NESTIX
- Posty w temacie: 11
Sorki pop9, pomyliłem cię z kimś innym.pop9 pisze:tzn. jasniej proszę??
Ja nie mam instalki Nestix
oto nestix2.def:
; nestix2 defaults-file
; Compensation
; 0 corresponds to -1 that is left
; 1 corresponds to 0 that is none
; 2 corresponds to 1 that is right
[Parts]
Compensation = 0
ProfileSnapDistance = 0.1
ProfileSnapStartAngle = 300.0
NXBEVELTEXTSCALE=0.125
TechToolVersion=1.1
ReadProfileAsPolyline=0
CanMakeOrders=1
ShowToolBar=1
SelectPartsForMetafileCreation_SQL=
Default_Move_dX=100.000000
Default_Move_dY=100.000000
Default_Move_rotX=100.000000
Default_Move_rotY=100.000000
Default_Move_rotAngle=10.000000
Default_Move_rotOn=0.000000
Default_Move_translateOn=1.000000
Default_defaults_snapFromPoint=20.000000
Default_defaults_snapFromLine=20.000000
Default_defaults_duplicateDX=20.000000
Default_defaults_duplicateDY=20.000000
Default_defaults_rotationAngle=10.000000
Default_defaults_snapOn=1.000000
Default_grid_dX=20.000000
Default_grid_dY=20.000000
Default_grid_gridOn=1.000000
Default_fillet_filletRad=20.000000
Default_fillet_chamferA=20.000000
Default_fillet_chamferB=20.000000
Default_fillet_chamferAngle=45.000000
RemunerationOffset=5
UseNewImportDlg=1
ImportReadAll=0
ImportDatabaseAccess=1
ImportSaveAsPlate=1
ImportOverWrite=0
ReadImportFileListOnInit=1
ImportDirectory=.\import
ImportSetupDirectory=.\setup
ImportFileVersion=6
Default_BevelDim_Circle=10.000000
UseAutoRev=0
testTextOverlapOnSave=0 ;0=off, 1=on (message to log in import), 2 messagebox in import
AfterPartSaveProc=
Default_defaults_iDynSnap=1.000000
Default_grid_dynGrid=1.000000
Default_grid_visGrid=0.000000
ExtendedDataInDxf=0 ;Is extended data used to describe bevels information in a DXF-file. Possible values: 0 = False, 1 = True.
PrintDxfDuringSave=0 ;Prints a dxf file with a same name during part saving. Possible values: 0 = False, 1 = True.
ShowBevelReliveFields=0
ShowDimSymbols=0
Default_DimTextSize=100.000000
[Database]
DataSource=DSN=Nx2 MSDE;UID=nestix2;PWD=nestix2
UseMotifDbInterface=0
UseDirectOrderFromPartList=1
; Käytetään luettaessa käyttäjän arvoa
UserDatePattern = DMY4.
