I thought it maybe was something else wrong with the spare drives, so I put back the "original" drives, but still get this error - so I suspect there might be something that needs to be "reset" or reloaded?
Any tips would be appreciated - the spindle drive I'v moved the programming unit over between the units, as the spare drive was setup for a different motor.
Was still no joy with the spindle on the spare drive either so any tips that might cause this behaviour is also appreciated (the spindle drives gives me N * NCMD "error code" when I try to run the spindle).
The unit is a Heidenhain 407
