LinuxCNC nie odpala
snajper007
LinuxCNC nie odpala
Post napisał: snajper007 » 27 cze 2015, 18:48
Po próbach instalacji sterowników karty graficznej ATI, linux nie uruchamiał ekranu logowania. Wyciągnąłem więc kartę graficzną i monitor podpiąłem pod zintegrowaną kartę. Debian uruchomiony, lecz LinuxCNC nie działa. Wywala taki błąd
Kod: Zaznacz cały
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.4
Machine configuration directory is '/home/slawomir/linuxcnc/configs/moja-frezarka'
Machine configuration file is 'moja-frezarka.ini'
INIFILE=/home/slawomir/linuxcnc/configs/moja-frezarka/moja-frezarka.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting TASK program: milltask
Starting DISPLAY program: axis
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=4106
Killing task milltask, PID=4176
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  136 (GLX)
  Minor opcode of failed request:  19 (X_GLXQueryServerString)
  Serial number of failed request:  716
  Current serial number in output stream:  716
4106
  PID TTY      STAT   TIME COMMAND
4176
Stopping realtime threads
Unloading hal components
Kernel message information:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[    0.000000] Disabled fast string operations
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[    0.000000]  BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 000000007f5ffc00 (usable)
[    0.000000]  BIOS-e820: 000000007f5ffc00 - 000000007f601c00 (ACPI NVS)
[    0.000000]  BIOS-e820: 000000007f603c00 - 0000000080000000 (reserved)
[    0.000000]  BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec00000 - 00000000fed00400 (reserved)
[    0.000000]  BIOS-e820: 00000000fed20000 - 00000000feda0000 (reserved)
[    0.000000]  BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[    0.000000]  BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[    0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[    0.000000] SMBIOS 2.3 present.
[    0.000000] DMI: Dell Inc.                 OptiPlex 745                 /0WK833, BIOS 2.3.1  05/21/2007
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[    0.000000] last_pfn = 0x7f5ff max_arch_pfn = 0x100000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-EFFFF uncachable
[    0.000000]   F0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask 000000000 write-back
[    0.000000]   1 base 07F800000 mask FFF800000 uncachable
[    0.000000]   2 base 07F700000 mask FFFF00000 uncachable
[    0.000000]   3 base 080000000 mask F80000000 uncachable
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] e820 update range: 000000007f700000 - 0000000100000000 (usable) ==> (reserved)
[    0.000000] found SMP MP-table at [c00fe710] fe710
[    0.000000] initial memory mapped : 0 - 01800000
[    0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[    0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[    0.000000]  0000000000 - 0000400000 page 4k
[    0.000000]  0000400000 - 0037400000 page 2M
[    0.000000]  0037400000 - 00377fe000 page 4k
[    0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[    0.000000] RAMDISK: 36530000 - 37290000
[    0.000000] ACPI: RSDP 000febf0 00024 (v02 DELL  )
[    0.000000] ACPI: XSDT 000fce99 0006C (v01 DELL    B8K     00000014 ASL  00000061)
[    0.000000] ACPI: FACP 000fcfc1 000F4 (v03 DELL    B8K     00000014 ASL  00000061)
[    0.000000] ACPI: DSDT fff6a119 0473C (v01   DELL    dt_ex 00001000 INTL 20050624)
[    0.000000] ACPI: FACS 7f5ffc00 00040
[    0.000000] ACPI: SSDT fff6e974 000AA (v01   DELL    st_ex 00001000 INTL 20050624)
[    0.000000] ACPI: APIC 000fd0b5 00092 (v01 DELL    B8K     00000014 ASL  00000061)
[    0.000000] ACPI: BOOT 000fd147 00028 (v01 DELL    B8K     00000014 ASL  00000061)
[    0.000000] ACPI: ASF! 000fd16f 00092 (v32 DELL    B8K     00000014 ASL  00000061)
[    0.000000] ACPI: MCFG 000fd201 0003E (v01 DELL    B8K     00000014 ASL  00000061)
[    0.000000] ACPI: HPET 000fd23f 00038 (v01 DELL    B8K     00000014 ASL  00000061)
[    0.000000] ACPI: TCPA 000fd49b 00032 (v01 DELL    B8K     00000014 ASL  00000061)
[    0.000000] ACPI: SLIC 000fd277 00176 (v01 DELL    B8K     00000014 ASL  00000061)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 1150MB HIGHMEM available.
[    0.000000] 887MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 377fe000
[    0.000000]   low ram: 0 - 377fe000
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x000377fe
[    0.000000]   HighMem  0x000377fe -> 0x0007f5ff
[    0.000000] Movable zone start PFN for each node
[    0.000000] Early memory PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009f
[    0.000000]     0: 0x00000100 -> 0x0007f5ff
[    0.000000] On node 0 totalpages: 521614
[    0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5540200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3951 pages, LIFO batch:0
[    0.000000]   Normal zone: 1744 pages used for memmap
[    0.000000]   Normal zone: 221486 pages, LIFO batch:31
[    0.000000]   HighMem zone: 2301 pages used for memmap
[    0.000000]   HighMem zone: 292100 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x05] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x07] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x01] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x02] disabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x03] disabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.000000] SMP: Allowing 8 CPUs, 6 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000f0000
[    0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[    0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:60000000)
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[    0.000000] PERCPU: Embedded 17 pages/cpu @f7769000 s48384 r0 d21248 u69632
[    0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 517537
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=9ea636a7-3166-4c02-ab32-0fc3221125ec ro initrd=/install/initrd.gz lapic quiet rootdelay=5 isolcpus=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] allocated 4173688 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (000377fe:0007f5ff)
[    0.000000] Memory: 2045108k/2086908k available (3495k kernel code, 41348k reserved, 1237k data, 416k init, 1177604k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff17000 - 0xfffff000   ( 928 kB)
[    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    0.000000]     vmalloc : 0xf7ffe000 - 0xff7fe000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf77fe000   ( 887 MB)
[    0.000000]       .init : 0xc14a0000 - 0xc1508000   ( 416 kB)
[    0.000000]       .data : 0xc1369d4a - 0xc149f480   (1237 kB)
[    0.000000]       .text : 0xc1000000 - 0xc1369d4a   (3495 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:2304 nr_irqs:744 16
[    0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000
[    0.000000] Interrupt pipeline (release #3)
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] hpet clockevent registered
[    0.000000] Fast TSC calibration using PIT
[    0.000000] Detected 1594.861 MHz processor.
