Panowie zna ktoś podobny sposób wstawiania współrzędnych otworów do tabeli tak jak w MOLD WIZARD w Draftingu? Niestety nie mamy licencji w pracy do modułu Mold wizard i szukamy jakiejś metody obejściowej.
NX Environment Variables
The following are variables that can be set for NX as a system environment, startup script variable, or sometimes as a customer defaults file. The more common customer defaults file are used the less these variables will be relevant. Then these variables will be used for testing or debugging.
NX 6 Added Variables
enable the legacy Create Reference Set CSYS functionality, creating a new Reference Set UGII_ALLOW_REFERENCE_SET_CSYS=1
turn on / some of the legacy transformation options are not available in NX6. UGII_ENABLE_TRANSFORM_LEGACY_OPTIONS = 1
turn on the new NX6 Hole Table creation in drafting UGII_DRAFTING_HOLE_TABLE=1
NX 5 Added or Depricated Variables
Enable the Class Selection Dialog Removes the floating dialog class selection and goes straight to the advanced class selection dialog NX_FORCE_CSD=1
Point to the directories with the template and pax files (File\New) UGII_TEMPLATE_DIR=<path>
Enable on extra Nx5.02 Replace Face Option UGII_Simplify_Surface=1
After Nx5.02 activate old Edit->Face functions UGII_DMX_NX502=1
don't cache WAVE specific information UGII_DONT_CACHE_WAVE_LINK_DATA=1
Variable to Aid With “Out of Memory” Errors on Large Assemblies UGII_CLOSE_UNDO_MODE=CHECK
NX 4 Added or Depricated Variables
Visually see the coverage of a Journaling when creating a Journal file
UGII_JOURNAL_INDICATOR=1
Enable view dynamics under the function keys (F1 -> F4) UGII_FKEY_DYNAMICS=1
Required to load the Solid Edge V19 adapter when Solid Edge parts are opened in NX4.0.2 UGII_USE_SEV19=1
NX 3 Added or Depricated Variables
Store user customizations UGII_LOCAL_USER_DEFAULTS=<path>\nx3_user.dpv
Set Default Role, MTX file must be in the ugii\menus\roles\ UGII_DEFAULT_ROLE=example.mtx
Location of the user.mtx file Store nx_mru.txt file for folding of menus UGII_USER_PROFILE_DIR=<path>
Save history.pax palette file in a specific location UGII_HISTORY_PALETTE_DIR=<path>
Turn of folded menus and prevent recording actions UGII_NO_FOLDED_MENUS=1
Default location for interactively created palettes UGII_PALETTE_WORK_DIR=<path>
NX to perform an interactive drawing refile on part load UGII_DRAFT_DRAWING_UPGRADE=1
Enable the Class Selection Dialog NX_FORCE_CSD=1
Disable splash on start of a NX session UGII_DISABLE_FLASH=YES
Enable the drawing compare (the hpgl output) function under file -> utilities -> UGII_ALLOW_DRAWING_COMPARE=1
Base Environment Variables
Not sure which version it was first released in but they have been in NX for a while.
