no i zbieram się, za analizę timer.h
fancyblink.list zapewnie wyjaśni wątpliwości, gdzie co ustawione (i jak)
Kod: Zaznacz cały
fancyblink.elf: file format elf32-littlearm
Disassembly of section .text:
08000000 <vector_table>:
8000000: 00 00 02 20 e5 01 00 08 37 02 00 08 35 02 00 08 ... ....7...5...
8000010: 35 02 00 08 35 02 00 08 35 02 00 08 00 00 00 00 5...5...5.......
800002c: 37 02 00 08 37 02 00 08 00 00 00 00 37 02 00 08 7...7.......7...
800003c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800004c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800005c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800006c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800007c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800008c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800009c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
80000ac: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
80000bc: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
80000cc: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
80000dc: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
80000ec: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
80000fc: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800010c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800011c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800012c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800013c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800014c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800015c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800016c: 37 02 00 08 37 02 00 08 37 02 00 08 37 02 00 08 7...7...7...7...
800017c: 37 02 00 08 37 02 00 08 7...7...
08000184 <clock_setup>:
#include <libopencm3/stm32/f4/rcc.h>
#include <libopencm3/stm32/f4/gpio.h>
/* Set STM32 to 168 MHz. */
void clock_setup(void)
8000184: b508 push {r3, lr}
rcc_clock_setup_hse_3v3(&hse_8mhz_3v3[CLOCK_3V3_168MHZ]);
8000186: 4804 ldr r0, [pc, #16] ; (8000198 <clock_setup+0x14>)
8000188: f000 f8fa bl 8000380 <rcc_clock_setup_hse_3v3>
/* Enable GPIOD clock. */
rcc_peripheral_enable_clock(&RCC_AHB1ENR, RCC_AHB1ENR_IOPDEN);
800018c: 4803 ldr r0, [pc, #12] ; (800019c <clock_setup+0x18>)
800018e: 2108 movs r1, #8
8000190: e8bd 4008 ldmia.w sp!, {r3, lr}
8000194: f000 b8b8 b.w 8000308 <rcc_peripheral_enable_clock>
8000198: 080004a4 .word 0x080004a4
800019c: 40023830 .word 0x40023830
080001a0 <gpio_setup>:
void gpio_setup(void)
/* Set GPIO12-15 (in GPIO port D) to 'output push-pull'. */
gpio_mode_setup(GPIOD, GPIO_MODE_OUTPUT,
80001a0: 4803 ldr r0, [pc, #12] ; (80001b0 <gpio_setup+0x10>)
80001a2: 2101 movs r1, #1
80001a4: 2200 movs r2, #0
80001a6: f44f 4370 mov.w r3, #61440 ; 0xf000
80001aa: f000 b929 b.w 8000400 <gpio_mode_setup>
80001ae: bf00 nop
80001b0: 40020c00 .word 0x40020c00
080001b4 <main>:
GPIO_PUPD_NONE, GPIO12 | GPIO13 | GPIO14 | GPIO15);