[    0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 3189.72 BogoMIPS (lpj=6379444)
[    0.004010] pid_max: default: 32768 minimum: 301
[    0.004078] Security Framework initialized
[    0.004083] AppArmor: AppArmor disabled by boot time parameter
[    0.004111] Mount-cache hash table entries: 512
[    0.004445] Initializing cgroup subsys cpuacct
[    0.004450] Initializing cgroup subsys memory
[    0.004464] Initializing cgroup subsys devices
[    0.004467] Initializing cgroup subsys freezer
[    0.004470] Initializing cgroup subsys net_cls
[    0.004473] Initializing cgroup subsys blkio
[    0.004484] Initializing cgroup subsys perf_event
[    0.004522] Disabled fast string operations
[    0.004528] CPU: Physical Processor ID: 0
[    0.004530] CPU: Processor Core ID: 0
[    0.004534] mce: CPU supports 6 MCE banks
[    0.004544] CPU0: Thermal monitoring enabled (TM2)
[    0.004618] ACPI: Core revision 20120320
[    0.135987] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.136372] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.176070] CPU0: Genuine Intel(R) CPU            2140  @ 1.60GHz stepping 02
[    0.180010] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[    0.180010] PEBS disabled due to CPU errata.
[    0.180010] ... version:                2
[    0.180010] ... bit width:              40
[    0.180010] ... generic registers:      2
[    0.180010] ... value mask:             000000ffffffffff
[    0.180010] ... max period:             000000007fffffff
[    0.180010] ... fixed-purpose events:   3
[    0.180010] ... event mask:             0000000700000003
[    0.188487] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.200047] CPU 1 irqstacks, hard=f5114000 soft=f5116000
[    0.200052] Booting Node   0, Processors  #1
[    0.008000] Initializing CPU#1
[    0.008000] Disabled fast string operations
[    0.212056] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.212114] Brought up 2 CPUs
[    0.212118] Total of 2 processors activated (6379.44 BogoMIPS).
[    0.213224] devtmpfs: initialized
[    0.213659] PM: Registering ACPI NVS region [mem 0x7f5ffc00-0x7f601bff] (8192 bytes)
[    0.213681] Dell OptiPlex 745 series board detected. Selecting BIOS-method for reboots.
[    0.213844] dummy:
[    0.213944] NET: Registered protocol family 16
[    0.214207] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.214211] ACPI: bus type pci registered
[    0.214313] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.214318] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.214322] PCI: Using MMCONFIG for extended config space
[    0.214325] PCI: Using configuration type 1 for base access
[    0.216665] bio: create slab <bio-0> at 0
[    0.216817] ACPI: Added _OSI(Module Device)
[    0.216822] ACPI: Added _OSI(Processor Device)
[    0.216826] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.216830] ACPI: Added _OSI(Processor Aggregator Device)
[    0.218376] ACPI: EC: Look up EC in DSDT
[    0.248534] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[    0.270137] ACPI Warning: Incorrect checksum in table [TCPA] - 0x00, should be 0x89 (20120320/tbutils-323)
[    0.270419] ACPI: Interpreter enabled
[    0.270444] ACPI: (supports S0 S1 S3 S4 S5)
[    0.270494] ACPI: Using IOAPIC for interrupt routing
[    0.386287] ACPI: ACPI Dock Station Driver: 1 docks/bays found
[    0.386299] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[    0.394594] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.411072] pci_root PNP0A03:00: host bridge window [io  0x0000-0x0cf7] (ignored)
[    0.411072] pci_root PNP0A03:00: host bridge window [io  0x0d00-0xffff] (ignored)
[    0.411072] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[    0.411072] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff] (ignored)
[    0.411072] pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff] (ignored)
[    0.411072] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xdfffffff] (ignored)
[    0.411072] pci_root PNP0A03:00: host bridge window [mem 0xf0000000-0xfebfffff] (ignored)
[    0.411072] pci_root PNP0A03:00: host bridge window [mem 0xff980800-0xff980bff] (ignored)
[    0.411072] pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff] (ignored)
[    0.411072] pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff] (ignored)
[    0.411072] PCI: root bus 00: using default resources
[    0.411072] PCI host bridge to bus 0000:00
[    0.411072] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.411072] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[    0.411072] pci 0000:00:00.0: [8086:2990] type 00 class 0x060000
[    0.411072] pci 0000:00:01.0: [8086:2991] type 01 class 0x060400
[    0.411072] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.411072] pci 0000:00:02.0: [8086:2992] type 00 class 0x030000
