Hej,
Czy ktoś byłby mi w stanie wytłumaczyć jak zmierzyć frez umieszczony w oprawce kątowej i później jaka jest możliwość
zaprogramowania na zwykłej tokarce z osią Y.
Oprawka kątowa
Oprawka kątowa
Re: Oprawka kątowa
Może zobacz tu:
A tu jest makro do oprawki kątowej:
https://www.emastercam.com/forums/topic ... ngle-head/
O0001 (FANUC ANGLE HEAD MACRO )
G00 G17 G20 G40 G49 G80 G90 G94
G00 G91 G28 Z0.0 M09
T01 M06
G00 G90 G54 X0.0 Y0.0 S2500 M04 (REVERSE SPINDLE FOR CW ON HEAD)
G00 G43 H01 Z12.0 M08
G65 P9180 X-3.5 Y0.0 Z0.0 D2.0 H0.02 Q0.1 R0.1 W500 U5.9055 V5.5 F10.0 A3 B-30.0 C0.0
G00 Z12.0 M05
G00 G91 G28 Y0.0
M30
O9180 (UNIVERSAL_ANGLE_HEAD.MACRO)
(GENERATE LINEARIZED POINT-TO-POINT NC CODE)
(FOR MULTI-AXIS DRILLING OPERATIONS)
(PARAMETERS)
(#24 = HOLE LOCATION - X {0})
(#25 = HOLE LOCATION - Y {0})
(#26 = HOLE LOCATION - Z {0})
(#7 = HOLE DEPTH - D {2.0})
(#11 = SWARF CLEARANCE(G73/G83 ONLY) - H {0.02})
(#17 = PECK AMOUNT(G73/G83 ONLY) - Q {0.1})
(#18 = INCREMENTAL CLEARANCE - R {0.1})
(#23 = DWELL IN MILLISECONDS(G82 ONLY) - W {500})
(#21 = PIVOT DISTANCE - U {5.9055})
(#22 = TOOL GAUGE LENGTH - V {5.5})
(#9 = FEED RATE - F {10.0})
(#2 = B-AXIS ANGLE (ROTATE ABOUT Y) {10.0})
(#3 = C-AXIS ANGLE (ROTATE ABOUT Z) {45.0})
(#1 = TYPE G81=0/G82=1/G73=2/G83=3/G84=4/G85=5 {3})
(FORCE ABSOLUTE VALUES)
#1 = [ABS[#1]]
IF[#1GT5] GOTO 9991 (INVALID CYCLE TYPE!)
#7 = [ABS[#7]]
IF[#7EQ0.0] GOTO 9992 (INVALID HOLE DEPTH!)
#9 = [ABS[#9]]
IF[#9EQ0.0] GOTO 9993 (INVALID FEEDRATE!)
#17 = [ABS[#17]]
IF[#1EQ2] GOTO 17
IF[#1EQ3] GOTO 17
GOTO 18
N17
IF[#9EQ0.0] GOTO 9994 (INVALID PECK VALUE!)
N18
#18 = [ABS[#18]]
IF[#18EQ0.0] GOTO 9995 (INVALID R CLEARANCE!)
#21 = [ABS[#21]]
IF[#21EQ0.0] GOTO 9996 (INVALID PIVOT LENGTH!)
#22 = [ABS[#22]]
IF[#22EQ0.0] GOTO 9997 (INVALID TOOL GAGE LENGTH!)
#11 = [ABS[#11]]
IF[#11EQ0.0] GOTO 9998 (INVALID CHIP CLEARANCE!)
#23 = [ABS[#23]]
(CALCULATE THE UNIT VECTORS)
#4 = [COS[#3] * SIN[#2]]
#5 = [COS[#3] * [TAN[#3] * SIN[#2]]]
#6 = [COS[#2]]
(CALCULATE THE TOTAL GAUGE LENGTH)
#8=[#21+#22]
(CALCULATE X,Y,Z SHIFTS FOR TOTAL GAUGE LENGTH)
#101=[#8*#4]
#102=[#8*#5]
#103=[#8*#6]
(CALCULATE X,Y,Z SHIFTS FOR R-PLANE CLEARANCE)
#111=[#18*#4]
#112=[#18*#5]
#113=[#18*#6]
(START POINT W/CLEARANCE)
#124=[#101+#111+#24]
#125=[#102+#112+#25]
#126=[#103+#113+#26]
#134=[#101+#111+#24]
#135=[#102+#112+#25]
#136=[#103+#113+#26]
(FINAL END POINT)
#144=[#24-[#7*#4]+#101]
#145=[#25-[#7*#5]+#102]
#146=[#26-[#7*#6]+#103]
IF[#1EQ0.0]GOTO 10
IF[#1EQ1.0]GOTO 20
IF[#1EQ2.0]GOTO 30
IF[#1EQ3.0]GOTO 40
IF[#1EQ4.0]GOTO 50
IF[#1EQ5.0]GOTO 60
GOTO 9991 (INVALID CYCLE SELECTION!)