int main(void)
80001b4: b508 push {r3, lr}
int i;
clock_setup();
80001b6: f7ff ffe5 bl 8000184 <clock_setup>
gpio_setup();
80001ba: f7ff fff1 bl 80001a0 <gpio_setup>
/* Set two LEDs for wigwag effect when toggling. */
gpio_set(GPIOD, GPIO12 | GPIO14);
80001be: 4807 ldr r0, [pc, #28] ; (80001dc <main+0x28>)
80001c0: f44f 41a0 mov.w r1, #20480 ; 0x5000
80001c4: f000 f93f bl 8000446 <gpio_set>
/* Blink the LEDs (PD12, PD13, PD14 and PD15) on the board. */
while (1) {
/* Toggle LEDs. */
gpio_toggle(GPIOD, GPIO12 | GPIO13 | GPIO14 | GPIO15);
80001c8: 4804 ldr r0, [pc, #16] ; (80001dc <main+0x28>)
80001ca: f44f 4170 mov.w r1, #61440 ; 0xf000
80001ce: f000 f93c bl 800044a <gpio_toggle>
80001d2: 4b03 ldr r3, [pc, #12] ; (80001e0 <main+0x2c>)
for (i = 0; i < 6000000; i++) /* Wait a bit. */
__asm__("nop");
80001d4: bf00 nop
while (1) {
/* Toggle LEDs. */
80001d6: 3b01 subs r3, #1
80001d8: d1fc bne.n 80001d4 <main+0x20>
80001da: e7f5 b.n 80001c8 <main+0x14>
80001dc: 40020c00 .word 0x40020c00
80001e0: 005b8d80 .word 0x005b8d80
080001e4 <reset_handler>:
void reset_handler(void)
volatile unsigned *src, *dest;
__asm__("MSR msp, %0" : : "r"(&_stack));
80001e4: 4b0d ldr r3, [pc, #52] ; (800021c <reset_handler+0x38>)
80001e6: f383 8808 msr MSP, r3
/* Enable access to Floating-Point coprocessor. */
SCB_CPACR |= SCB_CPACR_FULL * (SCB_CPACR_CP10 | SCB_CPACR_CP11);
80001ea: 4b0d ldr r3, [pc, #52] ; (8000220 <reset_handler+0x3c>)
dcmi_isr,
cryp_isr,
hash_rng_isr,
80001ec: 490d ldr r1, [pc, #52] ; (8000224 <reset_handler+0x40>)
80001ee: 681a ldr r2, [r3, #0]
80001f0: f442 0270 orr.w r2, r2, #15728640 ; 0xf00000
80001f4: 601a str r2, [r3, #0]
for (src = &_data_loadaddr, dest = &_data; dest < &_edata; src++, dest++)
80001f6: 4b0c ldr r3, [pc, #48] ; (8000228 <reset_handler+0x44>)
80001f8: 4a0c ldr r2, [pc, #48] ; (800022c <reset_handler+0x48>)
dcmi_isr,
cryp_isr,
hash_rng_isr,
80001fa: 1ac9 subs r1, r1, r3
80001fc: e002 b.n 8000204 <reset_handler+0x20>
*dest = *src;
80001fe: 5858 ldr r0, [r3, r1]
8000200: f843 0b04 str.w r0, [r3], #4
8000204: 4293 cmp r3, r2
8000206: d3fa bcc.n 80001fe <reset_handler+0x1a>
8000208: e002 b.n 8000210 <reset_handler+0x2c>
*dest = *src;
while (dest < &_ebss)
*dest++ = 0;
800020a: f843 2b04 str.w r2, [r3], #4
800020e: e001 b.n 8000214 <reset_handler+0x30>
*dest = *src;
8000210: 4907 ldr r1, [pc, #28] ; (8000230 <reset_handler+0x4c>)
*dest++ = 0;
8000212: 2200 movs r2, #0
*dest = *src;
8000214: 428b cmp r3, r1
8000216: d3f8 bcc.n 800020a <reset_handler+0x26>
*dest++ = 0;
/* Call the application's entry point. */
main();
8000218: f7ff bfcc b.w 80001b4 <main>
800021c: 20020000 .word 0x20020000
8000220: e000ed88 .word 0xe000ed88
8000224: 080004bc .word 0x080004bc
8000228: 20000000 .word 0x20000000
800022c: 20000008 .word 0x20000008
8000230: 20000008 .word 0x20000008
08000234 <blocking_handler>:
void blocking_handler(void)