[    0.411072] pci 0000:00:02.0: reg 10: [mem 0xdfe00000-0xdfefffff]
[    0.411072] pci 0000:00:02.0: reg 18: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.411072] pci 0000:00:02.0: reg 20: [io  0xecb8-0xecbf]
[    0.411072] pci 0000:00:02.1: [8086:2993] type 00 class 0x038000
[    0.411072] pci 0000:00:02.1: reg 10: [mem 0xdff00000-0xdfffffff]
[    0.411072] pci 0000:00:1a.0: [8086:2834] type 00 class 0x0c0300
[    0.411072] pci 0000:00:1a.0: reg 20: [io  0xff20-0xff3f]
[    0.411072] pci 0000:00:1a.1: [8086:2835] type 00 class 0x0c0300
[    0.411072] pci 0000:00:1a.1: reg 20: [io  0xff00-0xff1f]
[    0.411072] pci 0000:00:1a.7: [8086:283a] type 00 class 0x0c0320
[    0.411072] pci 0000:00:1a.7: reg 10: [mem 0xdfdffc00-0xdfdfffff]
[    0.412061] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[    0.412092] pci 0000:00:1c.0: [8086:283f] type 01 class 0x060400
[    0.412166] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.412202] pci 0000:00:1c.4: [8086:2847] type 01 class 0x060400
[    0.412275] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.412308] pci 0000:00:1d.0: [8086:2830] type 00 class 0x0c0300
[    0.412359] pci 0000:00:1d.0: reg 20: [io  0xff80-0xff9f]
[    0.412399] pci 0000:00:1d.1: [8086:2831] type 00 class 0x0c0300
[    0.412450] pci 0000:00:1d.1: reg 20: [io  0xff60-0xff7f]
[    0.412491] pci 0000:00:1d.2: [8086:2832] type 00 class 0x0c0300
[    0.412542] pci 0000:00:1d.2: reg 20: [io  0xff40-0xff5f]
[    0.412594] pci 0000:00:1d.7: [8086:2836] type 00 class 0x0c0320
[    0.412618] pci 0000:00:1d.7: reg 10: [mem 0xff980800-0xff980bff]
[    0.412706] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.412734] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.412808] pci 0000:00:1f.0: [8086:2810] type 00 class 0x060100
[    0.412908] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0c00 (mask 007f)
[    0.412913] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 00e0 (mask 0007)
[    0.412959] pci 0000:00:1f.2: [8086:2820] type 00 class 0x01018f
[    0.412978] pci 0000:00:1f.2: reg 10: [io  0xfe00-0xfe07]
[    0.412989] pci 0000:00:1f.2: reg 14: [io  0xfe10-0xfe13]
[    0.413001] pci 0000:00:1f.2: reg 18: [io  0xfe20-0xfe27]
[    0.413012] pci 0000:00:1f.2: reg 1c: [io  0xfe30-0xfe33]
[    0.413024] pci 0000:00:1f.2: reg 20: [io  0xfec0-0xfecf]
[    0.413035] pci 0000:00:1f.2: reg 24: [io  0xecc0-0xeccf]
[    0.413065] pci 0000:00:1f.2: PME# supported from D3hot
[    0.413084] pci 0000:00:1f.3: [8086:283e] type 00 class 0x0c0500
[    0.413100] pci 0000:00:1f.3: reg 10: [mem 0xdfdffb00-0xdfdffbff]
[    0.413137] pci 0000:00:1f.3: reg 20: [io  0xece0-0xecff]
[    0.413180] pci 0000:00:1f.5: [8086:2825] type 00 class 0x010185
[    0.413198] pci 0000:00:1f.5: reg 10: [io  0xfe40-0xfe47]
[    0.413210] pci 0000:00:1f.5: reg 14: [io  0xfe50-0xfe53]
[    0.413221] pci 0000:00:1f.5: reg 18: [io  0xfe60-0xfe67]
[    0.413233] pci 0000:00:1f.5: reg 1c: [io  0xfe70-0xfe73]
[    0.413244] pci 0000:00:1f.5: reg 20: [io  0xfed0-0xfedf]
[    0.413255] pci 0000:00:1f.5: reg 24: [io  0xecd0-0xecdf]
[    0.413286] pci 0000:00:1f.5: PME# supported from D3hot
[    0.413339] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[    0.413346] pci 0000:00:01.0:   bridge window [mem 0xdfc00000-0xdfcfffff]
[    0.413402] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[    0.413411] pci 0000:00:1c.0:   bridge window [mem 0xdfb00000-0xdfbfffff]
[    0.413498] pci 0000:03:00.0: [14e4:167a] type 00 class 0x020000
[    0.413527] pci 0000:03:00.0: reg 10: [mem 0xdfaf0000-0xdfafffff 64bit]
[    0.413646] pci 0000:03:00.0: PME# supported from D3hot D3cold
[    0.420049] pci 0000:00:1c.4: PCI bridge to [bus 03-03]
[    0.420060] pci 0000:00:1c.4:   bridge window [mem 0xdfa00000-0xdfafffff]
[    0.420159] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[    0.420176] pci 0000:00:1e.0:   bridge window [io  0x0000-0xffff] (subtractive decode)
[    0.420182] pci 0000:00:1e.0:   bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[    0.420210] pci_bus 0000:00: on NUMA node 0
[    0.420218] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.421274] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[    0.422065] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[    0.422548] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[    0.422969] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI5._PRT]
[    0.423439]  pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[    1.617107] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[    1.617950] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[    1.618799] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 9 10 11 12 15)