; Käytetään Informix-tietokantaan kirjoitettaessa
;DbDatePattern = MDY4/
; Käytetään Watcom-tietokantaan kirjoitettaessa
DbDatePattern = Y4MD-
UseRealForeignKeyQuery=0
UseNestix3Db=0
UseMSSQLServerConnectOptions=0
HideListDlgOnClose=0
DeleteSheetFromUse=0
StaticMsgLang=
UseNewSiteModel=0
nxsite=local
FormSet=A
PartListSendCmd=
StartupSQL=
NxRecentSheet=1
OrderListSendCmd=
UpdatePartMaterialSameAsOrderline=0
MaterialValuesCheckSQL=
UseMaterialStandards=0
SheetNameProc=NCUnewSheetName_1
UpdateFreeRectOnSave=1
AfterSheetSaveProc=
PlateToSheetUpdateProc=exec plateToSheetChangeProc %ld,%ld
UsePathSite=0
UseDbTransactionsOnPartImport=1
EditableCustOrderEditDlg=0
MrpInterfaceDialogNumber=18
NestBufferClearingProc=
UseGroupSite=0
UsePartImportMrpInterface=0
GetAsyOrderlineIdProc=
AddPartInfoAfterPosInfo=0
ReserveVisualOrdersToUser=
ShowAttachmentsButton=0
CheckNestMacroPartParams=0 ; Is Nest MacroPart feature in use (1) or not (0)
RemnantNameProc=
RemnantReadyProc=
Lang=def
UseNestQuantities=0
UseDbTransactions=1
MrpPartSearchOption=0
[Printing]
NestixRaport=0
RaportInteractive=0
NestInteractive=0
ReadPathNamesFromDb=0
ReadPathNamesFromNC=0
ReadPathNameListOnInit=1
ReadDxfListOnInit=1
PrintNestPictureDefaultValue=0
PrintEssiPicture=0
PrintNestedParts=0
UseWholePlateDefaultValue=1
DecorateInPartsState=0
MakePathMetafile=0
NestLandscape=1
ColorPrinting=0
PrintBevelList=0
PathNameScr=
PathNameMsg=SELECT MAX(NXNAME) FROM NXPATH WHERE NXNAME LIKE '________'
PathNameProc=
PrintPartPictureDefaultValue=1
PartsPlotScaleIndex=0;Plotters printing setting in the Parts side (0-8)
PartsPlotLineWidthIndex=0;Plotters printing setting in the Parts side (0-6)
RepComboShow=0
Params= %ld %s
Minimized=yes
Blocking=
RemoteExecuter=.\bats\nestrapo.bat
[Units]
GlobalUnits=mm
;;; HUOM SEURAAVASSA TULOSTUU ~-merkin
;;; paikalle diameter-symboli
;;; HUOM SEURAAVASSA TULOSTUU ^-merkin
;;; paikalle aste-symboli
;;; jos formaatin ;-merkin jälkeen on heti
;;; miinusmerkki(-) tulostus tapahtuu merkkijonon perään
[PARTSFONTCONV]
ConvCnt = 5
Conv1 = DX=;;
Conv2 = D=;~=;
Conv3 = DY=;;
Conv4 = A=;- ^;
Conv5 = R=;R;
[PartsOutput]
DimFormat=%.1lf
[ReportDef]
ReportFile=.\reports\nestrpt_def.rpt
SelectionFormula={nxpath.nxpathid} in [%s]
UseSqlInClause=1
UsePrintPreview=1
PreviewWindowLeft=100
PreviewWindowTop=0
PreviewWindowWidth=900
PreviewWindowHeight=830
[ReportFin]
ReportFile=.\reports\nestrpt_fin.rpt
UseSqlInClause=1
UsePrintPreview=1
PreviewWindowTop=0
[ReportSwe]
ReportFile=.\reports\nestrpt_swe.rpt
UseSqlInClause=1
UsePrintPreview=1
PreviewWindowTop=0
[ReportGer]
ReportFile=.\reports\nestrpt_ger.rpt
UseSqlInClause=1
UsePrintPreview=1
PreviewWindowTop=0
[Nest]
ActPlate=1
ActPath=1
ActGrip=1
QuilUiState=0
NestBufferState=1
OpenPlateList=1
MakeSheetMetafile=1
DeleteSameBlobSheets=0
CanChangeOrders=1
ShowToolBar=1
SelectSheetForMetafileCreation_SQL=
UseNewWorkareaOnPlateOpen=0
AddRejectedToOrderFreeCount=1
AskPartFilenameFromDb=0
RemnantCheckBeforePrinting=0
ShowPathSaveDialog=0
SamePrintCodes=0
NX_NO_SAVE_QUESTION=0
GenerateSheetNameLevel=2
SheetNameFormat=%s-%02ld
MakeBitmapOnSheetEditUpdate=0
ShowAutomaticPlateResize=0 ; Show Autom. Plate Resize -button in Plate and Nest Dimensions -dialog
HandlePartsOutsidePlate=0 ;Removes from reports the parts that are outside plate geometries. Possible values: 0 = False, 1 = True.
