zadajnik mpg tokarka
tristar0
Posty w temacie: 11
Post napisał: tristar0 » 07 gru 2022, 18:54
Znalazłem kilka przykładów żaden nie działa , w pc są już dwie karty lpt w pliku hal cfg = 0xdce0 out 0x378 in
tyle ruszyło i dalej ani rusz
[custom.hal]
# Jog Pendant
loadrt encoder num_chan=1
loadrt mux4 count=1
addf encoder.capture-position servo-thread
addf encoder.update-counters base-thread
addf mux4.0 servo-thread
# If your MPG outputs a quadrature signal per click set x4 to 1
# If your MPG puts out 1 pulse per click set x4 to 0
setp encoder.0.x4-mode 0
# For velocity mode, set to 1
# In velocity mode the axis stops when the dial is stopped
# even if that means the commanded motion is not completed,
# For position mode (the default), set to 0
# In position mode the axis will move exactly jog-scale
# units for each count, regardless of how long that might take,
setp axis.x.jog-vel-mode 0
setp axis.z.jog-vel-mode 0
# This sets the scale that will be used based on the input to the mux4
setp mux4.0.in0 0.1
setp mux4.0.in1 0.01
setp mux4.0.in2 0.001
# The inputs to the mux4 component
net scale1 mux4.0.sel0 <= parport.1.pin-09-in
net scale2 mux4.0.sel1 <= parport.1.pin-10-in
# The output from the mux4 is sent to each axis jog scale
net mpg-scale <= mux4.0.out
net mpg-scale => axis.x.jog-scale
net mpg-scale => axis.z.jog-scale
# The MPG inputs
net mpg-a encoder.0.phase-A <= parport.1.pin-02-in
net mpg-b encoder.0.phase-B <= parport.1.pin-03-in
# The Axis select inputs
net mpg-x axis.x.jog-enable <= parport.1.pin-04-in
net mpg-z axis.z.jog-enable <= parport.1.pin-06-in
# The encoder output counts to the axis. Only the selected axis will move.
net encoder-counts <= encoder.0.counts
net encoder-counts => axis.x.jog-counts
net encoder-counts => axis.z.jog-counts
Dodane 3 minuty 52 sekundy:
Obrazek a pacjent leży i życia w nim nie widać
Re: zadajnik mpg tokarka
Post napisał: kamar » 07 gru 2022, 19:56
Zmień forum. To jest o obsłudze maszyn CNC, giercarze bawią się gdzie indziej :)
tristar0
Posty w temacie: 11
Post napisał: tristar0 » 07 gru 2022, 20:29
kamar pisze:giercarze bawią się gdzie indziej
skoro ty nie potrafisz obsługiwać wędki na maszynie to co ja na to poradzę, w życiu trzeba próbować wszystkiego .skoro w DMG są to w czym masz problem żeby w linuxcnc też była ta sama bajka.
Post napisał: tuxcnc » 07 gru 2022, 20:44
tristar0 pisze: ↑
07 gru 2022, 18:54
Enkoder wygląda na kwadraturowy, więc powinno być mode 1
Więcej Ci dzisiaj nie pomogę, bo miałem ciężki dzień w robocie i nie chce mi się myśleć...
Post napisał: kamar » 07 gru 2022, 20:49
tristar0 pisze: ↑
07 gru 2022, 20:29
.skoro w DMG są
Są. I wszystkie co znam, wiszą z boku na magnesie.:) Ależ oczywiście życzę powodzenia.
tristar0
Posty w temacie: 11
Post napisał: tristar0 » 07 gru 2022, 20:53
kamar pisze:Są. I wszystkie co znam, wiszą z boku na magnesie
Kamar jeden woli matkę drugi córkę ,każdy ma swoją rację . :P
Dodane 1 minuta 23 sekundy:
tuxcnc pisze:Enkoder wygląda na kwadraturowy
no jest bo to oryginał do maszyny ,sprawdzę co tam nagraćkałem .
Dodane 1 minuta 33 sekundy:
Najgorsze jest to że wywali linuxa i szukaj wiatru w polu
Post napisał: kamar » 07 gru 2022, 21:01
tristar0 pisze: ↑
07 gru 2022, 20:29
Wędkę to ja obsługuję dość sprawnie ( właśnie uzbrajam prezentową , trzykońcówkową shimankę)
Dodane 2 minuty 6 sekundy:
tristar0 pisze: ↑
07 gru 2022, 20:55
To nie zrobiłeś klonu dysku ? To podstawa a nie wędka.
Jak wywali to zainstalujesz Macha i będziesz jeszcze miał kolorowe nalepki na klawiaturę :) :)
Post napisał: tuxcnc » 07 gru 2022, 21:33
tristar0 pisze: ↑
07 gru 2022, 20:55
Możesz zakomentować wszystkie linie, potem odkomentowywać po jednej i używając ulubionego narzędzia (http://linuxcnc.org/docs/stable/html/hal/tools.html) sprawdzać czy stan sygnałów zmienia się kiedy kręcisz pokrętłami w MPG.
A Linuxcnc zwykle się wywala gdy przypiszesz ten sam sygnał dwa razy, albo próbujesz używać nieistniejącego sygnału.
Uruchamiaj Linuxcnc z konsoli i czytaj wszystkie komunikaty...
tristar0
Posty w temacie: 11
Post napisał: tristar0 » 07 gru 2022, 21:48
kamar pisze:Jak wywali to zainstalujesz Macha i będziesz jeszcze miał kolorowe nalepki na klawiaturę
haha zabawny jesteś.dysk jest już w pudełku i czeka na zdechnięcie oryginału.A nie do macha to już nie wrócę prędzej do korbki :wink:
Dodane 13 minuty 35 sekundy:
tu się wysypuje
Dodane 22 sekundy:
tuxcnc pisze:Możesz zakomentować wszystkie linie
Post napisał: tuxcnc » 07 gru 2022, 21:59
tristar0 pisze: ↑
07 gru 2022, 21:48
Pin 9 to jest wyjście, a przypisujesz go jako wejście.
Sprawdź to.
