Hello
Sorry , i speak only english.
I have a Morbidelli u50 for 2 monts , now i have start it , for most of things works ok , but i have a problem , if i go whith the speed over 50% i have the next error :27 X Axis:pursiut erorr
can anyone help me pls !
Morbidelli U50
avanu_cristi
Petroholic
avanu_cristi
Hello , i have seen that post , but if i put the values like in the picture you put , and the speed is to low .
At the begining it worked mutch faster , but like most of the people, the baterry run out and lost the parameters , i loaded the new ones and have this problem now.
and if i put the values from the picture only in x axis , then i have same erorr but in the next axis , Y , and so on
So i think is a problem whith the parameters.
Tnks!
[ Dodano: 2017-07-19, 11:50 ]
Tnks!
On everithing i found on google the specification looks like in the picture atachPetroholic pisze:X AXIS maximum speed 20.000 ??? That gives 20m/min it's way to fast in my opinion. Google says it should be less...
From the other post about same problem:
Next thing is - check X axis screw if it's clogged...
Petroholic
jarosław pawlik