8000234: e7fe b.n 8000234 <blocking_handler>
08000236 <null_handler>:
void null_handler(void)
/* Do nothing. */
8000236: 4770 bx lr
08000238 <rcc_wait_for_osc_ready>:
return ((RCC_CIR & RCC_CIR_CSSF) != 0);
void rcc_wait_for_osc_ready(osc_t osc)
switch (osc) {
8000238: 2804 cmp r0, #4
800023a: d81c bhi.n 8000276 <rcc_wait_for_osc_ready+0x3e>
800023c: e8df f000 tbb [pc, r0]
8000240: 120d0803 .word 0x120d0803
8000244: 17 .byte 0x17
8000245: 00 .byte 0x00
case PLL:
while ((RCC_CR & RCC_CR_PLLRDY) == 0);
8000246: 4b0c ldr r3, [pc, #48] ; (8000278 <rcc_wait_for_osc_ready+0x40>)
8000248: 681a ldr r2, [r3, #0]
800024a: 0191 lsls r1, r2, #6
800024c: d5fc bpl.n 8000248 <rcc_wait_for_osc_ready+0x10>
800024e: 4770 bx lr
break;
case HSE:
while ((RCC_CR & RCC_CR_HSERDY) == 0);
8000250: 4b09 ldr r3, [pc, #36] ; (8000278 <rcc_wait_for_osc_ready+0x40>)
8000252: 681a ldr r2, [r3, #0]
8000254: 0392 lsls r2, r2, #14
8000256: d5fc bpl.n 8000252 <rcc_wait_for_osc_ready+0x1a>
8000258: 4770 bx lr
break;
case HSI:
while ((RCC_CR & RCC_CR_HSIRDY) == 0);
800025a: 4b07 ldr r3, [pc, #28] ; (8000278 <rcc_wait_for_osc_ready+0x40>)
800025c: 681a ldr r2, [r3, #0]
800025e: 0790 lsls r0, r2, #30
8000260: d5fc bpl.n 800025c <rcc_wait_for_osc_ready+0x24>
8000262: 4770 bx lr
break;
case LSE:
while ((RCC_BDCR & RCC_BDCR_LSERDY) == 0);
8000264: 4b05 ldr r3, [pc, #20] ; (800027c <rcc_wait_for_osc_ready+0x44>)
8000266: 681a ldr r2, [r3, #0]
8000268: 0791 lsls r1, r2, #30
800026a: d5fc bpl.n 8000266 <rcc_wait_for_osc_ready+0x2e>
800026c: 4770 bx lr
break;
case LSI:
while ((RCC_CSR & RCC_CSR_LSIRDY) == 0);
800026e: 4b04 ldr r3, [pc, #16] ; (8000280 <rcc_wait_for_osc_ready+0x48>)
8000270: 681a ldr r2, [r3, #0]
8000272: 0792 lsls r2, r2, #30
8000274: d5fc bpl.n 8000270 <rcc_wait_for_osc_ready+0x38>
8000276: 4770 bx lr
8000278: 40023800 .word 0x40023800
800027c: 40023870 .word 0x40023870
8000280: 40023874 .word 0x40023874
08000284 <rcc_wait_for_sysclk_status>:
void rcc_wait_for_sysclk_status(osc_t osc)
switch (osc) {
8000284: 2801 cmp r0, #1
8000286: d00a beq.n 800029e <rcc_wait_for_sysclk_status+0x1a>
8000288: d302 bcc.n 8000290 <rcc_wait_for_sysclk_status+0xc>
800028a: 2802 cmp r0, #2
800028c: d112 bne.n 80002b4 <rcc_wait_for_sysclk_status+0x30>
800028e: e00d b.n 80002ac <rcc_wait_for_sysclk_status+0x28>
case PLL:
while ((RCC_CFGR & ((1 << 1) | (1 << 0))) != RCC_CFGR_SWS_PLL);
8000290: 4b09 ldr r3, [pc, #36] ; (80002b8 <rcc_wait_for_sysclk_status+0x34>)
8000292: 681a ldr r2, [r3, #0]
8000294: f002 0203 and.w r2, r2, #3
8000298: 2a02 cmp r2, #2
800029a: d1fa bne.n 8000292 <rcc_wait_for_sysclk_status+0xe>
800029c: 4770 bx lr
break;
case HSE:
while ((RCC_CFGR & ((1 << 1) | (1 << 0))) != RCC_CFGR_SWS_HSE);
800029e: 4b06 ldr r3, [pc, #24] ; (80002b8 <rcc_wait_for_sysclk_status+0x34>)
80002a0: 681a ldr r2, [r3, #0]
80002a2: f002 0203 and.w r2, r2, #3
80002a6: 2a01 cmp r2, #1