Support for Multi Processor or Multi Core CPUs UGII_SMP_ENABLE=1
Mouse wheel (since NX2) UGII_MOUSE_WHEEL=1 default, roll back to enlarge UGII_MOUSE_WHEEL=2 roll forward to enlarge UGII_MOUSE_WHEEL=0 inactive mouse wheel, no zoom
Where should execute NX/Open application directory look by default UGII_INITIAL_UFUN_DIR=
Allow for opening of Solid Edge Assemblies UGII_SE_INTEROP=1
All the expression editor to be viewed in Drafting UGII_DRAFT_EXPRESSIONS_OK=1
Required for interoperability to function between Solid Edge and NX UGII_MONIKER=1
NX Location UGII_BASE_DIR=C:\PROGRA~1\UGS\NX4~1.0\ UGII_ROOT_DIR=%UGII_BASE_DIR%UGII\
Point to the application directory instead of custom_dirs.dat UGII_USER_DIR=<path>
Set Custom Directory Location UGII_CUSTOM_DIRECTORY_FILE=<path>\custom_dirs.dat
set part family member directory UGII_INITIAL_FAMILY_INSTANCE_DIR=%folder%
Enable class selection on the graphics display dialog bars UGII_CSD_ON_DIALOG_BAR=1
Enable class selection on the selection toolbar UGII_CSD_ON_TOOLBAR=1
Text file to map directories between windows and unix
UGII_DIRECTORY_MAP_FILE=<path to file>
Prevents the syslog from being removed from temp UGII_KEEP_SYSTEM_LOG=1
File difference time tolerance UGII_MODIFICATIONS_TIME_TOLERANCE=60
Prevents NX from defaulting to sketch on face when extruding Customer Defaults: Modeling->Extras->Sketch on Planar Faces UGII_SECTION_USE_PLANAR_FACE=1
Default location of your pattern files UGII_PATDIR=<path>
Creates a new parts list from a template UGII_DEFAULT_PARTS_LIST=<path>
Remove unsupported characters from text in drafting UGII_DRAFT_REMOVE_UNSUPPORTED_CONTROL_CHARACTERS=TRUE
Enable symbolic thread performance improvements UGII_DRAFT_SUPPRESS_THREAD_TRUE_HIDDEN_LINE=1
Force Parts lists to Upper Case UGII_FORCE_PLIST_AUTO_TEXT_TO_UPPER_CASE=1
Prevent Internal pars list from being used for Insert->Parts List UGII_IGNORE_INTERNAL_PLIST=1
Delay View Updates preference can be saved with the part file, this overrides that setting UGII_SUPPRESS_VIEW_UPDATE=1
Enable Surface Finish symbols in drafting UGII_SURFACE_FINISH=ON
Defining a user defined location for custom symbols UGII_SYMBOL_LIBRARY_DIR=<path>
User Defined Directory for Table Templaces defined by pax files UGII_TABLE_TEMPLATES=<path>
Allows user defined balloon symbols to be applied to assembly drawings UGII_UPDATE_ALL_ID_SYMBOLS_WITH_PLIST=1
Activate the weld symbols utility for drafting UGII_WELD_SYMBOL=ON
Converts promotions to WAVE geometry UGII_CONVERT_PROMOTION_TO_LINKED_BODY=1
turn off preview generation for all component Previews will still be generated for the Work and Display part UGII_DISABLE_COMPONENT_PREVIEWS=TRUE
Disable the generation of preview images under all circumstances UGII_DISABLE_PREVIEW=ON
Overrides customer defaults or the Save Options to always save trueshape data UGII_FORCE_TRUESHAPE_SAVE=1
Reverts to old style if internal errors received when adding a component to an assembly UGII_OLD_STYLE_STAGING_VIEW=YES
disable part preview in Open Part file UGII_SHOW_PART_PREVIEW=OFF
Allows JT assemblies to be opened as an assembly UGII_JT_ASSY_STRUCTURE=1
auto update for parts lists will not be turned off in NX/Manager mode UGII_UGMGR_PLIST_ALLOW_AUTO_UPDATE=1
point UG to the install path of Process Aid Wizard UGPROCESS_AID=<path>
Enable Weld Assistant Required for weld assistant. Points UG to the install directory for weld assistant. E.g: D:\Program Files\EDS\Unigraphics NX\UGWELD UGWELD_DIR=<path>
Helpfull Part Attributes
-->File->Preferences
If attribute exists on a component then component is excluded by all parts list
PLIST_IGNORE_MEMBER=1
If attribute exists on a component then that component and all of its children is excluded PLIST_IGNORE_SUBASSEMBLY=1
If attribute exists on a component will not intersected and shown with no crosshatching in drafting section view SECTION-COMPONENT=NO