[    1.619631] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[    1.620809] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[    1.621647] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[    1.622489] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[    1.623336] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[    1.623654] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    1.623676] vgaarb: loaded
[    1.623678] vgaarb: bridge control possible 0000:00:02.0
[    1.623740] PCI: Using ACPI for IRQ routing
[    1.631211] PCI: pci_cache_line_size set to 64 bytes
[    1.631312] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[    1.631317] reserve RAM buffer: 000000007f5ffc00 - 000000007fffffff
[    1.631559] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    1.631569] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[    1.633129] Switching to clocksource hpet
[    1.633225] pnp: PnP ACPI init
[    1.633243] ACPI: bus type pnp registered
[    1.640599] pnp 00:00: [bus 00-ff]
[    1.640604] pnp 00:00: [io  0x0cf8-0x0cff]
[    1.640608] pnp 00:00: [io  0x0000-0x0cf7 window]
[    1.640612] pnp 00:00: [io  0x0d00-0xffff window]
[    1.640616] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[    1.640620] pnp 00:00: [mem 0x000c0000-0x000effff window]
[    1.640624] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[    1.640628] pnp 00:00: [mem 0x80000000-0xdfffffff window]
[    1.640632] pnp 00:00: [mem 0xf0000000-0xfebfffff window]
[    1.640636] pnp 00:00: [mem 0xff980800-0xff980bff window]
[    1.640640] pnp 00:00: [mem 0xff97c000-0xff97ffff window]
[    1.640644] pnp 00:00: [mem 0xfed20000-0xfed9ffff window]
[    1.640709] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[    1.645034] pnp 00:01: [io  0x0060]
[    1.645038] pnp 00:01: [io  0x0064]
[    1.645041] pnp 00:01: [io  0x0062-0x0063]
[    1.645045] pnp 00:01: [io  0x0065-0x006f]
[    1.645048] pnp 00:01: [io  0x00e0-0x00ef]
[    1.645052] pnp 00:01: [io  0x0800-0x085f]
[    1.645055] pnp 00:01: [io  0x0c00-0x0c7f]
[    1.645058] pnp 00:01: [io  0x0860-0x08ff]
[    1.645138] system 00:01: [io  0x0800-0x085f] has been reserved
[    1.645143] system 00:01: [io  0x0c00-0x0c7f] has been reserved
[    1.645148] system 00:01: [io  0x0860-0x08ff] has been reserved
[    1.645153] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[    1.645463] pnp 00:02: [io  0x0080-0x009f]
[    1.645467] pnp 00:02: [io  0x0000-0x001f]
[    1.645471] pnp 00:02: [io  0x00c0-0x00df]
[    1.645475] pnp 00:02: [dma 4]
[    1.645520] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[    1.645757] pnp 00:03: [io  0x00f0-0x00ff]
[    1.645770] pnp 00:03: [irq 13]
[    1.645819] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[    1.646046] pnp 00:04: [io  0x0061]
[    1.646093] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[    1.646331] pnp 00:05: [io  0x0070-0x007f]
[    1.646339] pnp 00:05: [irq 8]
[    1.646387] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[    1.662405] pnp 00:06: [io  0x0378-0x037f]
[    1.662409] pnp 00:06: [io  0x0778-0x077f]
[    1.662418] pnp 00:06: [irq 7]
[    1.662422] pnp 00:06: [dma 0 disabled]
[    1.663711] pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active)
[    1.669416] pnp 00:07: [io  0x03f8-0x03ff]
[    1.669425] pnp 00:07: [irq 4]
[    1.669881] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[    1.693478] pnp 00:08: [mem 0x00000000-0x0009ffff]
[    1.693483] pnp 00:08: [mem 0x00100000-0x00ffffff]
[    1.693487] pnp 00:08: [mem 0x01000000-0x7f5ffbff]
[    1.693491] pnp 00:08: [mem 0x000f0000-0x000fffff]
[    1.693494] pnp 00:08: [mem 0x000c0000-0x000cffff]
[    1.693498] pnp 00:08: [mem 0xfec00000-0xfecfffff]
[    1.693502] pnp 00:08: [mem 0xfee00000-0xfeefffff]
[    1.693505] pnp 00:08: [mem 0xffb00000-0xffbfffff]
[    1.693509] pnp 00:08: [mem 0xffc00000-0xffffffff]
[    1.693600] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
[    1.693606] system 00:08: [mem 0x00100000-0x00ffffff] could not be reserved
[    1.693611] system 00:08: [mem 0x01000000-0x7f5ffbff] could not be reserved
[    1.693616] system 00:08: [mem 0x000f0000-0x000fffff] could not be reserved
[    1.693621] system 00:08: [mem 0x000c0000-0x000cffff] could not be reserved
[    1.693626] system 00:08: [mem 0xfec00000-0xfecfffff] could not be reserved
[    1.693631] system 00:08: [mem 0xfee00000-0xfeefffff] has been reserved
[    1.693636] system 00:08: [mem 0xffb00000-0xffbfffff] has been reserved
[    1.693640] system 00:08: [mem 0xffc00000-0xffffffff] has been reserved
[    1.693646] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[    1.696863] pnp 00:09: [mem 0xe0000000-0xefffffff]
[    1.696867] pnp 00:09: [mem 0xfeda0000-0xfedacfff]
[    1.696871] pnp 00:09: [io  0x0100-0x01fe]
[    1.696875] pnp 00:09: [io  0x0200-0x0277]
[    1.696878] pnp 00:09: [io  0x0280-0x02e7]
[    1.696881] pnp 00:09: [io  0x02f0-0x02f7]