LJC=1
SearchDefaultPlateSqlCmd=0 ;Database SQL command or prosedure call to search PlateId for Ordeline Default: 0 (No operations)
ExtMrpImportUtilityState=0 ; If > 0 and nxinvmrpimportflag > 0, sheet is prenested without geometry files
ShowWarnOfMaxNumOfTorches=0
PartIdTextSize=20.0 100.0 0.2
PartNegativeQuantityAllowed=0
UsePlateOffsetInInsideCheck=1
[LicenseServer]
ServerName=localhost
Interval=120
[FlameTech]
ShowToolBar=1
AutoOrderState=1
StartPointState=1
FreeCutState=1
NFSTRESSEDSTATE=2
FlamePrintingEndProc=
CanDeleteAlreadyCutCutterPath=1
TOOL_USE_MAX=5
TOOL1_TITLE=Rapid,30001
TOOL2_TITLE=Cutting Tool,0
TOOL3_TITLE=Point Mark,20001
TOOL4_TITLE=Marking Line,10001
TOOL5_TITLE=Drill, 21001
CommonLineCutState=1
StressedExtraFlagNameAndSqlCommand=0
StressedGetExtraFlagStateSqlCommand=0
OrigoState=1
CutDirState=1
ShowUsabilityCombo=
SelectUsabilityComboValuesSQL=select '10 %',10,'20 %',20,'30 %',30,'40 %',40,'50 %',50,'60 %',60,'70 %',70,'80 %',80,'90 %',90,'100 %',100
;StressedGetExtraFlagStateSqlCommand=<SQL command (lDbId)> Query to get information has one of the current plates already flack on. If so (returns != 0) flack will be selected and disablet.
;StressedExtraFlagNameAndSqlCommand=<UiName>,<SQL command (iFlack,lDbId)> Shows <UiName> checkbox and if chekked calls SQL command for new remnant (default = 0)
ShowMultiElemLeadButton=1
[Bahco]
CornerAbsRadius=12.5
CornerMaxRadius=12.5
CornerMinRadius=12.5
CornerStartLen=12.5
CornerEndLen=12.5
[NX2VersionData]
NX2_Version=2006
NX2_Release=0
NX2_Build=327
[PartListDxfExport]
ShowExportButton=0
[SheetListDxfExport]
ShowExportButton=0
[Import]
ImportReadAll=1
ImportDatabaseAccess=0
ImportSaveAsPlate=0
ImportOverWrite=0
DxfDirectory=C:\nx2\MASTER\IMPORT\DXF
DxfExtension=*.*
DwgDirectory=.\import\dwg
DwgExtension=*.*
EssiDirectory=.\import\essi
EssiExtension=*.*
SpanDirectory=.\import\span
SpanExtension=*.*
Nestix1Directory=.\import\cld
Nestix1Extension=*.*
Nestix2Directory=.\import\nestix2
Nestix2Extension=*.*
TribonDirectory=.\import\tribon
TribonExtension=*.*
AfterPartImportProc=0 ;Database SQL command or prosedure call after part import. Parameters: lPartId,pszSetName. Default 0 (No operations)
AfterSheetImportProc=0 ;Database SQL command or prosedure call after sheet import. Parameters: lSheetId,pszSetName. Default 0 (No operations)
ImportDefaultFileTypeIndex=0
BeforePartImportProc=0 ;Database SQL command or prosedure call before part import. Parameters: szFileName (no path), szFileName2 (path+name), iImportMode (DXF,SPAN...), iOwerWrite, iSaveAsPlate. Default 0 (No operations), Returns iOk (0==OK) and szLogCommand
