Zainstalowałem linuxcnc na laptppie IBM THINK PAD A31. procesor 1.8Ghz i 1 GB ram.
Przy próbie uruchomienia programu linuxcnc mam błąd jak poniżej, co moze byc przyczyna?:
Port lpt ustawiony w biosie na EPP.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.4
Machine configuration directory is '/home/kw/linuxcnc/configs/sim/ngcgui'
Machine configuration file is 'ngcgui_lathe.ini'
INIFILE=/home/kw/linuxcnc/configs/sim/ngcgui/ngcgui_lathe.ini
PARAMETER_FILE=sim-lathe.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Realtime system did not load
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=1502
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1502
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
/usr/bin/linuxcnc: line 433: 1539 Naruszenie ochrony pamięci $HALCMD stop
Unloading hal components
/usr/bin/linuxcnc: line 433: 1540 Naruszenie ochrony pamięci $HALCMD unload all
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
[ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000d2000 - 00000000000d4000 (reserved)
[ 0.000000] BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003ff70000 (usable)
[ 0.000000] BIOS-e820: 000000003ff70000 - 000000003ff7e000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003ff7e000 - 000000003ff80000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003ff80000 - 0000000040000000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff800000 - 0000000100000000 (reserved)
[ 0.000000] DMI present.
[ 0.000000] last_pfn = 0x3ff70 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-DBFFF uncachable
[ 0.000000] DC000-DFFFF write-back
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 03FF80000 mask FFFF80000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009f000 (usable)
[ 0.000000] modified: 000000000009f000 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000d2000 - 00000000000d4000 (reserved)
[ 0.000000] modified: 00000000000dc000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000003ff70000 (usable)
[ 0.000000] modified: 000000003ff70000 - 000000003ff7e000 (ACPI data)
[ 0.000000] modified: 000000003ff7e000 - 000000003ff80000 (ACPI NVS)
[ 0.000000] modified: 000000003ff80000 - 0000000040000000 (reserved)
[ 0.000000] modified: 00000000ff800000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 7000-c000
[ 0.000000] RAMDISK: 2f34b000 - 2ffd3917
[ 0.000000] ACPI: RSDP 000f7060 00024 (v02 IBM )
[ 0.000000] ACPI: XSDT 3ff72c6d 00044 (v01 IBM TP-1G 00001130 LTP 00000000)
[ 0.000000] ACPI: FACP 3ff72d00 00081 (v01 IBM TP-1G 00001130 IBM 00000001)
[ 0.000000] ACPI: DSDT 3ff72de7 0B06F (v01 IBM TP-1G 00001130 MSFT 0100000D)
[ 0.000000] ACPI: FACS 3ff7f000 00040
[ 0.000000] ACPI: SSDT 3ff72db4 00033 (v01 IBM TP-1G 00001130 MSFT 0100000D)
[ 0.000000] ACPI: ECDT 3ff7de56 00052 (v01 IBM TP-1G 00001130 IBM 00000001)
[ 0.000000] ACPI: BOOT 3ff7dfd8 00028 (v01 IBM TP-1G 00001130 LTP 00000001)
[ 0.000000] 135MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] node 0 low ram: 00000000 - 377fe000
[ 0.000000] node 0 bootmap 00008000 - 0000ef00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [002f34b000 - 002ffd3917] RAMDISK ==> [002f34b000 - 002ffd3917]
[ 0.000000] #5 [000009f000 - 0000100000] BIOS reserved ==> [000009f000 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b4128] BRK ==> [00008b1000 - 00008b4128]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000f000] BOOTMAP ==> [0000008000 - 000000f000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003ff70
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003ff70
[ 0.000000] On node 0 totalpages: 261899
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 271 pages used for memmap
[ 0.000000] HighMem zone: 34403 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:bf800000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1c00000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259852
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=1b76ab29-1230-4ce3-a9ac-fba7d1240f8f ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 5240000 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003ff70)
[ 0.000000] Memory: 1012152k/1048000k available (4539k kernel code, 34968k reserved, 1928k data, 620k init, 138696k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1198.878 MHz processor.
