MEGAPLOT XMD 32 - jakies opinie
syntetyczny
Posty w temacie: 14
Post napisał: syntetyczny » 29 cze 2013, 13:51
mc2kwacz pisze:umieszczone obok złączy chłodzenia, które potrafią ciec
Ja wykręciłem te króćce, naładowałem uszczelniacza do łączeń hydraulicznych, założyłem obejmę i zostawiłem na 12h. Po czym wkręciłem na miejsce. Od tego momentu zniknął problem cieknięcia....
Kreatura CNC
Modernizacja plotera megaplot
Georgi Mirov
Problem
#152
Post napisał: Georgi Mirov » 03 lip 2015, 16:46
I have an issue with this router.
When I load a new operation with a G-code and center the tool Z position ( I check the reading it's 98,5mm table-tool distance)
Then after the operation is finished if I continue to load operations all the time the Z position goes down 0.1mm after the operation is finished.
Let's say if I start a new G-code with 4 operations , the machines goes 0.1mm everytime and and at the end the last operation is already 0,4mm below the surface.
I started to center the tool after every operation and the reading at the Z position is 98,4 ; 98,3 and so on ..
I have checked the motor shaft to screw shaft coupling. It's tight.
Should I check the NUT - spinndle mount connection ?
Or it's another problem ?
This is the only motor that doesn't have a fan cooling and it's getting really hot.
syntetyczny
Posty w temacie: 14
Post napisał: syntetyczny » 03 lip 2015, 21:24
Two things, firstly check ballscrew nut, there is white ptfe plastic which prevents dust to get into nut. It should be loosened. Use some WD40 to clean ballscrew nut from transport dirt.
Secondly, check current settings on stepper driver for Z axis. It might be set too high.
Kreatura CNC
Georgi Mirov
#154
Post napisał: Georgi Mirov » 04 lip 2015, 10:21
I wil check the nut , how to check this Z driver ?
[ Dodano: 2015-07-04, 12:08 ]
I think I found the problem ...
When I center the tool and on it's highest position it's above 90mm the limit switch diode isn't lightening and probably this is why it's giving those errors.
After I center it with spindle lowered down and at it's highest position it's bellow 90mm the diode is ON and after one operation it didn't went down with 0,1mm .....
[ Dodano: 2015-07-04, 12:30 ]
No this didn't fixed it the machine went down again.
[ Dodano: 2015-07-04, 19:06 ]
How to check this driver setting ?
Can my error be related with wrong setting for motor/screw/steps ratio in the software ? ( I don't know if I'm explaining it right)
I mean if it's turning 0,999mm on screw instead of 1,000mm and this error is multiplied on every turn ?
On the driver for sets for pulse I have pin 7 ON ( 5000 Pulse/REV).
Can I run this machine with MACH 3 so I can set all values and check if this error appears ? What is your opinion ?
savox1
#155
Post napisał: savox1 » 26 sty 2016, 18:44
Witam Wszystkich.
Stałem się posiadaczem plotera XMD 32. Trochę się nim pobawiłem i program MegaCut niezbyt przypadł mi do gustu. Zakupiłem więc Macha3 i taką oto płytkę do tego plotera: http://cncprofi.com/plyta-glowna-z-opto ... 0-10v.html
Problem w tym, że nie bardzo umiem to sobie zgrać do kupy. Czy ktoś mógłby mnie poinstruować albo podrzucić jakaś instrukcję?
Ewentualnie czy mogę Machem sterować ploterem wykorzystując wbudowaną płytkę z gniazdem USB?
savox1
#156
Post napisał: savox1 » 01 lut 2016, 15:14
Naprawdę nikt nic nie wie? :sad:
syntetyczny
Posty w temacie: 14
Post napisał: syntetyczny » 01 lut 2016, 19:16
Nie i nie. Żeby ta płytka ze sklepu działała, trzeba wybebeszyć sterownik usb i podłączyć sygnały do tego rozdzielacza LPT i do dopiero do kompa z LPT.
Chce kolega sterowania Mach po usb, no to słyszałem że są takie, ale trzeba zapłacić ekstra za to.
Kreatura CNC
matisek932
Post napisał: matisek932 » 02 lut 2016, 12:25
Kto ma namiary na firmę która zajmuje się sprzedażą XMD 32 , oczywiście nowe??
CNC-SZLIF Toruń
oprawcafotografii
Posty w temacie: 45
#159
Post napisał: oprawcafotografii » 02 lut 2016, 13:12
Chyba nikt.
q
savox1
#160
Post napisał: savox1 » 04 lut 2016, 14:47
syntetyczny pisze:Chce kolega sterowania Mach po usb, no to słyszałem że są takie, ale trzeba zapłacić ekstra za to.
zapłacę, tylko powiedź kto mi to zrobi :)
matisek932 pisze:Kto ma namiary na firmę która zajmuje się sprzedażą XMD 32 , oczywiście nowe??
http://www.megaplot.com.pl/