ImportUseTypeDirectories=0
[NF2PlateSheetOrInventoryInfoData1]
SQLCommand=SELECT NXNAME FROM NXSHEET WHERE NXSHEETID=%ld
FormatString=%s
[EssiImport]
TextImport=0 ;Import Incjet Texts extenison off (0) / on (1)
BevelToTexConversion=0 ;Convert Bevel commands to text Off (0) / On (1)
[TextInfo]
TextHeight=50.0000
TextAngle=0.0000
TextVerticalAlign=0
TextHorizontalAlign=0
TextUseWinFontToInfoTexts=
[Metafile]
DefaultWidth=297
DefaultHeight=210
DefaultPixelWidth=0.150000
[Inch]
BaseUnitFactor=25.4
[NF2PartInfoData1]
SQLCommand=SELECT NXDRAWING FROM NXDETAIL WHERE NXDETAILID=%ld
FormatString=Drawing: %s
UseOrderlineIdInsteadPartId=0
[Nestrapo]
Params=dst
Minimized=yes
Blocking=
[none]
Params=
Minimized=yes
Blocking=
[MachDb]
UseXmlDb=
[ Dodano: 2008-12-09, 10:24 ]
a to NxPostpr.ini
[General]
; EditorProgram=C:\Program Files (x86)\JGsoft\EditPadPro\EditPadPro.exe
EditorProgram=notepad.exe
LastMachine=SuomenPolttoleikkausBurny10
MaxInterprTime=1200
MaxNcProgramSize=20000000
MaxErrorCount=10
ShowLinesInProgress=1
TextFontDirectory=.\WFONTS
TextFontDefault=nxfont8.nxf
SetLocaleCTYPE=german
OutputMacroUsageStatistics=0
MaxLineLenInInfoBox=90
[Machines]
Machine_1=SuomenPolttoleikkausMicroStepPlasma
Machine_2=SuomenPolttoleikkausBurny10
[SuomenPolttoleikkausMicroStepPlasma]
ProcessType=PLASMA
MacroFile_1=MicroStep_SPL.xmc
MacroDirectory=..\exe\NxPostpr\
LastCldataDir=.\nc\
FixedCldataDir=..\exe\NxPostpr\
NcProgramDir=.\essi\
LastCldataFile=
BevelCutOrder=124
BevelCutToStraightCut=000
CalcMovesFromHomePoint=1
ChangePrecisionCutTools=
ChangeSlowrToolsToCutTools=1
ChangeStartWindowCutTools=
ChangeTextToMoves=0
CheckMaxCircleRadius=1
CheckMinCircleRadius=0,0.0,0.0
CheckShortMovements=1
CheckShortRapidMovements=0.0
CheckSlowDownAndAccelerationMoves=0
CheckTwoLeadMoves=
CircleSplitMaxArcH=0.05
CircleSplitMaxRadius=99000.0
CldataExtension=
CompareSubrToolParameters=
ConnectLinesInTube=1
CornerLoopPoints=
CreateNcFilenameInMacro=0,abc.xmc
ErrFileExtension=_err.log
ExpandMultiTorchMachiningTypes=
FixedCldataExtension=.XPV
FixedPrePostFileName=FixedCldata.XPV
InputFileType=NX-CUTTING
JoinSameCircles=1
KerfCalc=00,ARCANGLIMIT=0,ARCHCOFFLODIST=0
LeadMovePoints=
LineConnectionTubeRadius=0.05
MachineInfo=Komas MicroStep Plasma
MarkProfileStartEndIntersection=0
MissingFunctionsFile=MissingFunctions.xmc
MoveTextReferensPointInTheMiddleOfTextBox=0
MultiLineText=0
NcProgramExtension=.ISO
OneTorchLimitCheck=0
OutputDistanceAndTimeCalc=
OutputMoveAngles=000
