POMOC W PROGRAMIE
Dyskusje na temat systemu Sinumerik
omm
Znawca tematu (min. 80)
POMOC W PROGRAMIE
Post napisał: omm » 22 cze 2009, 12:43
Witam wszystkich mam maly klopot a mianowicie mam do napisania program na freazrke no i jako tako udalo mi sie cos wydlubac i teraz jest pytanie czy jest to w miare poprawnie napisane. I teraz pytanie czy byl by ktos taki skory o poprawienie w tym programie ewentualnych bledow i co tam jest nie tak PLIS JESTEM LEIKIEM I NIE ZNAM SIE NA TYM AZ TAK
o to program
%10
N0000 G54 G90
N0010 G94 G40 T0202
N0020 S17500 M03
N0030 G00 X-1.0 Y0.0 Z5.0
N0040 G00 Z-10.0 M08
N0050 G01 X-1.0 Y168
N0060 X 95.3 Y 164.4
N0070 X 87.7 Y 159.1
N0080 X 0 Y 158.49
N0090 X 90.17 Y 154.43
N0010 X 80.49 Y 149.8
N0011 X 0 Y 149.8
N0012 X 75.2 Y 147.3
N0013 X 59 Y 140.1
N0014 X 0 Y 140.1
N0015 X 0 Y0
N0016 X 18 Y 27.2
N0017 X 25.9 Y 26.75
N0018 X 7.83 Y 0
N0020 X 31.4 Y 27
N0021 X 42.05 Y 26.36
N0022 X 20.6 Y 0
N0023 X 46.41 Y 26.6
N0024 X 58.39 Y 26.39
N0025 X 40.12 Y 0
N0026 X 63.39 Y 24.53
N0027 X 73.78 Y 20.64
N0028 X 57.47 Y 0
N0029 X 76.74 Y 18.25
N0030 X 85.97 Y 14.1
N0031 X 74.99 Y 0
N0032 X 90.09 Y 11.3
N0033 X 103 Y 6.4
N0034 X 93.9 Y 0
N0035 X 108.8 Y 7.4
N0036 X 125.9 Y 7.7
N0037 X 126 Y 0
N0038 X 129.6 Y 11.9
N0039 X 138.3 Y 18.1
N0040 X 138.3 Y 0
N0041 X 141.2 Y 20.3
N0042 X 149.3 Y 28.4
N0043 X 149.3 Y 0
N0044 X 153.2 Y 30.7
N0045 X 204 Y 30.7
N0046 X 151.9 Y 20.3
N0047 X 204 Y 11.6
N0048 X 153.1 Y 0
N0049 X 204 Y 0
N0050 X 204 Y 190
N0051 X 194 Y 154
N0052 X 189 Y 161.4
N0053 X 173.3 Y 142.3
N0054 X 179.8 Y 204
N0055 X 161.2 Y 139.3
N0056 X 147.8 Y 147.1
N0057 X 160.7 Y 204
N0058 X 141 Y 150.8
N0059 X 120 Y 160.4
N0069 X 150 Y 204
N0070 X 98 Y 158
N0071 X 84.7 Y 158
N0072 X 0 Y 158
N0073 X 0 Y 0
N0074 X 20.9 Y 23.1
N0075 X 0 Y 44
N0076 X 0 Y 204
N0077 X 24.2 Y 147.8
N0078 X 0 Y 126
N0079 X 0 Y 139
N0080 X 60 Y 139
N0081G01 X 95.1 Y 154.6
N0082 G02 X 144.5 Y141 R 39
N0082 X 144.5 Y 141
N0083 G03 X 154.3 Y 134 R 10
N0084 X 170 Y 134
N0085 G01 X 184 Y 134
N0086 G02 X 194 Y 124 R 10
N0087 G01 X 194 Y 43
N0088 G02 X 184 Y 34 R10
N0089 G01 X152 Y 34
N0090 G03 X144 Y 29 R10
N0091 G01 X144 Y 29
N0092 G02 X 96.54 Y 12.73 R 39
N0093 G01 X 60 Y 29
N0094 G01 X 15 Y 29
jest maly klopot z tymi promieniami w wierszu N0085 COS TAM MI NIE GRA DO KONCA
Z GORY DZIEKUJE WSZYSTKIM ZA POMOC
[ Dodano: 2009-06-22, 12:45 ]
SORKA ZA BLEDY
Endrju76
Post napisał: Endrju76 » 22 cze 2009, 19:25
