Mam problem z wykonaniem Z probe. Oprogramowanie grbl 1.1h; arduino uno (klon). Sondę podłączyłem do A5 w arduino. Po wpisaniu kodu "G91 G21 G38.2 Z-20 F50" oś Z leciutko drgnie i pojawia się komunikat:
"[PRB:0.000,0.000,0.760:1]
ok"
Co może być przyczyną tego, że oś Z nie przejeżdża zadeklarowanego dystansu 20mm?
Będę ogromnie wdzięczny za pomoc.
Moje ustawienia:
$0 = 10 (Step pulse time, microseconds)
$1 = 25 (Step idle delay, milliseconds)
$2 = 0 (Step pulse invert, mask)
$3 = 1 (Step direction invert, mask)
$4 = 0 (Invert step enable pin, boolean)
$5 = 0 (Invert limit pins, boolean)
$6 = 0 (Invert probe pin, boolean)
$10 = 2 (Status report options, mask)
$11 = 0.010 (Junction deviation, millimeters)
$12 = 0.002 (Arc tolerance, millimeters)
$13 = 0 (Report in inches, boolean)
$20 = 0 (Soft limits enable, boolean)
$21 = 0 (Hard limits enable, boolean)
$22 = 0 (Homing cycle enable, boolean)
$23 = 0 (Homing direction invert, mask)
$24 = 25.000 (Homing locate feed rate, mm/min)
$25 = 500.000 (Homing search seek rate, mm/min)
$26 = 250 (Homing switch debounce delay, milliseconds)
$27 = 1.000 (Homing switch pull-off distance, millimeters)
$30 = 10000 (Maximum spindle speed, RPM)
$31 = 0 (Minimum spindle speed, RPM)
$32 = 0 (Laser-mode enable, boolean)
$100 = 50.000 (X-axis travel resolution, step/mm)
$101 = 50.000 (Y-axis travel resolution, step/mm)
$102 = 200.000 (Z-axis travel resolution, step/mm)
$110 = 5000.000 (X-axis maximum rate, mm/min)
$111 = 5000.000 (Y-axis maximum rate, mm/min)
$112 = 500.000 (Z-axis maximum rate, mm/min)
$120 = 50.000 (X-axis acceleration, mm/sec^2)
$121 = 50.000 (Y-axis acceleration, mm/sec^2)
$122 = 10.000 (Z-axis acceleration, mm/sec^2)
$130 = 350.000 (X-axis maximum travel, millimeters)
$131 = 350.000 (Y-axis maximum travel, millimeters)
$132 = 100.000 (Z-axis maximum travel, millimeters)
Z probe - problemy
tuxcnc
Re: Z probe - problemy
Tradycyjny problem w Arduino, czyli zakłócenia.andrzejn pisze: ↑04 sie 2022, 18:40Witam,
ok"
Przewód od sondy robi za antenę i zbiera wszystkie zakłócenia z okolicy, a wejście jest wystarczająco czułe żeby na nie zareagować.
Pomóc może kondensator (kilka do kilkudziesięciu nF) wpięty pomiędzy wejście i masę.
Są bardziej profesjonalne metody, ale zacznij od kondensatora.
andrzejn
Oczywiście zadziałało! Wstawiłem 47 nF.
Wielkie, wielkie dzięki, tym bardziej, że to już kolejna pomoc, której mi udzieliłeś. Przy mojej wiedzy elektronicznej (a w zasadzie jej braku) w życiu bym na to nie wpadł.
