Od kilku dni bawie sie z ustawieniem odpowiednich parametrów ciecia raz jest dobrze raz gorzej i na dodatek zuzywaja sie szybko dysze i elektrody do powermaxa 30 i wcale nie sa tanie
Mam kilka pytań odnosnie ciecia plazmą powietrzną.
1 Uzywam z edytowanego postprocesora do mach3 oraz makro i niewiem czy działa własciwie: (blacha 2m predkosc 2000 30 amp, cisnienie rozne od 4 do 6 )
Post
N0010 (Filename: t.tap)
N0020 (Post processor: moj.scpost)
N0030 (Date: 2016-05-31)
N0040 G21 (Units: Metric)
N0050 G53 G90 G40
N0060 (Part: t)
N0070 M06 T0 (Plazma, 1 mm szczelina)
N0080 G00 X20.8048 Y8.6198 Z10.0000
N0090 M300
N0100 G00
N0110 M03
N0120 G01 Y5.6198 Z0.0000 F2000
N0130 X24.5000
N0140 Y14.6198
N0150 X15.5000
N0160 Y5.6198
N0170 X20.8048
N0180 M05
N0190 G00 Z10.0000
N0200 X20.0000 Y30.8322
N0210 M300
N0220 G00
N0230 M03
N0240 G01 Y27.8322 Z0.0000
N0250 G03 X20.0000 Y27.8322 I0.0000 J2.5000 F2000.0
N0260 M05
N0270 G00 Z10.0000
N0280 X40.0000 Y-3.5000
N0290 M300
N0300 G00
N0310 M03
N0320 G01 Y-0.5000 Z0.0000 F2000
N0330 X-2.5250
N0340 G03 X-0.5000 Y-2.5250 I0.0000 J-2.0250 F2000.0
N0350 G01 Y42.5250 F2000
N0360 G03 X-2.5250 Y40.5000 I-2.0250 J0.0000 F2000.0
N0370 G01 X42.5250 F2000
N0380 G03 X40.5000 Y42.5250 I0.0000 J2.0250 F2000.0
N0390 G01 Y0.0000 F2000
N0400 M05
N0410 G00 Z10.0000
N0420 M05 M30
Makro
HeightOfDetect = 5
SpeedOfDetect = 500
Offset = 5
HeightOfTransfer = 2
HeightOfPierce = 4
HeightOfCut = 1
Delay = Param1()
Dim MaterialPos As Double
If (GetOEMDro(186)>HeightOfDetect) Or GetOEMDro(186) Then
code "G00 Z" & HeightOfDetect
While IsMoving()
Wend
End If
message("Detecting of material pos.")
code "G31 Z-10 F" & SpeedOfDetect
While IsMoving()
Wend
If GetOEMDro(186)=-10 Then
message("No material detected")
While IsMoving()
Wend
1: GoTo 1
Else
MaterialPos = GetOEMDro(186) + offset
message("Material detected pos = " & MaterialPos)
code "G00 Z" & MaterialPos + HeightOfTransfer
While IsMoving()
Wend
DoSpinCW()
If Delay>200 Then
code "G00 Z" & MaterialPos + HeightOfPierce
While IsMoving()
Wend
End If
Sleep(Delay+1)
code "G00 Z" & MaterialPos + HeightOfCut
While IsMoving()
Wend
End If
2 Jak mam dobrac ustawienia THC do plazmy i ewentualnie do grubosci blachy?
Chodzi mi głownie o prad no chyba ze inne ustawienia tez sa wazne..
Podobno mozna to jakosc wyliczyc??
Prosze o jakies porady podstawy aby sie do tego zabrac..
