Prosty sposób na rysowanie perspektywy
Post napisał: RomanJ4 » 21 gru 2025, 19:24
Leonardo
Re: Prosty sposób na rysowanie perspektywy
Post napisał: Leonardo » 20 lis 2026, 16:13
I’ve been bouncing between the different table formats here and the variety actually holds up. Speed versions keep things moving, while the more relaxed tables let you settle in. The table casino games interface never gets in the way, and using crypto removes the usual pause between rounds that you get on other platforms.
Wróć do „Rysunek techniczny”
