BasRel v1.0
aues
BasRel v1.0
Post napisał: aues » 15 cze 2012, 16:33
BasRel v1.0 is a plugin for Autodesk 3ds Max, designed to give a complete solution for creation of bas-relief (high-quality HeightMaps) from 3d models or 3d scenes.
These reliefs are ideally process on CNC machines. The algorithm of this plug-in is based on work of Pildonovak. However, we developed the new features and capabilities.
The support for 64-bit systems allows BasRel perform effect more quickly. BasRel v1.0 with optimized RAM management makes creation process of bas-relief from 3d scene as easy as ABC.
<center>Obrazek </center>
<center>[youtube][/youtube]</center>
http://buy.3drelief.net
Kieriestof
Post napisał: Kieriestof » 06 sty 2013, 00:11
extra, but how to do the same with color bitmap?
I greet
Zbych07
Post napisał: Zbych07 » 06 sty 2013, 04:21
Całkiem fajny plugin, więcej można poczyać i zobaczyć tu: ---> Link