80002a8: d1fa bne.n 80002a0 <rcc_wait_for_sysclk_status+0x1c>
80002aa: 4770 bx lr
break;
case HSI:
while ((RCC_CFGR & ((1 << 1) | (1 << 0))) != RCC_CFGR_SWS_HSI);
80002ac: 4b02 ldr r3, [pc, #8] ; (80002b8 <rcc_wait_for_sysclk_status+0x34>)
80002ae: 681a ldr r2, [r3, #0]
80002b0: 0790 lsls r0, r2, #30
80002b2: d1fc bne.n 80002ae <rcc_wait_for_sysclk_status+0x2a>
80002b4: 4770 bx lr
80002b6: bf00 nop
80002b8: 40023808 .word 0x40023808
080002bc <rcc_osc_on>:
void rcc_osc_on(osc_t osc)
switch (osc) {
80002bc: 2804 cmp r0, #4
80002be: d81b bhi.n 80002f8 <rcc_osc_on+0x3c>
80002c0: e8df f000 tbb [pc, r0]
80002c4: 0f0d0803 .word 0x0f0d0803
80002c8: 15 .byte 0x15
80002c9: 00 .byte 0x00
case PLL:
RCC_CR |= RCC_CR_PLLON;
80002ca: 4b0c ldr r3, [pc, #48] ; (80002fc <rcc_osc_on+0x40>)
80002cc: 681a ldr r2, [r3, #0]
80002ce: f042 7280 orr.w r2, r2, #16777216 ; 0x1000000
80002d2: e00a b.n 80002ea <rcc_osc_on+0x2e>
break;
case HSE:
RCC_CR |= RCC_CR_HSEON;
80002d4: 4b09 ldr r3, [pc, #36] ; (80002fc <rcc_osc_on+0x40>)
80002d6: 681a ldr r2, [r3, #0]
80002d8: f442 3280 orr.w r2, r2, #65536 ; 0x10000
80002dc: e005 b.n 80002ea <rcc_osc_on+0x2e>
break;
case HSI:
RCC_CR |= RCC_CR_HSION;
80002de: 4b07 ldr r3, [pc, #28] ; (80002fc <rcc_osc_on+0x40>)
80002e0: e000 b.n 80002e4 <rcc_osc_on+0x28>
break;
case LSE:
RCC_BDCR |= RCC_BDCR_LSEON;
80002e2: 4b07 ldr r3, [pc, #28] ; (8000300 <rcc_osc_on+0x44>)
80002e4: 681a ldr r2, [r3, #0]
80002e6: f042 0201 orr.w r2, r2, #1
80002ea: 601a str r2, [r3, #0]
break;
80002ec: 4770 bx lr
case LSI:
RCC_CSR |= RCC_CSR_LSION;
80002ee: 4b05 ldr r3, [pc, #20] ; (8000304 <rcc_osc_on+0x48>)
80002f0: 681a ldr r2, [r3, #0]
80002f2: f042 0201 orr.w r2, r2, #1
80002f6: 601a str r2, [r3, #0]
80002f8: 4770 bx lr
80002fa: bf00 nop
80002fc: 40023800 .word 0x40023800
8000300: 40023870 .word 0x40023870
8000304: 40023874 .word 0x40023874
08000308 <rcc_peripheral_enable_clock>:
void rcc_peripheral_enable_clock(volatile u32 *reg, u32 en)
*reg |= en;
8000308: 6803 ldr r3, [r0, #0]
800030a: 430b orrs r3, r1
800030c: 6003 str r3, [r0, #0]
800030e: 4770 bx lr
08000310 <rcc_set_sysclk_source>:
void rcc_set_sysclk_source(u32 clk)
u32 reg32;
reg32 = RCC_CFGR;
8000310: 4b03 ldr r3, [pc, #12] ; (8000320 <rcc_set_sysclk_source+0x10>)
8000312: 681a ldr r2, [r3, #0]
reg32 &= ~((1 << 1) | (1 << 0));
8000314: f022 0203 bic.w r2, r2, #3
RCC_CFGR = (reg32 | clk);
8000318: 4302 orrs r2, r0
800031a: 601a str r2, [r3, #0]
800031c: 4770 bx lr
800031e: bf00 nop
8000320: 40023808 .word 0x40023808
08000324 <rcc_set_ppre2>:
void rcc_set_ppre2(u32 ppre2)
u32 reg32;
reg32 = RCC_CFGR;
8000324: 4b03 ldr r3, [pc, #12] ; (8000334 <rcc_set_ppre2+0x10>)
8000326: 681a ldr r2, [r3, #0]
reg32 &= ~((1 << 13) | (1 << 14) | (1 << 15));
8000328: f422 4260 bic.w r2, r2, #57344 ; 0xe000
RCC_CFGR = (reg32 | (ppre2 << 13));
800032c: ea42 3240 orr.w r2, r2, r0, lsl #13