[ 0.008011] Calibrating delay loop (skipped), value calculated using timer frequency.. 2397.75 BogoMIPS (lpj=4795512)
[ 0.008065] Security Framework initialized
[ 0.008127] AppArmor: AppArmor initialized
[ 0.008152] Mount-cache hash table entries: 512
[ 0.008531] Initializing cgroup subsys ns
[ 0.008545] Initializing cgroup subsys cpuacct
[ 0.008560] Initializing cgroup subsys memory
[ 0.008591] Initializing cgroup subsys devices
[ 0.008601] Initializing cgroup subsys freezer
[ 0.008609] Initializing cgroup subsys net_cls
[ 0.008673] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.008686] CPU: L2 cache: 512K
[ 0.008695] CPU: Hyper-Threading is disabled
[ 0.008706] mce: CPU supports 4 MCE banks
[ 0.008745] Performance Events: no PMU driver, software events only.
[ 0.008767] Checking 'hlt' instruction... OK.
[ 0.026252] SMP alternatives: switching to UP code
[ 0.053236] Freeing SMP alternatives: 31k freed
[ 0.053280] ACPI: Core revision 20090903
[ 0.093090] ACPI: setting ELCR to 0200 (from 0800)
[ 0.096027] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.096044] ftrace: allocating 21003 entries in 42 pages
[ 0.122273] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.122283] weird, boot CPU (#0) not listed by the BIOS.
[ 0.122288] SMP motherboard not detected.
[ 0.122294] Local APIC not detected. Using dummy APIC emulation.
[ 0.122300] SMP disabled
[ 0.122678] Brought up 1 CPUs
[ 0.122686] Total of 1 processors activated (2397.75 BogoMIPS).
[ 0.123069] CPU0 attaching NULL sched-domain.
[ 0.123393] devtmpfs: initialized
[ 0.124330] regulator: core version 0.5
[ 0.124462] NET: Registered protocol family 16
[ 0.124786] EISA bus registered
[ 0.124808] ACPI: bus type pci registered
[ 0.125041] PCI: PCI BIOS revision 2.10 entry at 0xfd8fe, last bus=8
[ 0.125049] PCI: Using configuration type 1 for base access
[ 0.127357] bio: create slab <bio-0> at 0
[ 0.130377] ACPI: EC: EC description table is found, configuring boot EC
[ 0.154152] ACPI: Interpreter enabled
[ 0.154162] ACPI: (supports S0 S5)
[ 0.154195] ACPI: Using PIC for interrupt routing
[ 0.173409] ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
[ 0.173533] ACPI: Power Resource [PUBS] (on)
[ 0.176122] ACPI: ACPI Dock Station Driver: 1 docks/bays found
[ 0.176196] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.176303] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xe0000000-0xe3ffffff]
[ 0.176550] pci 0000:00:1d.0: reg 20 io port: [0x1800-0x181f]
[ 0.176659] pci 0000:00:1d.1: reg 20 io port: [0x1820-0x183f]
[ 0.176762] pci 0000:00:1d.2: reg 20 io port: [0x1840-0x185f]
[ 0.176952] pci 0000:00:1f.0: quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
[ 0.176963] pci 0000:00:1f.0: quirk: region 1180-11bf claimed by ICH4 GPIO
[ 0.177013] pci 0000:00:1f.1: reg 10 io port: [0x1f0-0x1f7]
[ 0.177028] pci 0000:00:1f.1: reg 14 io port: [0x3f4-0x3f7]
[ 0.177043] pci 0000:00:1f.1: reg 18 io port: [0x170-0x177]
[ 0.177058] pci 0000:00:1f.1: reg 1c io port: [0x374-0x377]
