Czy jest ktoś tak mocny i może mi wytłumaczyć jak przeprowadzić korektę osi Z abym mógł pobierać narzędzia z magazynku bo brakuje mi 3mm aby pobrać narzędzie.korekta ta już kiedyś była dokonywana ponieważ była wymieniana śruba od tej osi.Problem powrócił po wymianie dysku starego (padł całkowicie) na nowy.Nowy nie posiada wcześniejszych ustawień a brakuje własnie tej korekcji. Maszyna to:
Homag BAZ 32
sterowanie to Homatic NC 81
mam tą procedurę ale po angielsku i dochodzę do pod punktu 11 a dalej nie wiem o to procedura:
Adjustment instructions for the tool changer position for NC81 control unit with a disk changer
If the machine is switched on and in working order, i.e. no CNC fault, SPC-SYNC etc., and the disk changer is in the X-direction in water and the cutter spindle is also properly aligned, then proceed as follows:
1. insert an empty tool adapter into the cutter spindle by hand
2. switch of control voltage
3. if the disk can be moved, then unscrew the valve coil from the pulse valve and move the disk down by hand
4. push the Y axis backwards and adjust the Z axis by hand to that the upper groove flank of the HSK receiver touches the upper groove flank of the plastic insert of the disk changer
5. push the Y axis by hand into the disk changer position
6. read off and make a note of the ACTUAL value of the Y and Z axes
7. push the Y axis far enough forwards and switch the control voltage back on
8. now remove the tool manually and insert into a position in the disk changer, then reference the disk and switch the key-operated switch to the automatic mode
9. run down the computer (in basic menu with CTRL+A) and log on again with "service user"
10. click menu item 1 "SERVICE MODE"
11. go to "Enter/transfer fixed data"
12. "Change machine fixed data (f2)"
13. write the change dimensions noted above into the corresponding lines
14. end with "R" and then save with "A" if you are sure that everything is OK. If you are not sure then end with "R" and abort with "B"
15. after altering, you then have to "Transfer fixed data to machine f2"
16. go back one page with "R"
17. go to "SHELL"
18. write chd prg
19. write "e.eichen" and then proceed with great care
20. the change dimensions from the f2 file must correspond with the entries in ".eichen"
21. then press "ESC" twice
22. if you are sure that the entries are correct, write "lo" (load), if you are not sure or you have overwritten something, write "ab" (abort) and repeat from number 19)
23. press "ESC" until you are back in the service mode
24. run the computer down again with "CRTL+A" and log on with "cnc user" and reference machine
25. write a small program in which the tool in position one is changed
26. then have the tool in position one slowly changed
27. turn the potentiometer to zero when the cutter spindle reaches the bevel of the HSK receiver and check that the gap in all four directions is identical (distance between receiver of cutter spindle and tool adapter)
28. if the gap is not equal, determine and enter a new change dimension (from number 9)
29. then test the same with a C-axis unit and pay attention to the driving pin(s)
30. the change position then has to be entered in ".eichen_k?" (V.S.C_POS=??) and f2 data.
If something is not OK or unclear, please call the customer service department.
Proszę o pomoc nawet odpłatną
Korekta osi Z
engineer_equip
engineer_equip
bodzio82 pisze:Witam
Poradziłem sobie z tą osią Z. A czy Pan ogólnie zajmuje się automatyką? Jak można to prosił bym o kontakt.
Witam. Naprawiam automatyki w maszynach CNC Homag Gruppe i innych producentów. Na tej stronie z ciekawości. Teraz robię sam projekt automatyki do maszyny. Możesz pisać do mnie na e-mail przez mój profil (poniżej tego tekstu) .