8000330: 601a str r2, [r3, #0]
8000332: 4770 bx lr
8000334: 40023808 .word 0x40023808
08000338 <rcc_set_ppre1>:
void rcc_set_ppre1(u32 ppre1)
u32 reg32;
reg32 = RCC_CFGR;
8000338: 4b03 ldr r3, [pc, #12] ; (8000348 <rcc_set_ppre1+0x10>)
800033a: 681a ldr r2, [r3, #0]
reg32 &= ~((1 << 10) | (1 << 11) | (1 << 12));
800033c: f422 52e0 bic.w r2, r2, #7168 ; 0x1c00
RCC_CFGR = (reg32 | (ppre1 << 10));
8000340: ea42 2280 orr.w r2, r2, r0, lsl #10
8000344: 601a str r2, [r3, #0]
8000346: 4770 bx lr
8000348: 40023808 .word 0x40023808
0800034c <rcc_set_hpre>:
void rcc_set_hpre(u32 hpre)
u32 reg32;
reg32 = RCC_CFGR;
800034c: 4b03 ldr r3, [pc, #12] ; (800035c <rcc_set_hpre+0x10>)
800034e: 681a ldr r2, [r3, #0]
reg32 &= ~((1 << 4) | (1 << 5) | (1 << 6) | (1 << 7));
8000350: f022 02f0 bic.w r2, r2, #240 ; 0xf0
RCC_CFGR = (reg32 | (hpre << 4));
8000354: ea42 1200 orr.w r2, r2, r0, lsl #4
8000358: 601a str r2, [r3, #0]
800035a: 4770 bx lr
800035c: 40023808 .word 0x40023808
08000360 <rcc_set_main_pll_hse>:
(pllq << RCC_PLLCFGR_PLLQ_SHIFT);
void rcc_set_main_pll_hse(u32 pllm, u32 plln, u32 pllp, u32 pllq)
RCC_PLLCFGR = (pllm << RCC_PLLCFGR_PLLM_SHIFT) |
8000360: f440 0080 orr.w r0, r0, #4194304 ; 0x400000
(plln << RCC_PLLCFGR_PLLN_SHIFT) |
8000364: ea40 1081 orr.w r0, r0, r1, lsl #6
(((pllp >> 1) - 1) << RCC_PLLCFGR_PLLP_SHIFT) |
8000368: 0852 lsrs r2, r2, #1
RCC_PLLCFGR_PLLSRC |
800036a: ea40 6003 orr.w r0, r0, r3, lsl #24
800036e: 3a01 subs r2, #1
8000370: 4b02 ldr r3, [pc, #8] ; (800037c <rcc_set_main_pll_hse+0x1c>)
8000372: ea40 4002 orr.w r0, r0, r2, lsl #16
8000376: 6018 str r0, [r3, #0]
8000378: 4770 bx lr
800037a: bf00 nop
800037c: 40023804 .word 0x40023804
08000380 <rcc_clock_setup_hse_3v3>:
/* Return the clock source which is used as system clock. */
return ((RCC_CFGR & 0x000c) >> 2);
void rcc_clock_setup_hse_3v3(const clock_scale_t *clock)
8000380: b510 push {r4, lr}
8000382: 4604 mov r4, r0
/* Enable internal high-speed oscillator. */
rcc_osc_on(HSI);
8000384: 2002 movs r0, #2
8000386: f7ff ff99 bl 80002bc <rcc_osc_on>
rcc_wait_for_osc_ready(HSI);
800038a: 2002 movs r0, #2
800038c: f7ff ff54 bl 8000238 <rcc_wait_for_osc_ready>
/* Select HSI as SYSCLK source. */
rcc_set_sysclk_source(RCC_CFGR_SW_HSI);
8000390: 2000 movs r0, #0
8000392: f7ff ffbd bl 8000310 <rcc_set_sysclk_source>
/* Enable external high-speed oscillator 8MHz. */
rcc_osc_on(HSE);
8000396: 2001 movs r0, #1
8000398: f7ff ff90 bl 80002bc <rcc_osc_on>
rcc_wait_for_osc_ready(HSE);
800039c: 2001 movs r0, #1
800039e: f7ff ff4b bl 8000238 <rcc_wait_for_osc_ready>
/* Enable/disable high performance mode */
if (!clock->power_save)
80003a2: 7be0 ldrb r0, [r4, #15]
80003a4: b100 cbz r0, 80003a8 <rcc_clock_setup_hse_3v3+0x28>
pwr_set_vos_scale(SCALE1);
else
pwr_set_vos_scale(SCALE2);
80003a6: 2001 movs r0, #1
80003a8: f000 f85e bl 8000468 <pwr_set_vos_scale>
* Set prescalers for AHB, ADC, ABP1, ABP2.