[    1.696885] pnp 00:09: [io  0x0300-0x0377]
[    1.696888] pnp 00:09: [io  0x0380-0x03bb]
[    1.696892] pnp 00:09: [io  0x03c0-0x03e7]
[    1.696895] pnp 00:09: [io  0x03f6-0x03f7]
[    1.696899] pnp 00:09: [io  0x0400-0x04cf]
[    1.696902] pnp 00:09: [io  0x04d2-0x057f]
[    1.696905] pnp 00:09: [io  0x0580-0x0677]
[    1.696909] pnp 00:09: [io  0x0680-0x0777]
[    1.696914] pnp 00:09: [io  0x0780-0x07bb]
[    1.696918] pnp 00:09: [io  0x07c0-0x07ff]
[    1.696921] pnp 00:09: [io  0x08e0-0x08ff]
[    1.696925] pnp 00:09: [io  0x0900-0x09fe]
[    1.696928] pnp 00:09: [io  0x0a00-0x0afe]
[    1.696932] pnp 00:09: [io  0x0b00-0x0bfe]
[    1.696936] pnp 00:09: [io  0x0c80-0x0caf]
[    1.696939] pnp 00:09: [io  0x0cc0-0x0cf7]
[    1.696943] pnp 00:09: [io  0x0d00-0x0dfe]
[    1.696946] pnp 00:09: [io  0x0e00-0x0efe]
[    1.696950] pnp 00:09: [io  0x0f00-0x0ffe]
[    1.696953] pnp 00:09: [io  0x2000-0x20fe]
[    1.696957] pnp 00:09: [io  0x2100-0x21fe]
[    1.696960] pnp 00:09: [io  0x2200-0x22fe]
[    1.696964] pnp 00:09: [io  0x2300-0x23fe]
[    1.696967] pnp 00:09: [io  0x2400-0x24fe]
[    1.696971] pnp 00:09: [io  0x2500-0x25fe]
[    1.696974] pnp 00:09: [io  0x2600-0x26fe]
[    1.696978] pnp 00:09: [io  0x2700-0x27fe]
[    1.696981] pnp 00:09: [io  0x2800-0x28fe]
[    1.696985] pnp 00:09: [io  0x2900-0x29fe]
[    1.696988] pnp 00:09: [io  0x2a00-0x2afe]
[    1.696992] pnp 00:09: [io  0x2b00-0x2bfe]
[    1.696995] pnp 00:09: [io  0x2c00-0x2cfe]
[    1.696999] pnp 00:09: [io  0x2d00-0x2dfe]
[    1.697002] pnp 00:09: [io  0x2e00-0x2efe]
[    1.697006] pnp 00:09: [io  0x2f00-0x2ffe]
[    1.697010] pnp 00:09: [io  0x5000-0x50fe]
[    1.697013] pnp 00:09: [io  0x5100-0x51fe]
[    1.697017] pnp 00:09: [io  0x5200-0x52fe]
[    1.697020] pnp 00:09: [io  0x5300-0x53fe]
[    1.697024] pnp 00:09: [io  0x5400-0x54fe]
[    1.697027] pnp 00:09: [io  0x5500-0x55fe]
[    1.697031] pnp 00:09: [io  0x5600-0x56fe]
[    1.697034] pnp 00:09: [io  0x5700-0x57fe]
[    1.697038] pnp 00:09: [io  0x5800-0x58fe]
[    1.697041] pnp 00:09: [io  0x5900-0x59fe]
[    1.697045] pnp 00:09: [io  0x5a00-0x5afe]
[    1.697048] pnp 00:09: [io  0x5b00-0x5bfe]
[    1.697052] pnp 00:09: [io  0x5c00-0x5cfe]
[    1.697055] pnp 00:09: [io  0x5d00-0x5dfe]
[    1.697059] pnp 00:09: [io  0x5e00-0x5efe]
[    1.697062] pnp 00:09: [io  0x5f00-0x5ffe]
[    1.697066] pnp 00:09: [io  0x6000-0x60fe]
[    1.697069] pnp 00:09: [io  0x6100-0x61fe]
[    1.697073] pnp 00:09: [io  0x6200-0x62fe]
[    1.697077] pnp 00:09: [io  0x6300-0x63fe]
[    1.697080] pnp 00:09: [io  0x6400-0x64fe]
[    1.697084] pnp 00:09: [io  0x6500-0x65fe]
[    1.697087] pnp 00:09: [io  0x6600-0x66fe]
[    1.697091] pnp 00:09: [io  0x6700-0x67fe]
[    1.697094] pnp 00:09: [io  0x6800-0x68fe]
[    1.697098] pnp 00:09: [io  0x6900-0x69fe]
[    1.697101] pnp 00:09: [io  0x6a00-0x6afe]
[    1.697105] pnp 00:09: [io  0x6b00-0x6bfe]
[    1.697108] pnp 00:09: [io  0x6c00-0x6cfe]
[    1.697112] pnp 00:09: [io  0x6d00-0x6dfe]
[    1.697115] pnp 00:09: [io  0x6e00-0x6efe]
[    1.697119] pnp 00:09: [io  0x6f00-0x6ffe]
[    1.697124] pnp 00:09: [io  0xa000-0xa0fe]
[    1.697128] pnp 00:09: [io  0xa100-0xa1fe]
[    1.697131] pnp 00:09: [io  0xa200-0xa2fe]
[    1.697135] pnp 00:09: [io  0xa300-0xa3fe]
[    1.697139] pnp 00:09: [io  0xa400-0xa4fe]
[    1.697142] pnp 00:09: [io  0xa500-0xa5fe]
[    1.697146] pnp 00:09: [io  0xa600-0xa6fe]
[    1.697149] pnp 00:09: [io  0xa700-0xa7fe]
[    1.697153] pnp 00:09: [io  0xa800-0xa8fe]
[    1.697156] pnp 00:09: [io  0xa900-0xa9fe]
[    1.697160] pnp 00:09: [io  0xaa00-0xaafe]
[    1.697163] pnp 00:09: [io  0xab00-0xabfe]
[    1.697167] pnp 00:09: [io  0xac00-0xacfe]
[    1.697170] pnp 00:09: [io  0xad00-0xadfe]
[    1.697174] pnp 00:09: [io  0xae00-0xaefe]
[    1.697177] pnp 00:09: [io  0xaf00-0xaffe]
[    1.697494] system 00:09: [io  0x0100-0x01fe] has been reserved
[    1.697499] system 00:09: [io  0x0200-0x0277] has been reserved
[    1.697504] system 00:09: [io  0x0280-0x02e7] has been reserved
[    1.697508] system 00:09: [io  0x02f0-0x02f7] has been reserved
[    1.697513] system 00:09: [io  0x0300-0x0377] has been reserved
[    1.697517] system 00:09: [io  0x0380-0x03bb] has been reserved
[    1.697522] system 00:09: [io  0x03c0-0x03e7] could not be reserved
[    1.697526] system 00:09: [io  0x03f6-0x03f7] has been reserved
[    1.697531] system 00:09: [io  0x0400-0x04cf] has been reserved
[    1.697535] system 00:09: [io  0x04d2-0x057f] has been reserved
[    1.697539] system 00:09: [io  0x0580-0x0677] has been reserved
[    1.697544] system 00:09: [io  0x0680-0x0777] has been reserved
[    1.697548] system 00:09: [io  0x0780-0x07bb] has been reserved
[    1.697553] system 00:09: [io  0x07c0-0x07ff] has been reserved
[    1.697557] system 00:09: [io  0x08e0-0x08ff] has been reserved
