Mach 5 osi
Re: Mach 5 osi
Google nie masz ?
https://www.machsupport.com/wp-content/ ... Config.pdfUp to three additional axes. These can be either Rotary (i.e. their movement is measured in degrees) or Linear. One of the additional linear axes can be slaved to the X or Y or Z axis. The two will move together at all times in response to a part program's moves and to your jogging, but they will each be referenced separately.
parafoil
Re: Mach 5 osi
chodzi mi o interfejs, czy jest inny do 6 osi? mam macha ale jak pisałem sa tylko osie X,Y,Z i A
chyba że czegoś nie zrozumiałem, czy te dodatkowe 3 osie to obrót wokół osi xyz???