* Do this before touching the PLL (TODO: why?).
rcc_set_hpre(clock->hpre);
80003ac: 7b20 ldrb r0, [r4, #12]
80003ae: f7ff ffcd bl 800034c <rcc_set_hpre>
rcc_set_ppre1(clock->ppre1);
80003b2: 7b60 ldrb r0, [r4, #13]
80003b4: f7ff ffc0 bl 8000338 <rcc_set_ppre1>
rcc_set_ppre2(clock->ppre2);
80003b8: 7ba0 ldrb r0, [r4, #14]
80003ba: f7ff ffb3 bl 8000324 <rcc_set_ppre2>
rcc_set_main_pll_hse(clock->pllm, clock->plln,
80003be: 7922 ldrb r2, [r4, #4]
80003c0: 7963 ldrb r3, [r4, #5]
80003c2: 8861 ldrh r1, [r4, #2]
80003c4: 7820 ldrb r0, [r4, #0]
80003c6: f7ff ffcb bl 8000360 <rcc_set_main_pll_hse>
clock->pllp, clock->pllq);
/* Enable PLL oscillator and wait for it to stabilize. */
rcc_osc_on(PLL);
80003ca: 2000 movs r0, #0
80003cc: f7ff ff76 bl 80002bc <rcc_osc_on>
rcc_wait_for_osc_ready(PLL);
80003d0: 2000 movs r0, #0
80003d2: f7ff ff31 bl 8000238 <rcc_wait_for_osc_ready>
/* Configure flash settings. */
flash_set_ws(clock->flash_config);
80003d6: 68a0 ldr r0, [r4, #8]
80003d8: f000 f83c bl 8000454 <flash_set_ws>
/* Select PLL as SYSCLK source. */
rcc_set_sysclk_source(RCC_CFGR_SW_PLL);
80003dc: 2002 movs r0, #2
80003de: f7ff ff97 bl 8000310 <rcc_set_sysclk_source>
/* Wait for PLL clock to be selected. */
rcc_wait_for_sysclk_status(PLL);
80003e2: 2000 movs r0, #0
80003e4: f7ff ff4e bl 8000284 <rcc_wait_for_sysclk_status>
/* Set the peripheral clock frequencies used. */
rcc_ppre1_frequency = clock->apb1_frequency;
80003e8: 6922 ldr r2, [r4, #16]
80003ea: 4b03 ldr r3, [pc, #12] ; (80003f8 <rcc_clock_setup_hse_3v3+0x78>)
80003ec: 601a str r2, [r3, #0]
rcc_ppre2_frequency = clock->apb2_frequency;
80003ee: 6962 ldr r2, [r4, #20]
80003f0: 4b02 ldr r3, [pc, #8] ; (80003fc <rcc_clock_setup_hse_3v3+0x7c>)
80003f2: 601a str r2, [r3, #0]
80003f4: bd10 pop {r4, pc}
80003f6: bf00 nop
80003f8: 20000000 .word 0x20000000
80003fc: 20000004 .word 0x20000004
08000400 <gpio_mode_setup>:
void gpio_mode_setup(u32 gpioport, u8 mode, u8 pull_up_down, u16 gpios)
8000400: e92d 43f0 stmdb sp!, {r4, r5, r6, r7, r8, r9, lr}
* We want to set the config only for the pins mentioned in gpios,
* but keeping the others, so read out the actual config first.
moder = GPIO_MODER(gpioport);
8000404: 6806 ldr r6, [r0, #0]
pupd = GPIO_PUPDR(gpioport);
8000406: 68c5 ldr r5, [r0, #12]
8000408: 2400 movs r4, #0
for (i = 0; i < 16; i++) {
if (!((1 << i) & gpios))
continue;
moder &= ~GPIO_MODE_MASK(i);
800040a: f04f 0803 mov.w r8, #3
800040e: fa53 f704 asrs.w r7, r3, r4
8000412: f017 0f01 tst.w r7, #1
8000416: d00f beq.n 8000438 <gpio_mode_setup+0x38>
* along with this library. If not, see <http://www.gnu.org/licenses/>.