[    1.697562] system 00:09: [io  0x0900-0x09fe] has been reserved
[    1.697566] system 00:09: [io  0x0a00-0x0afe] has been reserved
[    1.697570] system 00:09: [io  0x0b00-0x0bfe] has been reserved
[    1.697575] system 00:09: [io  0x0c80-0x0caf] has been reserved
[    1.697579] system 00:09: [io  0x0cc0-0x0cf7] has been reserved
[    1.697584] system 00:09: [io  0x0d00-0x0dfe] has been reserved
[    1.697588] system 00:09: [io  0x0e00-0x0efe] has been reserved
[    1.697593] system 00:09: [io  0x0f00-0x0ffe] has been reserved
[    1.697597] system 00:09: [io  0x2000-0x20fe] has been reserved
[    1.697602] system 00:09: [io  0x2100-0x21fe] has been reserved
[    1.697606] system 00:09: [io  0x2200-0x22fe] has been reserved
[    1.697611] system 00:09: [io  0x2300-0x23fe] has been reserved
[    1.697615] system 00:09: [io  0x2400-0x24fe] has been reserved
[    1.697620] system 00:09: [io  0x2500-0x25fe] has been reserved
[    1.697624] system 00:09: [io  0x2600-0x26fe] has been reserved
[    1.697630] system 00:09: [io  0x2700-0x27fe] has been reserved
[    1.697634] system 00:09: [io  0x2800-0x28fe] has been reserved
[    1.697639] system 00:09: [io  0x2900-0x29fe] has been reserved
[    1.697644] system 00:09: [io  0x2a00-0x2afe] has been reserved
[    1.697648] system 00:09: [io  0x2b00-0x2bfe] has been reserved
[    1.697653] system 00:09: [io  0x2c00-0x2cfe] has been reserved
[    1.697657] system 00:09: [io  0x2d00-0x2dfe] has been reserved
[    1.697662] system 00:09: [io  0x2e00-0x2efe] has been reserved
[    1.697666] system 00:09: [io  0x2f00-0x2ffe] has been reserved
[    1.697671] system 00:09: [io  0x5000-0x50fe] has been reserved
[    1.697675] system 00:09: [io  0x5100-0x51fe] has been reserved
[    1.697680] system 00:09: [io  0x5200-0x52fe] has been reserved
[    1.697685] system 00:09: [io  0x5300-0x53fe] has been reserved
[    1.697689] system 00:09: [io  0x5400-0x54fe] has been reserved
[    1.697694] system 00:09: [io  0x5500-0x55fe] has been reserved
[    1.697698] system 00:09: [io  0x5600-0x56fe] has been reserved
[    1.697703] system 00:09: [io  0x5700-0x57fe] has been reserved
[    1.697708] system 00:09: [io  0x5800-0x58fe] has been reserved
[    1.697712] system 00:09: [io  0x5900-0x59fe] has been reserved
[    1.697717] system 00:09: [io  0x5a00-0x5afe] has been reserved
[    1.697722] system 00:09: [io  0x5b00-0x5bfe] has been reserved
[    1.697727] system 00:09: [io  0x5c00-0x5cfe] has been reserved
[    1.697731] system 00:09: [io  0x5d00-0x5dfe] has been reserved
[    1.697736] system 00:09: [io  0x5e00-0x5efe] has been reserved
[    1.697740] system 00:09: [io  0x5f00-0x5ffe] has been reserved
[    1.697745] system 00:09: [io  0x6000-0x60fe] has been reserved
[    1.697752] system 00:09: [io  0x6100-0x61fe] has been reserved
[    1.697756] system 00:09: [io  0x6200-0x62fe] has been reserved
[    1.697761] system 00:09: [io  0x6300-0x63fe] has been reserved
[    1.697766] system 00:09: [io  0x6400-0x64fe] has been reserved
[    1.697771] system 00:09: [io  0x6500-0x65fe] has been reserved
[    1.697775] system 00:09: [io  0x6600-0x66fe] has been reserved
[    1.697780] system 00:09: [io  0x6700-0x67fe] has been reserved
[    1.697785] system 00:09: [io  0x6800-0x68fe] has been reserved
[    1.697790] system 00:09: [io  0x6900-0x69fe] has been reserved
[    1.697794] system 00:09: [io  0x6a00-0x6afe] has been reserved
[    1.697799] system 00:09: [io  0x6b00-0x6bfe] has been reserved
[    1.697804] system 00:09: [io  0x6c00-0x6cfe] has been reserved
[    1.697808] system 00:09: [io  0x6d00-0x6dfe] has been reserved
[    1.697813] system 00:09: [io  0x6e00-0x6efe] has been reserved
[    1.697818] system 00:09: [io  0x6f00-0x6ffe] has been reserved
[    1.697823] system 00:09: [io  0xa000-0xa0fe] has been reserved
[    1.697827] system 00:09: [io  0xa100-0xa1fe] has been reserved
[    1.697832] system 00:09: [io  0xa200-0xa2fe] has been reserved
[    1.697837] system 00:09: [io  0xa300-0xa3fe] has been reserved
[    1.697842] system 00:09: [io  0xa400-0xa4fe] has been reserved
[    1.697846] system 00:09: [io  0xa500-0xa5fe] has been reserved
[    1.697851] system 00:09: [io  0xa600-0xa6fe] has been reserved
[    1.697856] system 00:09: [io  0xa700-0xa7fe] has been reserved
[    1.697861] system 00:09: [io  0xa800-0xa8fe] has been reserved
[    1.697865] system 00:09: [io  0xa900-0xa9fe] has been reserved
[    1.697870] system 00:09: [io  0xaa00-0xaafe] has been reserved
[    1.697875] system 00:09: [io  0xab00-0xabfe] has been reserved
[    1.697880] system 00:09: [io  0xac00-0xacfe] has been reserved
[    1.697885] system 00:09: [io  0xad00-0xadfe] has been reserved
[    1.697890] system 00:09: [io  0xae00-0xaefe] has been reserved
[    1.697895] system 00:09: [io  0xaf00-0xaffe] has been reserved
