SANYO new chips---THB6128,THB7128,THB8128
lihaijiang
Post napisał: lihaijiang » 09 kwie 2012, 09:27
THB6128
*1 channel PWM current control stepping motor driver
*BiCDMOS process IC
*Output on-resistance ( High side 0.3 Ω, Low side 0.25 Ω, Total 0.55 Ω; Ta = 25°C, Io = 2.0 A)
*2, 1-2, W1-2, 2W1-2, 4W1-2, 8W1-2, 16W1-2, 32W1-2 phase excitation are selectable
*Advance the excitation step with the only step signal input
*Available forward reverse control
*Iomax=2.2A
*Over current protection circuit
*Thermal shutdown circuit
*Input pull down resistance
*With reset pin and enable pin
Absolute Maximum Ratings at Ta = 25° C
*Operating temperature(Topg): -20 to 85 ° C
*Storage temperature(Tstg): -55 to +150 ° C
*Package: MFP30KR
*Dimentions: 1.52*0.79*0.025cm
*Weight: 0.6g
THB7128
*PWM current control stepping motor driver
*Output on-resistance (High side 0.3ohm, Low side 0.25ohm, Total 0.55ohm; Ta = 25℃, Io = 2.5A)
*VMmax=40V(DC),Iopmax=3.3A
*With built-in automatic half current maintenance energizing function
*Operating temperature(Topg): -20 to 105 ° C
*Storage temperature (Tstg): -40 to +125 ° C
*Package: HZIP25
*Dimentions: 2.92*1.29*0.45cm
*Weight: 3g
THB8128
*BiCDMOS process IC
*Output on-resistance( High side 0.25 Ω, Low side 0.15 Ω, Total 0.40 Ω; Ta = 25°C, Io = 4.0 A)
*Selectable phase drive (1/2, 1/8, 1/16,1/32, 1/64,1/128, 1/10,1/20step)
*Iomax =4.3A
*Operating temperature(Topg): -30 to 85 ° C
*Storage temperature (Tstg): -55 to +150 ° C
*Package: HZIP25
*Weight: 6g
Anoncement about THB series chips by SANYO semiconductor(H.K.) Co.,Ltd.jpg (43.38 KiB) Przejrzano 1483 razy
lihaijiang
poorchava
Post napisał: poorchava » 10 kwie 2012, 15:10
Is there some modern solution from Toshiba featuring external MOSFETS? 0.3R/0.25R of on-resistance might be good for integrated power stage, but in discrete MOSFETs it's state of technology from 15yrs ago. Discrete mosfets would allow much higher power throughoutput and lower heat losses.
A chip allowing for usage of N-MOSFETs in both high- and low-side with all the gate drive circuitry would be very nice. something similar to Allegro Micro A4989
LINK
