temacie: 11
Post napisał: jarenio » 23 sie 2012, 17:17
to już przewalczyłem :)
zrobiłeś loterówke, zamiast thcud jest thcup
ale i tak....
Kod: Zaznacz cały
plazma.hal:79: Signal name 'stepgen.2.position-fb' must not be the same as a pin.  Did you omit the signal name?
3154
walcze i walcze, ta ostatnia linijka nie daje mi żyć, a bez niej linuxcnc nie podnosi palnika mimo że vcp świeci że ma za nisko :(
thcud.comp od Johna poprawiłem pod siebie (zmieniłem porty) i zainstalowłem jeszcze raz
[ Dodano: 2012-08-23, 17:58 ]
nie mam weny, wygląda że jest ok, a nie jest, nie rusza Zką :/
na razie mam dość, nic dzisiaj nie wymyślę...
[ Dodano: 2012-08-23, 20:56 ]
teraz już poszedłem po całości.....
Kod: Zaznacz cały
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 File exists
15440
ERROR: Module thcud does not exist in /proc/modules
<commandline>:0: exit value: 1
<commandline>:0: rmmod failed, returned -1
<commandline>:0: unloadrt failed
ERROR: Module hal_lib is in use by thc
ERROR: Module rtapi is in use by thc,hal_lib
ERROR: Module rtai_math is in use by rtapi
ERROR: Module rtai_sem is in use by rtapi
ERROR: Module rtai_fifos is in use by rtapi
ERROR: Module rtai_sched is in use by rtapi,rtai_sem,rtai_fifos
ERROR: Module rtai_hal is in use by rtapi,rtai_sem,rtai_fifos,rtai_sched
ktoś się orientuje jak odinstalować .comp albo całkowicie zresetować linuxcnc ????
Pozdrawiam; Jarek
marekms
re
#24
Post napisał: marekms » 23 sie 2012, 21:23
U mnie też nie działa Z, wyrzuca 'błąd pozycji w napędzie 2" i ogólnie bardzo się muli, wgranie nowe gcodu trwa
40sek.
Marek
jarenio
Posty w temacie: 11
Post napisał: jarenio » 23 sie 2012, 21:31
przewalczyłem i program się uruchania
ArturM, jak możesz wrzuć full konfig jeszcze raz :)
Pozdrawiam; Jarek
ArturM
Post napisał: ArturM » 24 sie 2012, 08:49
jarenio pisze:przewalczyłem i program się uruchania
Ok - konfigi przegrane na żywo dziś rano z maszyny:
plazma.zip
(8.17 KiB) Pobrany 367 razy
jarenio
Posty w temacie: 11
Post napisał: jarenio » 24 sie 2012, 09:05
Dzięki, zaraz przetestuje, ale już widzę że są różnice ;)
[ Dodano: 2012-08-24, 10:07 ]
niestety, pozmieniałem wszytko tak jak jest u Ciebie, na VCP diody się zapalają ale palnik nie jeździ góra dół :/
zamieszczam moje ustawienia i plik ngc którym to testuje, jak byś miał chwilkę to plisssss luknij na to, może Ci się rzuci coś w oczy :)
[ Dodano: 2012-08-24, 11:59 ]
niestety, na głupotę nie ma rady, ale zawsze jest youtube :)
problem rozwiązany. Okazało się, że u mnie porty wejściowe są aktywne sygnałem niskim...
Pytanie mam jeszcze
możesz wyjaśnić działanie
setp thcud.requested-vel ??
setp thcud.vel-tol ??
setp thcud.correction-vel ??
Plazma.zip
plazma- jarenio
(10.11 KiB) Pobrany 348 razy
Pozdrawiam; Jarek
Post napisał: kamar » 24 sie 2012, 13:24
jarenio pisze: problem rozwiązany.
Może pokaż jak działa i wanienkę przy okazji.
P.S. Artur odpowie jak wróci. (Zebym ja mógł siedziec na forum to ktoś się musi bujać po terenie :) )
jarenio
Posty w temacie: 11
Post napisał: jarenio » 24 sie 2012, 13:51
oczywiście że się pochwalę, ale to w poniedziałek, bo juz się zbieram do wyjścia z firmy ;)
to co mnie głównie bęczy w tych ustawieniach to jakby wolne ruchy palnika, przy dużych prędkościach palenie nie daje sobie rady...
tyle że testowałem w ekstremalnych warunkach
jak byście jeszcze spisali ustawienia THC to by było super
I jeszcze jedno pytanie.
Interesowaliście się częścią kodu która chyba odłącza THC podczas zakrętów lini cięcia, bo takie coś chyba tam się chowa, ale za bardzo się temu nie przyglądałem ??
Pozdrawiam; Jarek
Post napisał: kamar » 24 sie 2012, 14:15
Drogi kolego :) dalej to już działka etatowych palaczy. :)
Ustawienia THC zrobiliśmy przypadkowe, przetestowaliśmy i żelastwo stoi.
Jak sie trafi jakieś poważniejsze palenie to znowu coś się posprawdza. A to może być za miesiąc albo i kwartał :)