[    1.697900] system 00:09: [mem 0xe0000000-0xefffffff] has been reserved
[    1.697905] system 00:09: [mem 0xfeda0000-0xfedacfff] has been reserved
[    1.697911] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    1.698152] pnp 00:0a: [mem 0xfed00000-0xfed003ff]
[    1.698213] pnp 00:0a: Plug and Play ACPI device, IDs PNP0103 (active)
[    1.698224] pnp: PnP ACPI: found 11 devices
[    1.698227] ACPI: ACPI bus type pnp unregistered
[    1.698232] PnPBIOS: Disabled by ACPI PNP
[    1.735570] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 02-02] add_size 1000
[    1.735577] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[    1.735590] pci 0000:00:1c.4: bridge window [io  0x1000-0x0fff] to [bus 03-03] add_size 1000
[    1.735596] pci 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[    1.735614] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[    1.735619] pci 0000:00:1c.4: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[    1.735624] pci 0000:00:1c.0: res[13]=[io  0x1000-0x0fff] get_res_add_size add_size 1000
[    1.735628] pci 0000:00:1c.4: res[13]=[io  0x1000-0x0fff] get_res_add_size add_size 1000
[    1.735635] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80000000-0x801fffff 64bit pref]
[    1.735641] pci 0000:00:1c.4: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[    1.735646] pci 0000:00:1c.0: BAR 13: assigned [io  0x1000-0x1fff]
[    1.735652] pci 0000:00:1c.4: BAR 13: assigned [io  0x3000-0x3fff]
[    1.735658] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[    1.735664] pci 0000:00:01.0:   bridge window [mem 0xdfc00000-0xdfcfffff]
[    1.735673] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[    1.735678] pci 0000:00:1c.0:   bridge window [io  0x1000-0x1fff]
[    1.735685] pci 0000:00:1c.0:   bridge window [mem 0xdfb00000-0xdfbfffff]
[    1.735691] pci 0000:00:1c.0:   bridge window [mem 0x80000000-0x801fffff 64bit pref]
[    1.735700] pci 0000:00:1c.4: PCI bridge to [bus 03-03]
[    1.735704] pci 0000:00:1c.4:   bridge window [io  0x3000-0x3fff]
[    1.735711] pci 0000:00:1c.4:   bridge window [mem 0xdfa00000-0xdfafffff]
[    1.735718] pci 0000:00:1c.4:   bridge window [mem 0x80200000-0x803fffff 64bit pref]
[    1.735726] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[    1.735779] pci 0000:00:1e.0: setting latency timer to 64
[    1.735785] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    1.735789] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[    1.735794] pci_bus 0000:01: resource 1 [mem 0xdfc00000-0xdfcfffff]
[    1.735798] pci_bus 0000:02: resource 0 [io  0x1000-0x1fff]
[    1.735801] pci_bus 0000:02: resource 1 [mem 0xdfb00000-0xdfbfffff]
[    1.735806] pci_bus 0000:02: resource 2 [mem 0x80000000-0x801fffff 64bit pref]
[    1.735810] pci_bus 0000:03: resource 0 [io  0x3000-0x3fff]
[    1.735813] pci_bus 0000:03: resource 1 [mem 0xdfa00000-0xdfafffff]
[    1.735817] pci_bus 0000:03: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[    1.735821] pci_bus 0000:04: resource 4 [io  0x0000-0xffff]
[    1.735825] pci_bus 0000:04: resource 5 [mem 0x00000000-0xffffffff]
[    1.735945] NET: Registered protocol family 2
[    1.736072] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    1.736411] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    1.736925] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    1.737255] TCP: Hash tables configured (established 131072 bind 65536)
[    1.737259] TCP: reno registered
[    1.737265] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.737279] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.737477] NET: Registered protocol family 1
[    1.737507] pci 0000:00:02.0: Boot video device
[    1.737771] PCI: CLS 64 bytes, default 64
[    1.737845] Unpacking initramfs...
[    2.151019] Freeing initrd memory: 13696k freed
[    2.160878] Simple Boot Flag at 0x7a set to 0x1
[    2.161524] audit: initializing netlink socket (disabled)
[    2.161543] type=2000 audit(1435422687.156:1): initialized
[    2.178434] highmem bounce pool size: 64 pages
[    2.178441] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    2.178699] VFS: Disk quotas dquot_6.5.2
[    2.178741] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.178857] msgmni has been set to 1721
[    2.179077] alg: No test for stdrng (krng)
[    2.179118] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    2.179123] io scheduler noop registered
[    2.179126] io scheduler deadline registered
[    2.179155] io scheduler cfq registered (default)
[    2.179507] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    2.179542] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    2.179546] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    2.180429] GHES: HEST is not enabled!
[    2.180449] isapnp: Scanning for PnP cards...
