Manualna zmiana narzędzia z czujnikiem długości
pietras_vip
Stały bywalec (min. 70)
Post napisał: pietras_vip » 14 gru 2012, 15:23
mógłbyś mi to rozjaśnić jestem początkujacy
manual_change.ngc
Kod: Zaznacz cały
   1 ; manual toolchange with automatic tool length probe
   2
   3 o<manual_change> sub
   4
   5 (we change feed, metric/in and potentially G90)
   6 (so mark as save caller state & auto-restore on return or endsub)
   7
   8 M73
   9
  10 G21 (TLO and toolchange position is in mm as per ini)
  11 G90 (absolute)
  12
  13 ; move to toolchange position: z, then xy
  14 g53 g0 Z #<_ini[change_position]z>
  15 g53 g0 X #<_ini[change_position]x> Y #<_ini[change_position]y>
  16
  17 ; indicate tool number to be loaded
  18 M68 E #<_ini[pins]toolno> Q #<_selected_tool>
  19
  20 ; enable table
  21 M64 P  #<_ini[pins]enable>
  22
  23 ; signal user to change tool
  24 M64 P  #<_ini[pins]change>
  25
  26 ; and wait for acknowledgement
  27 M66 P #<_ini[pins]changed> L1 Q#<_ini[dwell]ack_secs>
  28 M65 P #<_ini[pins]change> ; drop change pin
  29
  30
  31 ;see if we timed out
  32 O100 if [#5399 EQ -1]
  33         M65 P  #<_ini[pins]enable> ; disable table
  34 O100    return [-1] ; indicate timeout failure to epilog
  35 O100 endif
  36
  37 O200 if [#<_selected_tool> EQ 0]   ; an unload.
  38         M65 P  #<_ini[pins]enable> ; disable table
  39 O200    return [1] ; indicate success
  40 O200 endif
  41
  42 ; tool changed - move to toolensor
  43 g53 g0 X #<_ini[toolsensor]x> Y #<_ini[toolsensor]y>
  44 g53 g0 Z #<_ini[toolsensor]z>
  45
  46 ; probe tool length
  47 M64 P  #<_ini[pins]probing> ; turn on probing led
  48
  49 F #<_ini[toolsensor]probefeed>
  50 G91 (relative mode)
  51 G38.3 Z #<_ini[toolsensor]maxprobe>
  52
  53 ; we must execute this only in the milltask interpreter
  54 ; or preview will break, so test for '#<_task>' which is 1 for
  55 ; the milltask interpreter and 0 in the UI's
  56
  57 O300 if [[#<_task> GT 0] and [#5070 EQ 0]]
  58 O300    return [-2] ; indicate probe contact failure to epilog
  59 O300 endif
  60
  61
  62 ; see wether this was the reference tool:
  63 M66 P #<_ini[pins]reftool> L0
  64
  65 O400 if [#5399 EQ 1]
  66     #1000=#5063 (save reference tool length)
  67     M68 E #<_ini[pins]reflen> Q #1000
  68     (print,reference length is #1000)
  69 O400 else
  70      g43.1 z[#5063-#1000] (set new tool offset)
  71      M68 E #<_ini[pins]currlen> Q [#5063-#1000]
  72      (print,new length is #5063)
  73 O400 endif
  74
  75 M65 P #<_ini[pins]probing> ; drop probing led
  76 M65 P  #<_ini[pins]enable> ; disable table
  77
  78 G90 (absolute)
  79
  80
  81 ; move back to toolchange position: z, then xy
  82 g53 g0 Z #<_ini[change_position]z>
  83 g53 g0 X #<_ini[change_position]x> Y #<_ini[change_position]y>
  84
  85 ; succeed by returning a positive value
  86 o<manual_change> endsub [1]
  87 m2
potrzebne pliki gdzie je wrzucic
MlKl
Post napisał: MlKl » 14 gru 2012, 15:33
To, co wkleiłeś wrzuć tam, gdzie masz inne suby od NGCGUI
http://git.mah.priv.at/gitweb/emc2-dev. ... adevcp.hal to do katalogu z twoim plikiem ini, i wywołaj to w pliku .ini swojej maszyny
http://git.mah.priv.at/gitweb/emc2-dev. ... change.ini - tu masz przykładowy plik .ini - musisz na jego podstawie edytować swój własny, porównaj wpisy i po prostu przekopiuj do swojego w odpowiednich sekcjach te odnośnie zmiany narzędzia.
syntetyczny
Post napisał: syntetyczny » 18 gru 2012, 16:31
A nie można tak jak w tym manualu?? I w MDI_COMMAND dać komendę, zrobić buttona, podłączyć go i heja?Tak jak Artur_M radził??
Kreatura CNC
Modernizacja plotera megaplot