[ 0.177073] pci 0000:00:1f.1: reg 20 io port: [0x1860-0x186f]
[ 0.177089] pci 0000:00:1f.1: reg 24 32bit mmio: [0x000000-0x0003ff]
[ 0.177185] pci 0000:00:1f.3: reg 20 io port: [0x1880-0x189f]
[ 0.177255] pci 0000:00:1f.5: reg 10 io port: [0x1c00-0x1cff]
[ 0.177272] pci 0000:00:1f.5: reg 14 io port: [0x18c0-0x18ff]
[ 0.177367] pci 0000:00:1f.6: reg 10 io port: [0x2400-0x24ff]
[ 0.177382] pci 0000:00:1f.6: reg 14 io port: [0x2000-0x207f]
[ 0.177511] pci 0000:01:00.0: reg 10 32bit mmio pref: [0xe8000000-0xefffffff]
[ 0.177526] pci 0000:01:00.0: reg 14 io port: [0x3000-0x30ff]
[ 0.177540] pci 0000:01:00.0: reg 18 32bit mmio: [0xd0100000-0xd010ffff]
[ 0.177572] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.177614] pci 0000:01:00.0: supports D1 D2
[ 0.177687] pci 0000:00:01.0: bridge io port: [0x3000-0x3fff]
[ 0.177697] pci 0000:00:01.0: bridge 32bit mmio: [0xd0100000-0xd01fffff]
[ 0.177707] pci 0000:00:01.0: bridge 32bit mmio pref: [0xe8000000-0xefffffff]
[ 0.177775] pci 0000:02:00.0: reg 10 32bit mmio: [0x50000000-0x50000fff]
[ 0.177810] pci 0000:02:00.0: supports D1 D2
[ 0.177817] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.177827] pci 0000:02:00.0: PME# disabled
[ 0.177889] pci 0000:02:00.1: reg 10 32bit mmio: [0x50100000-0x50100fff]
[ 0.177925] pci 0000:02:00.1: supports D1 D2
[ 0.177931] pci 0000:02:00.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.177941] pci 0000:02:00.1: PME# disabled
[ 0.178029] pci 0000:02:08.0: reg 10 32bit mmio: [0xd0200000-0xd0200fff]
[ 0.178044] pci 0000:02:08.0: reg 14 io port: [0x8000-0x803f]
[ 0.178117] pci 0000:02:08.0: supports D1 D2
[ 0.178124] pci 0000:02:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.178134] pci 0000:02:08.0: PME# disabled
[ 0.178195] pci 0000:00:1e.0: transparent bridge
[ 0.178206] pci 0000:00:1e.0: bridge io port: [0x4000-0x8fff]
[ 0.178217] pci 0000:00:1e.0: bridge 32bit mmio: [0xd0200000-0xdfffffff]
[ 0.178229] pci 0000:00:1e.0: bridge 32bit mmio pref: [0xf0000000-0xf7ffffff]
[ 0.178306] pci_bus 0000:00: on NUMA node 0
[ 0.178318] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.178452] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGP_._PRT]
[ 0.178534] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.186905] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.187359] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.187806] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.188280] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.188724] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.189112] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11) *0, disabled.
[ 0.189504] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11) *0, disabled.
[ 0.189902] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 11) *0, disabled.
[ 0.190256] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.190269] vgaarb: loaded
[ 0.190632] SCSI subsystem initialized
[ 0.190806] libata version 3.00 loaded.
