Z probe - problemy
andrzejn
Z probe - problemy
Post napisał: andrzejn » 04 sie 2022, 18:40
Mam problem z wykonaniem Z probe. Oprogramowanie grbl 1.1h; arduino uno (klon). Sondę podłączyłem do A5 w arduino. Po wpisaniu kodu "G91 G21 G38.2 Z-20 F50" oś Z leciutko drgnie i pojawia się komunikat:
"[PRB:0.000,0.000,0.760:1]
ok"
Co może być przyczyną tego, że oś Z nie przejeżdża zadeklarowanego dystansu 20mm?
Będę ogromnie wdzięczny za pomoc.
Moje ustawienia:
$0 = 10 (Step pulse time, microseconds)
$1 = 25 (Step idle delay, milliseconds)
$2 = 0 (Step pulse invert, mask)
$3 = 1 (Step direction invert, mask)
$4 = 0 (Invert step enable pin, boolean)
$5 = 0 (Invert limit pins, boolean)
$6 = 0 (Invert probe pin, boolean)
$10 = 2 (Status report options, mask)
$11 = 0.010 (Junction deviation, millimeters)
$12 = 0.002 (Arc tolerance, millimeters)
$13 = 0 (Report in inches, boolean)
$20 = 0 (Soft limits enable, boolean)
$21 = 0 (Hard limits enable, boolean)
$22 = 0 (Homing cycle enable, boolean)
$23 = 0 (Homing direction invert, mask)
$24 = 25.000 (Homing locate feed rate, mm/min)
$25 = 500.000 (Homing search seek rate, mm/min)
$26 = 250 (Homing switch debounce delay, milliseconds)
$27 = 1.000 (Homing switch pull-off distance, millimeters)
$30 = 10000 (Maximum spindle speed, RPM)
$31 = 0 (Minimum spindle speed, RPM)
$32 = 0 (Laser-mode enable, boolean)
$100 = 50.000 (X-axis travel resolution, step/mm)
$101 = 50.000 (Y-axis travel resolution, step/mm)
$102 = 200.000 (Z-axis travel resolution, step/mm)
$110 = 5000.000 (X-axis maximum rate, mm/min)
$111 = 5000.000 (Y-axis maximum rate, mm/min)
$112 = 500.000 (Z-axis maximum rate, mm/min)
$120 = 50.000 (X-axis acceleration, mm/sec^2)
$121 = 50.000 (Y-axis acceleration, mm/sec^2)
$122 = 10.000 (Z-axis acceleration, mm/sec^2)
$130 = 350.000 (X-axis maximum travel, millimeters)
$131 = 350.000 (Y-axis maximum travel, millimeters)
$132 = 100.000 (Z-axis maximum travel, millimeters)
Re: Z probe - problemy
Post napisał: tuxcnc » 04 sie 2022, 22:09
andrzejn pisze:
04 sie 2022, 18:40
ok"
Tradycyjny problem w Arduino, czyli zakłócenia.
Przewód od sondy robi za antenę i zbiera wszystkie zakłócenia z okolicy, a wejście jest wystarczająco czułe żeby na nie zareagować.
Pomóc może kondensator (kilka do kilkudziesięciu nF) wpięty pomiędzy wejście i masę.
Są bardziej profesjonalne metody, ale zacznij od kondensatora.
andrzejn
Post napisał: andrzejn » 05 sie 2022, 11:45
Oczywiście zadziałało! Wstawiłem 47 nF.
Wielkie, wielkie dzięki, tym bardziej, że to już kolejna pomoc, której mi udzieliłeś. Przy mojej wiedzy elektronicznej (a w zasadzie jej braku) w życiu bym na to nie wpadł.
Wróć do „CNC podstawy”