N10 (G81 - STANDARD DRILL CYCLE)
(HOLE LOCATION - 'X' = #24)
(HOLE LOCATION - 'Y' = #25)
(HOLE LOCATION - 'Z' = #26)
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
(UNIT VECTOR - 'I' = #4)
(UNIT VECTOR - 'J' = #5)
(UNIT VECTOR - 'K' = #6)
(PIVOT DISTANCE = #21)
(TOOL GAUGE LENGTH = #22)
(TOTAL SET LENGTH = #8)
(HOLE DEPTH - 'D' = #7)
(INCREMENTAL CLEARANCE - 'R' = #18)
(FEED RATE - 'F' = #9)
G00 X[#124] Y[#125] Z[#126]
G01 X[#144] Y[#145] Z[#146] F[#9]
G01 X[#134] Y[#135] Z[#136] F[#9*50]
GOTO 99
N20 (G82 - STANDARD DRILL CYCLE W/DWELL)
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
(DWELL IN MILLISECONDS - 'P' = #23)
G04 P#23
GOTO 99
N30 (G73 - CHIP BREAK CYCLE)
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
(PECK AMOUNT - 'Q' = #17)
(SWARF CLEARANCE - 'H' = #11)
WHILE[#126GT#146]DO 1
#124=[#124-[#17*#4]]
#125=[#125-[#17*#5]]
#126=[#126-[#17*#6]]
IF[#126LT#146] GOTO 73
G01 X[#124] Y[#125] Z[#126] F[#9]
G01 X[#124+[#11*#4]] Y[#125+[#11*#5]] Z[#126+[#11*#6]] F[#9*50]
END 1
N73
GOTO 99
N40 (G83 - DEEP HOLE CYCLE)
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
WHILE[#126GT#146]DO 2
IF[#126LT#146] GOTO 83
END 2
N83
GOTO 99
N50 (G84 - TAPPING CYCLE)
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
M03
G01 X[#134] Y[#135] Z[#136] F[#9]
M04
GOTO 99
N60 (G85 - BORING CYCLE)
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
GOTO 99
N99 G00 (END MACRO - SUCCESS)
M99
N9991
#3000=1(INVALID CYCLE TYPE!)
GOTO 9999
N9992
#3000=2(INVALID HOLE DEPTH!)
GOTO 9999
N9993
#3000=3(INVALID FEEDRATE!)
GOTO 9999
N9994
#3000=4(INVALID PECK VALUE!)
GOTO 9999
N9995
#3000=5(INVALID R CLEARANCE!)
GOTO 9999
N9996
#3000=6(INVALID PIVOT LENGTH!)
GOTO 9999
N9997
#3000=7(INVALID TOOL GAGE LENGTH!)
GOTO 9999
N9998
#3000=8(INVALID CHIP CLEARANCE!)
GOTO 9999
N9999 (END MACRO - FAIL)
M30
T01 M06
G00 Z12.0 M05
G00 G91 G28 Y0.0
M30
(PARAMETERS)
#1 = [ABS[#1]]
#7 = [ABS[#7]]
#9 = [ABS[#9]]
#17 = [ABS[#17]]
IF[#1EQ2] GOTO 17
IF[#1EQ3] GOTO 17
GOTO 18
N17
N18
#18 = [ABS[#18]]
#21 = [ABS[#21]]
#22 = [ABS[#22]]
#11 = [ABS[#11]]
#23 = [ABS[#23]]
#6 = [COS[#2]]
#8=[#21+#22]
#101=[#8*#4]
#102=[#8*#5]
#103=[#8*#6]
#111=[#18*#4]
#112=[#18*#5]
#113=[#18*#6]
(FINAL END POINT)
IF[#1EQ0.0]GOTO 10
IF[#1EQ1.0]GOTO 20
IF[#1EQ2.0]GOTO 30
IF[#1EQ3.0]GOTO 40
IF[#1EQ4.0]GOTO 50
IF[#1EQ5.0]GOTO 60
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
GOTO 99
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
G04 P#23
GOTO 99
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
END 1
N73
GOTO 99
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
END 2
N83
GOTO 99
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
M03
M04
GOTO 99
(ANGLE 'B' = #2)
(ANGLE 'C' = #3)
GOTO 99
M99
N9991
GOTO 9999
N9992
GOTO 9999
N9993
GOTO 9999
N9994
GOTO 9999
N9995
GOTO 9999
N9996
GOTO 9999
N9997
GOTO 9999
N9998
GOTO 9999
M30