[ 0.191010] usbcore: registered new interface driver usbfs
[ 0.191050] usbcore: registered new interface driver hub
[ 0.191125] usbcore: registered new device driver usb
[ 0.191504] ACPI: WMI: Mapper loaded
[ 0.191512] PCI: Using ACPI for IRQ routing
[ 0.192104] NetLabel: Initializing
[ 0.192112] NetLabel: domain hash size = 128
[ 0.192117] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.192156] NetLabel: unlabeled traffic allowed by default
[ 0.192243] Switching to clocksource tsc
[ 0.197094] AppArmor: AppArmor Filesystem Enabled
[ 0.197129] pnp: PnP ACPI init
[ 0.197167] ACPI: bus type pnp registered
[ 0.205632] pnp: PnP ACPI: found 13 devices
[ 0.205641] ACPI: ACPI bus type pnp unregistered
[ 0.205652] PnPBIOS: Disabled by ACPI PNP
[ 0.205687] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.205697] system 00:00: iomem range 0xc0000-0xc3fff could not be reserved
[ 0.205707] system 00:00: iomem range 0xc4000-0xc7fff could not be reserved
[ 0.205716] system 00:00: iomem range 0xc8000-0xcbfff could not be reserved
[ 0.205725] system 00:00: iomem range 0xcc000-0xcffff could not be reserved
[ 0.205734] system 00:00: iomem range 0xd0000-0xd3fff could not be reserved
[ 0.205743] system 00:00: iomem range 0xdc000-0xdffff could not be reserved
[ 0.205753] system 00:00: iomem range 0xe0000-0xe3fff could not be reserved
[ 0.205762] system 00:00: iomem range 0xe4000-0xe7fff could not be reserved
[ 0.205771] system 00:00: iomem range 0xe8000-0xebfff could not be reserved
[ 0.205780] system 00:00: iomem range 0xec000-0xeffff could not be reserved
[ 0.205789] system 00:00: iomem range 0xf0000-0xfffff could not be reserved
[ 0.205799] system 00:00: iomem range 0x100000-0x3fffffff could not be reserved
[ 0.205808] system 00:00: iomem range 0xfec00000-0xffffffff could not be reserved
[ 0.205832] system 00:02: ioport range 0x1000-0x107f has been reserved
[ 0.205842] system 00:02: ioport range 0x1180-0x11bf has been reserved
[ 0.205853] system 00:02: ioport range 0x15e0-0x15ef has been reserved
[ 0.205862] system 00:02: ioport range 0x1600-0x167f has been reserved
[ 0.240936] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.240947] pci 0000:00:01.0: IO window: 0x3000-0x3fff
[ 0.240958] pci 0000:00:01.0: MEM window: 0xd0100000-0xd01fffff
[ 0.240969] pci 0000:00:01.0: PREFETCH window: 0xe8000000-0xefffffff
[ 0.240991] pci 0000:02:00.0: CardBus bridge, secondary bus 0000:03
[ 0.240999] pci 0000:02:00.0: IO window: 0x004000-0x0040ff
[ 0.241009] pci 0000:02:00.0: IO window: 0x004400-0x0044ff
[ 0.241020] pci 0000:02:00.0: PREFETCH window: 0xf0000000-0xf3ffffff
[ 0.241031] pci 0000:02:00.0: MEM window: 0xd4000000-0xd7ffffff
[ 0.241042] pci 0000:02:00.1: CardBus bridge, secondary bus 0000:07
[ 0.241049] pci 0000:02:00.1: IO window: 0x004800-0x0048ff
[ 0.241059] pci 0000:02:00.1: IO window: 0x004c00-0x004cff
[ 0.241070] pci 0000:02:00.1: PREFETCH window: 0xf4000000-0xf7ffffff
[ 0.241081] pci 0000:02:00.1: MEM window: 0xd8000000-0xdbffffff
[ 0.241091] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[ 0.241100] pci 0000:00:1e.0: IO window: 0x4000-0x8fff
[ 0.241113] pci 0000:00:1e.0: MEM window: 0xd0200000-0xdfffffff
[ 0.241125] pci 0000:00:1e.0: PREFETCH window: 0xf0000000-0xf7ffffff
[ 0.241161] pci 0000:00:1e.0: setting latency timer to 64
[ 0.241961] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
[ 0.241970] PCI: setting IRQ 11 as level-triggered
[ 0.241981] pci 0000:02:00.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 0.242731] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
[ 0.242741] pci 0000:02:00.1: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 0.242757] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.242766] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.242774] pci_bus 0000:01: resource 0 io: [0x3000-0x3fff]
[ 0.242781] pci_bus 0000:01: resource 1 mem: [0xd0100000-0xd01fffff]
[ 0.242789] pci_bus 0000:01: resource 2 pref mem [0xe8000000-0xefffffff]
