Fusion 360 gwintowanie Linuxcnc
Pafełek
Post napisał: Pafełek » 03 kwie 2020, 15:01
Cześć
Mam mały problem może ktoś pomoże.
Zrobiłem w Fusion 360 pewien model z gwintem zewnętrznym m8 i chciałbym wygenerować kod i spróbować nagwintować ale mam taki problem . Postprocesor jest raczej dobry,oprócz gwintowania nie miałem problemu na razie.
Information: Configuration: LinuxCNC Turning
Information: Vendor: LinuxCNC
Information: Posting intermediate data to 'C:\Users\pawel_000\Desktop\3.ngc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1250 (ANSI - Europa Úšrodkowa)'
Start time: Friday, April 3, 2020 1:01:07 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5633.2
Configuration path: C:\Users\pawel_000\AppData\Local\Autodesk\webdeploy\production\c23c4c7ff2652eaacfec153295bbc3d6e4b9657f\Applications\CAM360\Data\Posts\linuxcnc turning.cps
Include paths: C:\Users\pawel_000\AppData\Local\Autodesk\webdeploy\production\c23c4c7ff2652eaacfec153295bbc3d6e4b9657f\Applications\CAM360\Data\Posts
Configuration modification date: Friday, February 7, 2020 11:35:11 AM
Output path: C:\Users\pawel_000\Desktop\3.ngc
Checksum of intermediate NC data: c28bb6c5627ddbaa30993123e7accd88
Checksum of configuration: f65ed9765ca6cd8e1742ff4a2df92112
Vendor url: http://www.linuxcnc.org
Legal: Copyright (C) 2012-2018 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.7813
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Threading not supported using synchronization of feed-spindle.
Error at line: 757
Error in operation: 'Thread2'
Failed while processing onLinear() for record 346.
Error: Failed to execute configuration.
Stop time: Friday, April 3, 2020 1:01:07 PM
Post processing failed.
TOP67
Re: Fusion 360 gwintowanie Linuxcnc
Post napisał: TOP67 » 03 kwie 2020, 15:11
A maszyna pozwala na gwintowanie?
Masz enkoder na wrzecionie?
Pafełek
Post napisał: Pafełek » 03 kwie 2020, 15:33
Tak mam bo np narzynką mogę nagwintować. Ten komunikat wyrzuca jeszcze Fusion360
TOP67
Post napisał: TOP67 » 03 kwie 2020, 15:39
Czyli postprocesor nie ma informacji o tym, że może gwintować.
Pafełek
Post napisał: Pafełek » 03 kwie 2020, 15:49
TOP67 pisze:
03 kwie 2020, 15:39
Co kolega ma na myśli bo zielony jestem ?
TOP67
Post napisał: TOP67 » 03 kwie 2020, 15:52
Postprocesor to tylko zbiór informacji o tym co potrafi maszyna i jej sterowanie. Jakie obsługuje kody i cykle. Jak nie będzie tam informacji o możliwości gwintowania, to nie wygeneruje się kod.
Przy samym PostProcess jest też kilka ptaszków do zaznaczenia.
Pafełek
Post napisał: Pafełek » 03 kwie 2020, 15:57
Może kolega zerknąć ? Przesłałem załącznik
post do fusion.cps.txt
(40.55 KiB) Pobrany 155 razy
Post napisał: kamar » 03 kwie 2020, 16:17
Oczywiście NGCGUI kolega nie ma zainstalowanego. Nie było by tematu.
Mści się w przekonanie .że nic nie potrzebuję, wszystko zrobię Camem.
O ile wiem to w Fusionie nie ma "fabrycznego" pp na tokarkę do linuxCNC a jak ktoś coś przerabiał to pewnie olał
gwintowanie jako nieprzydatne albo przerabiał z frezarki.
Pafełek
Post napisał: Pafełek » 03 kwie 2020, 16:43
kamar pisze:
03 kwie 2020, 16:17
Oczywiście mam dzięki koledze Adamowi :-) I nawet przed chwilą zrobiłem swój pierwszy gwint na cnc :-) Na razie wyszedł marny w nierdzewce bo strasznie chropowaty.Chciałem po prostu wiedzieć co jest nie tak z Fusion i dlaczego nie generuje mi tego kodu(byłoby mi też w ten sposób wygodniej )
Post napisał: kamar » 03 kwie 2020, 17:27
Pafełek pisze:
03 kwie 2020, 16:43
To nie będzie bo Fusion nie oferuje gwintowania :)
