Automatyczna wymiana narzędzi w mokrym chińczyku.
Tool change adapters 80mm spindle
Jeśli znasz ciekawy adres strony związanej z CNC, mechaniką lub automatyką umieść go tutaj. Zabronione jest umieszczanie linków reklamowych. Musisz mieć minimum 10 postów aby napisać coś na tym forum.
oskaeg
Post napisał: oskaeg » 20 wrz 2018, 19:34
https://www.sorotec.de/shop/Tool-change ... indle.html
Easy and cost-efficient entry into automatic tool change
With a mechatron tool change adapter you can easily upgrade an existing spindle system with manual tool change to an automatic tool change.
With our model STC80 we offer for all of our spindles from STANDARD series up to 2,2kW a suitable tool change adapter. The costs for a system are quite lower than a comparable system with pneumatic tool change. Therefore our product is primary interesting for private customers or semi-professional users.
For professional users and industrial applications we recommend the spindles from our ATC and DTC series.
Toolholder: SK10
Diameter outside: 80mm
Weight: 1.7 kg
Max Torque: 0.9 Nm
Max RPM: 24.000
Pneumatic for tool-change: 6-15 Bar, recommend min 10 Bar
Toolchange magazin for 6 Mechatron toolholders SK10 / ER16
https://www.usovo.de/shop/Tool-changer- ... 72k1nchs86
Wróć do „Linki”
