Makerbase MKS DLC V2.0
Post napisał: tuxcnc » 20 sie 2021, 16:25
Dzisiaj dotarła do mnie płytka z aukcji https://www.aliexpress.com/item/1005002281056702.html
GRBL używam od dawna i mam więcej sterowników niż sterowanych maszyn, ale jak zobaczyłem kompletny sterownik za tak śmieszne pieniądze, to kupiłem żeby przetestować.
Na razie zgrałem oryginalny firmware (potrzebny programator, np. USBasp) i wykonałem testowe połączenie z komputerem.
Kod: Zaznacz cały
**** Connected to ttyUSB0 @ 115200 baud ****
Grbl 1.1f ['$' for help]
$0 = 10    (Step pulse time, microseconds)
$1 = 25    (Step idle delay, milliseconds)
$2 = 0    (Step pulse invert, mask)
$3 = 3    (Step direction invert, mask)
$4 = 0    (Invert step enable pin, boolean)
$5 = 0    (Invert limit pins, boolean)
$6 = 0    (Invert probe pin, boolean)
$10 = 1    (Status report options, mask)
$11 = 0.010    (Junction deviation, millimeters)
$12 = 0.002    (Arc tolerance, millimeters)
$13 = 0    (Report in inches, boolean)
$20 = 0    (Soft limits enable, boolean)
$21 = 0    (Hard limits enable, boolean)
$22 = 0    (Homing cycle enable, boolean)
$23 = 0    (Homing direction invert, mask)
$24 = 300.000    (Homing locate feed rate, mm/min)
$25 = 500.000    (Homing search seek rate, mm/min)
$26 = 250    (Homing switch debounce delay, milliseconds)
$27 = 1.000    (Homing switch pull-off distance, millimeters)
$30 = 10000    (Maximum spindle speed, RPM)
$31 = 0    (Minimum spindle speed, RPM)
$32 = 0    (Laser-mode enable, boolean)
$100 = 80.000    (X-axis travel resolution, step/mm)
$101 = 80.000    (Y-axis travel resolution, step/mm)
$102 = 100.000    (Z-axis travel resolution, step/mm)
$110 = 3000.000    (X-axis maximum rate, mm/min)
$111 = 3000.000    (Y-axis maximum rate, mm/min)
$112 = 3000.000    (Z-axis maximum rate, mm/min)
$120 = 100.000    (X-axis acceleration, mm/sec^2)
$121 = 100.000    (Y-axis acceleration, mm/sec^2)
$122 = 10.000    (Z-axis acceleration, mm/sec^2)
$130 = 200.000    (X-axis maximum travel, millimeters)
$131 = 200.000    (Y-axis maximum travel, millimeters)
$132 = 200.000    (Z-axis maximum travel, millimeters)
ok
>>> $G
[GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]
ok
>>> $X
ok
>>> $H
[Error] An error was detected while sending '$H': (error:5) Homing cycle failure. Homing is not enabled via settings. Streaming has been paused.
[Error] Error while processing response <An error was detected while sending '$H': (error:5) Homing cycle failure. Homing is not enabled via settings. Streaming has been paused.>
>>> $X
ok
**** Connection closed ****
Wygląda na standardową kompilację i domyślne ustawienia.
Podłączyłem też Makerbase MKS TFT-35 (oczywiście kupiony osobno), działa, lub jak kto woli nie działa, dokładnie tak jak to opisałem w innym wątku, czyli przede wszystkim przy ruchach ręcznych potrafi po jednym dotknięciu pojechać dwa kroki. Reszta działa jak się można spodziewać i da się od biedy używać.
Do fizycznej maszyny jeszcze nie podłączałem, bo mi się najzwyczajniej nie chce.
mks-dlc-factory.tar
(40 KiB) Pobrany 147 razy
Wróć do „Elektronika CNC”