[    2.533528] isapnp: No Plug & Play device found
[    2.533596] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.553997] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    2.574767] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    2.575253] Linux agpgart interface v0.103
[    2.575424] agpgart-intel 0000:00:00.0: Intel 965Q Chipset
[    2.575520] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[    2.575882] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[    2.576036] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xc0000000
[    2.576267] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    2.579168] serio: i8042 KBD port at 0x60,0x64 irq 1
[    2.579220] serio: i8042 AUX port at 0x60,0x64 irq 12
[    2.579360] mousedev: PS/2 mouse device common for all mice
[    2.579436] rtc_cmos 00:05: RTC can wake from S4
[    2.579582] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[    2.579610] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[    2.579813] TCP: cubic registered
[    2.579896] NET: Registered protocol family 10
[    2.580279] Mobile IPv6
[    2.580284] NET: Registered protocol family 17
[    2.580291] Registering the dns_resolver key type
[    2.580383] Using IPI No-Shortcut mode
[    2.580519] PM: Hibernation image not present or could not be loaded.
[    2.580536] registered taskstats version 1
[    2.580991] rtc_cmos 00:05: setting system clock to 2015-06-27 16:31:28 UTC (1435422688)
[    2.581121] Freeing unused kernel memory: 416k freed
[    2.581411] Write protecting the kernel text: 3496k
[    2.581447] Write protecting the kernel read-only data: 984k
[    2.608280] udevd[49]: starting version 175
[    2.683854] usbcore: registered new interface driver usbfs
[    2.683891] usbcore: registered new interface driver hub
[    2.687296] SCSI subsystem initialized
[    2.769432] tg3.c:v3.123 (March 21, 2012)
[    2.771409] usbcore: registered new device driver usb
[    2.772537] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.772633] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[    2.772639] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[    2.772678] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[    2.772718] ehci_hcd 0000:00:1a.7: debug port 1
[    2.776337] libata version 3.00 loaded.
[    2.783441] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[    2.783476] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xdfdffc00
[    2.792039] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    2.792101] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.792105] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.792110] usb usb1: Product: EHCI Host Controller
[    2.792113] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    2.792117] usb usb1: SerialNumber: 0000:00:1a.7
[    2.792306] hub 1-0:1.0: USB hub found
[    2.792314] hub 1-0:1.0: 4 ports detected
[    2.792455] ata_piix 0000:00:1f.2: version 2.13
[    2.792491] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    2.801624] tg3 0000:03:00.0: eth0: Tigon3 [partno(BCM95754) rev b002] (PCI Express) MAC address 00:1a:a0:5d:35:34
[    2.801631] tg3 0000:03:00.0: eth0: attached PHY is 5787 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[    2.801636] tg3 0000:03:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[    2.801641] tg3 0000:03:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[    2.805615] microcode: CPU0 sig=0x6f2, pf=0x1, revision=0x56
[    2.808982] uhci_hcd: USB Universal Host Controller Interface driver
[    2.847837] microcode: CPU0 updated to revision 0x5d, date = 2010-10-02
[    2.847857] microcode: CPU1 sig=0x6f2, pf=0x1, revision=0x56
[    2.853103] microcode: CPU1 updated to revision 0x5d, date = 2010-10-02
[    2.853489] microcode: Microcode Update Driver: v2.00 <[email protected]>, Peter Oruba
[    2.948090] ata_piix 0000:00:1f.2: setting latency timer to 64
[    2.948852] scsi0 : ata_piix
[    2.949077] scsi1 : ata_piix
[    2.954458] ata1: SATA max UDMA/133 cmd 0xfe00 ctl 0xfe10 bmdma 0xfec0 irq 20
[    2.954466] ata2: SATA max UDMA/133 cmd 0xfe20 ctl 0xfe30 bmdma 0xfec8 irq 20
[    2.954588] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[    2.954594] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[    2.954614] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    2.954651] ehci_hcd 0000:00:1d.7: debug port 1
[    2.958545] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[    2.958571] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xff980800
[    2.968040] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    2.968086] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.968092] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.968097] usb usb2: Product: EHCI Host Controller
[    2.968102] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    2.968107] usb usb2: SerialNumber: 0000:00:1d.7
[    2.968449] hub 2-0:1.0: USB hub found
[    2.968458] hub 2-0:1.0: 6 ports detected
[    2.968610] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[    2.968615] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[    2.968629] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    2.968677] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[    2.968730] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.968734] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.968738] usb usb3: Product: UHCI Host Controller
[    2.968742] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[    2.968745] usb usb3: SerialNumber: 0000:00:1a.0
[    2.968910] hub 3-0:1.0: USB hub found
[    2.968919] hub 3-0:1.0: 2 ports detected
[    2.969049] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[    2.969055] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[    2.969066] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    2.969109] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[    2.969162] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    2.969166] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.969170] usb usb4: Product: UHCI Host Controller
[    2.969173] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[    2.969177] usb usb4: SerialNumber: 0000:00:1a.1
[    2.969340] hub 4-0:1.0: USB hub found
[    2.969348] hub 4-0:1.0: 2 ports detected
[    2.969470] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[    2.969475] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    2.969487] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[    2.969515] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[    2.969567] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    2.969571] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.969575] usb usb5: Product: UHCI Host Controller
[    2.969579] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[    2.969582] usb usb5: SerialNumber: 0000:00:1d.0
[    2.970840] hub 5-0:1.0: USB hub found
[    2.970852] hub 5-0:1.0: 2 ports detected
[    2.970984] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[    2.970989] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    2.971002] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[    2.971032] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[    2.971086] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    2.971091] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.971095] usb usb6: Product: UHCI Host Controller
[    2.971098] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[    2.971102] usb usb6: SerialNumber: 0000:00:1d.1
[    2.972352] hub 6-0:1.0: USB hub found
[    2.972361] hub 6-0:1.0: 2 ports detected
[    2.972497] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[    2.972502] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    2.972519] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[    2.972568] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[    2.972623] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    2.972628&
jarenio
Post napisał: jarenio » 29 cze 2015, 09:16
Pozdrawiam; Jarek
