COD MW4 DMZ FOB Tactics by U4GM for Smart Squads
Andrew736
Post napisał: Andrew736 » 02 lip 2026, 10:32
DMZ players will notice the difference the moment they step into the new Forward Operating Base, and Modern Warfare 4 Boosting has already become a talking point for squads trying to keep pace with the new pressure. The place is split between broken industrial shells, heavy fog, and long stretches of near-darkness, so rushing in like it is a normal raid is a fast way to get dropped. You need night vision, patience, and a bit of nerve. Most teams will learn that the hard way.
Dark Routes and Tight Angles
The first thing that stands out is how much the base leans on movement and sound. One bad footstep can pull a whole room onto you. The hallways are narrow, the corners are ugly, and the lighting is just poor enough to make every doorway feel risky. If you go loud too early, the whole run can fall apart. On the other hand, slow play opens up cleaner entries, better flanks, and those quiet melee finishes people love when the lights are barely holding on.
Support That Changes the Pace
The interior is not built for one style of fight. Some rooms reward silence, while others turn into a mess in seconds. That is where the base's support points matter. Fire support can break a push that was getting out of hand, or pin enemies long enough for your squad to move. It is a simple idea, but in practice it keeps a bad situation from snowballing. A lot of players will also lean on the scattered weapon vendors, since they let you patch up a weak loadout without gambling the whole deployment on what you brought in.
What Smart Squads Do First
If you are heading in with a team, the usual mistake is treating every room the same. You should not. A better approach is to clear space, check your angles, and keep one player ready to cover the back. That sounds basic, but it works. Here is the kind of checklist most good squads end up using.
Keep night vision ready before entering the darker sections.
Use quiet movement until you know where the enemy line is.
Hit weapon vendors only when the area is secure.
Save fire support for choke points or when you are pinned.
Use deploy stations to reset gear before pushing deeper.
Holding the Base Long Enough to Matter
The deploy stations tie the whole place together. They are tucked deeper inside, usually where the fighting gets nastiest, and they give squads a chance to reset before the next push. That matters because the base does not stay calm for long. Once one team starts making noise, everyone else starts moving. If you can hold a room, resupply in time, and keep your squad together, the whole zone opens up. Players who handle cheap Modern Warfare 4 Boosting style pressure well will find the Forward Operating Base less about raw firepower and more about staying sharp when the lights go out.