[ 0.242797] pci_bus 0000:02: resource 0 io: [0x4000-0x8fff]
[ 0.242805] pci_bus 0000:02: resource 1 mem: [0xd0200000-0xdfffffff]
[ 0.242812] pci_bus 0000:02: resource 2 pref mem [0xf0000000-0xf7ffffff]
[ 0.242820] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.242827] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.242835] pci_bus 0000:03: resource 0 io: [0x4000-0x40ff]
[ 0.242842] pci_bus 0000:03: resource 1 io: [0x4400-0x44ff]
[ 0.242850] pci_bus 0000:03: resource 2 pref mem [0xf0000000-0xf3ffffff]
[ 0.242858] pci_bus 0000:03: resource 3 mem: [0xd4000000-0xd7ffffff]
[ 0.242866] pci_bus 0000:07: resource 0 io: [0x4800-0x48ff]
[ 0.242873] pci_bus 0000:07: resource 1 io: [0x4c00-0x4cff]
[ 0.242880] pci_bus 0000:07: resource 2 pref mem [0xf4000000-0xf7ffffff]
[ 0.242888] pci_bus 0000:07: resource 3 mem: [0xd8000000-0xdbffffff]
[ 0.242982] NET: Registered protocol family 2
[ 0.243231] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.244150] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.245672] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.246624] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.246633] TCP reno registered
[ 0.246922] NET: Registered protocol family 1
[ 0.247065] pci 0000:01:00.0: Boot video device
[ 0.247122] pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.247347] Simple Boot Flag at 0x35 set to 0x1
[ 0.247605] Scanning for low memory corruption every 60 seconds
[ 0.247915] audit: initializing netlink socket (disabled)
[ 0.247945] type=2000 audit(1407944636.247:1): initialized
[ 0.263696] Trying to unpack rootfs image as initramfs...
[ 0.280836] highmem bounce pool size: 64 pages
[ 0.280855] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.291928] VFS: Disk quotas dquot_6.5.2
[ 0.292142] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.293832] fuse init (API version 7.13)
[ 0.294083] msgmni has been set to 1706
[ 0.300528] alg: No test for stdrng (krng)
[ 0.300760] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.300771] io scheduler noop registered
[ 0.300777] io scheduler anticipatory registered
[ 0.300783] io scheduler deadline registered
[ 0.300906] io scheduler cfq registered (default)
[ 0.301201] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.301273] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.301474] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.301809] ACPI: Lid Switch [LID]
[ 0.301947] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.301960] ACPI: Sleep Button [SLPB]
[ 0.302115] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.302124] ACPI: Power Button [PWRF]
[ 0.308515] isapnp: Scanning for PnP cards...
[ 0.314509] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.316583] serial 00:0a: activated
[ 0.316787] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a NS16550A
[ 0.317019] serial 0000:00:1f.6: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 0.317038] serial 0000:00:1f.6: PCI INT B disabled
[ 0.372288] brd: module loaded
[ 0.373648] loop: module loaded
[ 0.373938] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.374216] ata_piix 0000:00:1f.1: version 2.13
[ 0.374245] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[ 0.375095] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 0.375107] ata_piix 0000:00:1f.1: PCI INT A -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 0.375200] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.375416] scsi0 : ata_piix
[ 0.380230] scsi1 : ata_piix
[ 0.383234] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1860 irq 14
[ 0.383244] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1868 irq 15
[ 0.384465] Fixed MDIO Bus: probed
[ 0.384575] PPP generic driver version 2.4.2
[ 0.384717] tun: Universal TUN/TAP device driver, 1.6
[ 0.384724] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 0.384972] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.385029] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.385068] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.385824] uhci_hcd 0000:00:1d.0: power state changed by ACPI to D0
