Mam Pytanie co oznaczaja te wyrazenia?
@430 K3 K1 K0 R51
@100 K-10
znaczenie wyrazen
grzesiek28
efiks
@430 <Value 1> <Value 2> <Value 3> <Value>
The numerical value is entered in the zero offset memory. The existing contents are overwritten.
The notations <Value 1> to <Value 3> must be allocated as follows:
<Value 1> Group of settable zero offsets (G54 = 1 to G57 = 4)
<Value 2> Number of axis
<Value 3> Coarse or fine value (0 or 1)
Example:
@430 K1 K2 K0 K500 The coarse value of the first settable zero offset is loaded
in the second axis with the constant 500
a to drugie to skok do danego bloku....
Example:
....cieżko jest lekko żyć....