8000418: 0067 lsls r7, r4, #1
continue;
800041a: fa08 fc07 lsl.w ip, r8, r7
800041e: ea6f 0c0c mvn.w ip, ip
moder |= GPIO_MODE(i, mode);
8000422: fa01 f907 lsl.w r9, r1, r7
continue;
8000426: ea0c 0606 and.w r6, ip, r6
pupd &= ~GPIO_PUPD_MASK(i);
800042a: ea0c 0505 and.w r5, ip, r5
pupd |= GPIO_PUPD(i, pull_up_down);
800042e: fa12 f707 lsls.w r7, r2, r7
continue;
8000432: ea46 0609 orr.w r6, r6, r9
8000436: 433d orrs r5, r7
8000438: 3401 adds r4, #1
800043a: 2c10 cmp r4, #16
800043c: d1e7 bne.n 800040e <gpio_mode_setup+0xe>
/* Set mode and pull up/down control registers. */
GPIO_MODER(gpioport) = moder;
800043e: 6006 str r6, [r0, #0]
GPIO_PUPDR(gpioport) = pupd;
8000440: 60c5 str r5, [r0, #12]
8000442: e8bd 83f0 ldmia.w sp!, {r4, r5, r6, r7, r8, r9, pc}
08000446 <gpio_set>:
GPIO_AFRH(gpioport) = afrh;
void gpio_set(u32 gpioport, u16 gpios)
GPIO_BSRR(gpioport) = gpios;
8000446: 6181 str r1, [r0, #24]
8000448: 4770 bx lr
0800044a <gpio_toggle>:
return gpio_port_read(gpioport) & gpios;
void gpio_toggle(u32 gpioport, u16 gpios)
GPIO_ODR(gpioport) ^= gpios;
800044a: 6943 ldr r3, [r0, #20]
800044c: 404b eors r3, r1
800044e: 6143 str r3, [r0, #20]
8000450: 4770 bx lr
08000454 <flash_set_ws>:
void flash_set_ws(u32 ws)
u32 reg32;
reg32 = FLASH_ACR;
8000454: 4b03 ldr r3, [pc, #12] ; (8000464 <flash_set_ws+0x10>)
8000456: 681a ldr r2, [r3, #0]
reg32 &= ~((1 << 0) | (1 << 1) | (1 << 2));
8000458: f022 0207 bic.w r2, r2, #7
reg32 |= ws;
800045c: 4302 orrs r2, r0
FLASH_ACR = reg32;
800045e: 601a str r2, [r3, #0]
8000460: 4770 bx lr
8000462: bf00 nop
8000464: 40023c00 .word 0x40023c00
08000468 <pwr_set_vos_scale>:
#include <libopencm3/stm32/f4/pwr.h>
void pwr_set_vos_scale(vos_scale_t scale)
if (scale == SCALE1)
8000468: b928 cbnz r0, 8000476 <pwr_set_vos_scale+0xe>
PWR_CR |= PWR_CR_VOS;
800046a: 4b07 ldr r3, [pc, #28] ; (8000488 <pwr_set_vos_scale+0x20>)
800046c: 681a ldr r2, [r3, #0]
800046e: f442 4280 orr.w r2, r2, #16384 ; 0x4000
8000472: 601a str r2, [r3, #0]
8000474: 4770 bx lr
else if (scale == SCALE2)
8000476: 2801 cmp r0, #1
8000478: d104 bne.n 8000484 <pwr_set_vos_scale+0x1c>
PWR_CR &= PWR_CR_VOS;
800047a: 4b03 ldr r3, [pc, #12] ; (8000488 <pwr_set_vos_scale+0x20>)
800047c: 681a ldr r2, [r3, #0]
800047e: f402 4280 and.w r2, r2, #16384 ; 0x4000
8000482: 601a str r2, [r3, #0]
8000484: 4770 bx lr
8000486: bf00 nop
8000488: 40007000 .word 0x40007000
0800048c <hse_8mhz_3v3>:
800048c: 00f00008 00000502 00000603 01040500 ................
800049c: 01c9c380 03938700 01500008 00000702 ..........P.....
80004ac: 00000605 00040500 0280de80 0501bd00 ................