[ 0.385847] uhci_hcd 0000:00:1d.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 0.385867] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.385876] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.386004] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 0.386054] uhci_hcd 0000:00:1d.0: irq 11, io base 0x00001800
[ 0.386323] usb usb1: configuration #1 chosen from 1 choice
[ 0.386406] hub 1-0:1.0: USB hub found
[ 0.386430] hub 1-0:1.0: 2 ports detected
[ 0.392606] uhci_hcd 0000:00:1d.1: power state changed by ACPI to D0
[ 0.393396] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 0.393409] uhci_hcd 0000:00:1d.1: PCI INT B -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.393431] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.393441] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.393628] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
[ 0.393677] uhci_hcd 0000:00:1d.1: irq 11, io base 0x00001820
[ 0.393933] usb usb2: configuration #1 chosen from 1 choice
[ 0.394021] hub 2-0:1.0: USB hub found
[ 0.394044] hub 2-0:1.0: 2 ports detected
[ 0.394164] uhci_hcd 0000:00:1d.2: PCI INT C -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 0.394185] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.394193] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.394302] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
[ 0.394342] uhci_hcd 0000:00:1d.2: irq 11, io base 0x00001840
[ 0.394567] usb usb3: configuration #1 chosen from 1 choice
[ 0.394648] hub 3-0:1.0: USB hub found
[ 0.394669] hub 3-0:1.0: 2 ports detected
[ 0.394922] PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 0.408673] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.408703] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.409136] mice: PS/2 mouse device common for all mice
[ 0.409511] rtc_cmos 00:06: RTC can wake from S4
[ 0.409632] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 0.409666] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 0.409984] device-mapper: uevent: version 1.0.3
[ 0.410321] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: [email protected]
[ 0.412816] device-mapper: multipath: version 1.1.0 loaded
[ 0.412827] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.414220] EISA: Probing bus 0 at eisa.0
[ 0.414235] Cannot allocate resource for EISA slot 1
[ 0.414245] Cannot allocate resource for EISA slot 2
[ 0.414251] Cannot allocate resource for EISA slot 3
[ 0.414258] Cannot allocate resource for EISA slot 4
[ 0.414264] Cannot allocate resource for EISA slot 5
[ 0.414271] Cannot allocate resource for EISA slot 6
[ 0.414277] Cannot allocate resource for EISA slot 7
[ 0.414283] Cannot allocate resource for EISA slot 8
[ 0.414289] EISA: Detected 0 cards.
[ 0.414297] cpuidle: using governor ladder
[ 0.414303] cpuidle: using governor menu
[ 0.415472] TCP cubic registered
[ 0.415875] NET: Registered protocol family 10
[ 0.416988] lo: Disabled Privacy Extensions
[ 0.417752] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.418415] NET: Registered protocol family 17
[ 0.418490] Using IPI No-Shortcut mode
[ 0.418713] registered taskstats version 1
[ 0.419182] rtc_cmos 00:06: setting system clock to 2014-08-13 15:43:57 UTC (1407944637)
[ 0.419193] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.419198] EDD information not available.
[ 0.580909] ata2.00: ATAPI: MATSHITADVD-ROM SR-8177, NB21, max UDMA/33
[ 0.581140] ata1.00: ATA-5: IC25N040ATCS04-0, CA4OA71A, max UDMA/100
[ 0.581150] ata1.00: 78140160 sectors, multi 16: LBA
[ 0.588822] ata2.00: configured for UDMA/33
[ 0.597555] ata1.00: configured for UDMA/100
[ 0.747359] usb 2-2: new full speed USB device using uhci_hcd and address 2
[ 1.011419] isapnp: No Plug & Play device found