Jeżeli to Sin to należy wpisać wymianę narzędzi M6
N0010 G94 G40 T0202
N0011 M6
N0020 S17500 M03 - brak posuwu roboczego np F200
we wszystkich blokach po X i Y usunąć spacje
dopisać G01
N0082 G01 X 144.5 Y 141
N0084 G01 X 170 Y 134
Endrju
Zaznacz "POMÓGŁ" - to nie boli
mat336
Post napisał: mat336 » 22 cze 2009, 20:20
Moim zdaniem brakuje ci na poczatki G01 albo G00 a w tym N085 nie masz zadnego łuku,pozatym np moja maszyna nie przyjnie wymiaru jesi nie bedzie w nim przecinka, przyznaje szczerze ze nie patrzylemdokładniej na wymiary:):)
dziadol
Post napisał: dziadol » 22 cze 2009, 22:31
N0084 X 170 Y 134
Jak dla mnie to takze brakuje w zapisie N0084 nadania G01 lub łuku jako "R"
W N0083 jest nadany promień jako G03. i zapis N0084 takze czyta łuk lecz jest brak nadania łuku.
Inna sprawa jak to ma być prosta.
Jak ma być prosta to w N0084 powinien być zamis z G01
NP.
N0084 G01X 170 Y 134
lub
N0084 X 170 Y 134 R XX
Pozdro.....
[/b]
omm
Post napisał: omm » 23 cze 2009, 09:26
Własnie z tym promieniem R10 mam problem bo nie mam kompletnie pojecia jak to zrobic w poscie dolaczam zdjecie tego detaluObrazek tam gdzie sa te ostre krawedzie maja byc promienie po R10 na dole i na górze i wlasnie nie wiem jak to kurka zrobic DZIEKUJE WSZYSTKIM ZA POMOC
[ Dodano: 2009-06-23, 09:49 ]
kurka tylko jak tam wstawie wiekszy promien np R30 to robi delikatny luk moze to jest poprostu kwestia zle dobranego narzedzia
wiktoriano
Post napisał: wiktoriano » 23 cze 2009, 10:16
co prawda ja robie na tokarce ale u mnie na sinumeric 840D nie dziala polecenie "R"
muszę zamiast R10 wpisywać CR=10 i smiga:-)
wieslawbarek
Post napisał: wieslawbarek » 23 cze 2009, 20:47
Program masz dobrze napisany (no prawie ) tylko tak jak juz na samym początku napisał Endrju po G3 musisz mieć G1 nie możesz zaczynać od x144.5 musi być G1x144.5
omm
Post napisał: omm » 24 cze 2009, 00:34
DZIEKUJE WSZYSTKIM ZA POMOC JEST JUZ WSZYSTKO OKEJ :lol:
[ Dodano: 2009-07-01, 15:54 ]
Witam ponownie Panowiem znów pojawil sie klopot i za diabla nie wiem jak sobie z nim poradzic program zostal zatwierdzony przez mojego prof ale jest klopot chce aby zamiast R39 R10 itp zastosować I J i kurka od 2 dni walcze z tym i du** jedynie co udalo mi sie zrobic to wiersz N0085 G01 X 184 Y 134
N0086 G02 X 194 Y 124 R 10 ( I0 J10) a kurka reszte mi za diably nie chce wyjsc plis prosze o pomoc z gory dziekuje
Wróć do „Siemens Sinumerik CNC”
