Ja wykręciłem te króćce, naładowałem uszczelniacza do łączeń hydraulicznych, założyłem obejmę i zostawiłem na 12h. Po czym wkręciłem na miejsce. Od tego momentu zniknął problem cieknięcia....mc2kwacz pisze:umieszczone obok złączy chłodzenia, które potrafią ciec
MEGAPLOT XMD 32 - jakies opinie
- Posty w temacie: 14
Problem
I have an issue with this router.
When I load a new operation with a G-code and center the tool Z position ( I check the reading it's 98,5mm table-tool distance)
Then after the operation is finished if I continue to load operations all the time the Z position goes down 0.1mm after the operation is finished.
Let's say if I start a new G-code with 4 operations , the machines goes 0.1mm everytime and and at the end the last operation is already 0,4mm below the surface.
I started to center the tool after every operation and the reading at the Z position is 98,4 ; 98,3 and so on ..
I have checked the motor shaft to screw shaft coupling. It's tight.
Should I check the NUT - spinndle mount connection ?
Or it's another problem ?
This is the only motor that doesn't have a fan cooling and it's getting really hot.
I wil check the nut , how to check this Z driver ?
[ Dodano: 2015-07-04, 12:08 ]
I think I found the problem ...
When I center the tool and on it's highest position it's above 90mm the limit switch diode isn't lightening and probably this is why it's giving those errors.
After I center it with spindle lowered down and at it's highest position it's bellow 90mm the diode is ON and after one operation it didn't went down with 0,1mm .....
[ Dodano: 2015-07-04, 12:30 ]
No this didn't fixed it the machine went down again.
[ Dodano: 2015-07-04, 19:06 ]
How to check this driver setting ?
Can my error be related with wrong setting for motor/screw/steps ratio in the software ? ( I don't know if I'm explaining it right)
I mean if it's turning 0,999mm on screw instead of 1,000mm and this error is multiplied on every turn ?
On the driver for sets for pulse I have pin 7 ON ( 5000 Pulse/REV).
Can I run this machine with MACH 3 so I can set all values and check if this error appears ? What is your opinion ?
Witam Wszystkich.
Stałem się posiadaczem plotera XMD 32. Trochę się nim pobawiłem i program MegaCut niezbyt przypadł mi do gustu. Zakupiłem więc Macha3 i taką oto płytkę do tego plotera: http://cncprofi.com/plyta-glowna-z-opto ... 0-10v.html
Problem w tym, że nie bardzo umiem to sobie zgrać do kupy. Czy ktoś mógłby mnie poinstruować albo podrzucić jakaś instrukcję?
Ewentualnie czy mogę Machem sterować ploterem wykorzystując wbudowaną płytkę z gniazdem USB?
- Posty w temacie: 45
zapłacę, tylko powiedź kto mi to zrobisyntetyczny pisze:Chce kolega sterowania Mach po usb, no to słyszałem że są takie, ale trzeba zapłacić ekstra za to.
http://www.megaplot.com.pl/matisek932 pisze:Kto ma namiary na firmę która zajmuje się sprzedażą XMD 32 , oczywiście nowe??