[ 1.011804] scsi 0:0:0:0: Direct-Access ATA IC25N040ATCS04-0 CA4O PQ: 0 ANSI: 5
[ 1.012209] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.012601] sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 1.012756] sd 0:0:0:0: [sda] Write Protect is off
[ 1.012766] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.012845] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.013460] sda:
[ 1.014682] scsi 1:0:0:0: CD-ROM MATSHITA DVD-ROM SR-8177 NB21 PQ: 0 ANSI: 5
[ 1.021910] sr0: scsi3-mmc drive: 24x/24x cd/rw xa/form2 cdda tray
[ 1.021923] Uniform CD-ROM driver Revision: 3.20
[ 1.022208] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.022388] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.031254] usb 2-2: configuration #1 chosen from 1 choice
[ 1.040867] sda1 sda2 < sda5 >
[ 1.073967] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.552722] Freeing initrd memory: 12834k freed
[ 1.577719] Freeing unused kernel memory: 620k freed
[ 1.578955] Write protecting the kernel text: 4540k
[ 1.579018] Write protecting the kernel read-only data: 1668k
[ 1.646632] udev: starting version 151
[ 2.283844] Linux agpgart interface v0.103
[ 2.299587] Floppy drive(s): fd0 is 1.44M
[ 2.365258] FDC 0 is a National Semiconductor PC87306
[ 2.377568] [drm] Initialized drm 1.1.0 20060810
[ 2.385733] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 2.385743] e100: Copyright(c) 1999-2006 Intel Corporation
[ 2.386680] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 11
[ 2.386694] e100 0000:02:08.0: PCI INT A -> Link[LNKE] -> GSI 11 (level, low) -> IRQ 11
[ 2.412227] e100 0000:02:08.0: PME# disabled
[ 2.425960] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:02/LNXVIDEO:00/input/input5
[ 2.426198] ACPI: Video Device [VID] (multi-head: yes rom: no post: no)
[ 2.439378] agpgart-intel 0000:00:00.0: Intel 845G Chipset
[ 2.445084] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xe0000000
[ 2.464344] usbcore: registered new interface driver hiddev
[ 2.469455] input: HID-compliant Mouse HID-compliant Mouse as /devices/pci0000:00/0000:00:1d.1/usb2/2-2/2-2:1.0/input/input6
[ 2.470068] generic-usb 0003:0D8D:0516.0001: input,hidraw0: USB HID v1.10 Mouse [HID-compliant Mouse HID-compliant Mouse] on usb-0000:00:1d.1-2/input0
[ 2.470145] usbcore: registered new interface driver usbhid
[ 2.470777] usbhid: v2.6:USB HID core driver
[ 2.480656] e100: eth0: e100_probe: addr 0xd0200000, irq 11, MAC addr 00:02:8a:35:91:2b
[ 2.600454] [drm] radeon defaulting to kernel modesetting.
[ 2.600464] [drm] radeon kernel modesetting enabled.
[ 2.600715] radeon 0000:01:00.0: power state changed by ACPI to D0
[ 2.600742] radeon 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 2.606793] [drm] radeon: Initializing kernel modesetting.
[ 2.606964] [drm] register mmio base: 0xD0100000
[ 2.606971] [drm] register mmio size: 65536
[ 2.607340] [drm] GPU reset succeed (RBBM_STATUS=0x00000140)
[ 2.607381] agpgart-intel 0000:00:00.0: AGP 2.0 bridge
[ 2.607416] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
[ 2.607467] radeon 0000:01:00.0: putting AGP V2 device into 4x mode
[ 2.607506] [drm] radeon: VRAM 64M
[ 2.607512] [drm] radeon: VRAM from 0x00000000 to 0x03FFFFFF
[ 2.607518] [drm] radeon: GTT 64M
[ 2.607524] [drm] radeon: GTT from 0xE0000000 to 0xE3FFFFFF
[ 2.607566] [drm] radeon: irq initialized.
[ 2.607734] [drm] Detected VRAM RAM=64M, BAR=128M
[ 2.607744] [drm] RAM width 128bits DDR
[ 2.607912] [TTM] Zone kernel: Available graphics memory: 443708 kiB.
[ 2.607920] [TTM] Zone highmem: Available graphics memory: 513056 kiB.
[ 2.607959] [drm] radeon: 32M of VRAM memory ready
[ 2.607968] [drm] radeon: 64M of GTT memory ready.
[ 2.608297] [drm] radeon: cp idle (0x00008383)
[ 2.608383] [drm] Loading R100 Microcode
[ 2.608949] platform radeon_cp.0: firmware: requesting radeon/R100_cp.bin
[ 2.634463] [drm] radeon: ring at 0x00000000E0000000
[ 2.634494] [drm] ring test succeeded in 1 usecs
[ 2.641835] [drm] radeon: ib pool ready.