OutputToolParameters=
PendulumDistance=0
RadiusCompCalc=0200000000
RadiusCompCalcAskCompValue=
RadiusCompCalcMachiningTypes=
RapidSpeed=10000
RemoveFixedPrePostFile=1
RemoveIncorrectNcProgram=1
RemoveTribonNxCutFile=0
SameToolTypes=CUT|SLOWR
ShortestAllowedMove=0.05
SortedMachiningTypes=
SubroutineGeneration=0000
SupportedMachiningTypes=CUT,SLOWR,PUNCH,POWDER
ThreeTorchPoints=
TransMatrix33=0, 1,0,0, 0,1,0, 0,0,0
UseFixedPrePostFileName=0
UsePendulumStart=0
UseTextDruckMasken=0
Vacublast=0,XNEG=10,XPOS=10,MAXH=2.0,EDGEDIST=40.0
[SuomenPolttoleikkausBurny10]
MacroFile_1=Burny10BevelGas.xmc
LastCldataDir=.\nc\
LastCldataFile=
BevelCutOrder=124
ChangeTextToMoves=0
CheckTwoLeadMoves=
CldataExtension=
CornerLoopPoints=
JoinSameCircles=1
LeadMovePoints=
MachineInfo=Komas Burny 10 Gas
MultiLineText=0
OutputToolParameters=TORCH_COUNT,TORCH_DISTANCE,KERF_PARAMS,END_KERF_PARAMS
PendulumDistance=0
RadiusCompCalc=200000000
RapidSpeed=10000
ThreeTorchPoints=
UsePendulumStart=0
Vacublast=0,XNEG=20,XPOS=20
Wiadomość z ostatniej chwili...
Prawdopodobnie postprocesory do YUN (PERUN) zostały opanowane. Trwają testy na maszynach.
Burny5 łyka pliki YUN'owe (PERUN'owe)
YUN (PERUN) łyka pliki Burn'ego
Wciąż otwarta pozostaje sprawa postprocesorów do Bystronika i połączenia RS-232 YUN (PERUN) z komputerem programisty.
Proszę wszystkich o propozycje bo czas nagli... a księżniczka się starzeje...
kredek
[ Dodano: 2008-12-09, 13:33 ]
A tak wygląda przykładowy krótki plik wykonawczy dla lasera Bystronic .
(/RAN10.00)
N1G29X6000Y2000P1H1
N2G52X10Y10L1
N3G99
N1000G28X110Y160L1P1
N1001G0X50Y85
N1002G0Y75
N1003G1Y65M04
N1004G41
N1005G3I50J85M05
N1006G40
N1007G0X110Y0
N1008G1X100Y10M04
N1009G41
N1010G1X0
N1011Y160
N1012X50
N1013G2X100Y110J110
N1014G1Y10
N1015X104Y6M05
N1016G40
N1017G98
[ Dodano: 2008-12-09, 13:55 ]
Podejrzewam, że wszystko jest do maszyn które są w obecnych opcjach Nestixa.
Na oko żaden nie generuje G cod'u, ale to moje zdanie...
kredek
[ Dodano: 2008-12-17, 21:29 ]
Postprocesory zrobiliśmy w tamtym tygodniu "sposobem gospodarskim" znaczy sie we własnym zakresie.
pop9 zdobywa rekę księżniczki. Lepiej późno niż wcale.
kredek
(/RAN10.00)
N1G29X6000Y2000P1H1
N2G52X10Y10L1
N3G99
N1001G0X50Y85
N1002G0Y75
N1003G1Y65M04
N1004G41
N1005G3I50J85M05
N1006G40
N1007G0X110Y0
N1008G1X100Y10M04
N1009G41
N1010G1X0
N1011Y160
N1012X50
N1013G2X100Y110J110
N1014G1Y10
N1015X104Y6M05
N1016G40
N1017G98
W katalogu tym znajdują się jakieś postprocesory chyba oraz pliki exe, dll, ctn, ini itp...pop9 pisze:a co masz w katalogu NxPostpr??
kredek