[ 2.642010] [drm] ib test succeeded in 0 usecs
[ 2.642755] [drm] DFP table revision: 2
[ 2.643281] [drm] Panel ID String: Samsung LTN150P1-L02
[ 2.643291] [drm] Panel Size 1400x1050
[ 2.643567] [drm] Default TV standard: NTSC
[ 2.643575] [drm] 27.000000000 MHz TV ref clk
[ 2.643580] [drm] No TV DAC info found in BIOS
[ 2.643589] [drm] Default TV standard: NTSC
[ 2.643593] [drm] 27.000000000 MHz TV ref clk
[ 2.643752] [drm] Radeon Display Connectors
[ 2.643760] [drm] Connector 0:
[ 2.643765] [drm] VGA
[ 2.643773] [drm] DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[ 2.643778] [drm] Encoders:
[ 2.643783] [drm] CRT1: INTERNAL_DAC1
[ 2.643789] [drm] Connector 1:
[ 2.643793] [drm] DVI-D
[ 2.643798] [drm] HPD1
[ 2.643805] [drm] DDC: 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[ 2.643810] [drm] Encoders:
[ 2.643815] [drm] DFP1: INTERNAL_TMDS1
[ 2.643820] [drm] Connector 2:
[ 2.643825] [drm] LVDS
[ 2.643829] [drm] Encoders:
[ 2.643834] [drm] LCD1: INTERNAL_LVDS
[ 2.643839] [drm] Connector 3:
[ 2.643844] [drm] S-video
[ 2.643848] [drm] Encoders:
[ 2.643853] [drm] TV1: INTERNAL_DAC2
[ 2.677421] [drm] fb mappable at 0xE8040000
[ 2.677429] [drm] vram apper at 0xE8000000
[ 2.677435] [drm] size 1478400
[ 2.677440] [drm] fb depth is 8
[ 2.677445] [drm] pitch is 1408
[ 2.677762] fb0: radeondrmfb frame buffer device
[ 2.677769] registered panic notifier
[ 2.677785] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[ 2.685175] vga16fb: initializing
[ 2.685189] vga16fb: mapped to 0xc00a0000
[ 2.685200] vga16fb: not registering due to another framebuffer present
[ 2.750559] Console: switching to colour frame buffer device 175x65
[ 3.525614] xor: automatically using best checksumming function: pIII_sse
[ 3.544034] pIII_sse : 1553.000 MB/sec
[ 3.544042] xor: using function: pIII_sse (1553.000 MB/sec)
[ 3.581338] device-mapper: dm-raid45: initialized v0.2594b
[ 3.879556] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 7.121218] Adding 1648632k swap on /dev/sda5. Priority:-1 extents:1 across:1648632k
[ 7.625411] udev: starting version 151
[ 9.114270] Non-volatile memory driver v1.3
[ 9.117281] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 9.132468] intel_rng: FWH not detected
[ 9.346626] parport_pc 00:0b: reported by Plug and Play ACPI
[ 9.346672] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 9.422926] psmouse serio1: ID: 10 00 64
[ 9.491468] lp0: using parport0 (interrupt-driven).
[ 9.622932] ppdev: user-space parallel port driver
[ 9.639113] yenta_cardbus 0000:02:00.0: CardBus bridge found [1014:0185]
[ 9.764554] yenta_cardbus 0000:02:00.0: ISA IRQ mask 0x0438, PCI irq 11
[ 9.764566] yenta_cardbus 0000:02:00.0: Socket status: 30000006
[ 9.764586] yenta_cardbus 0000:02:00.0: pcmcia: parent PCI bridge I/O window: 0x4000 - 0x8fff
[ 9.764598] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x4000-0x8fff: clean.
[ 9.769889] yenta_cardbus 0000:02:00.0: pcmcia: parent PCI bridge Memory window: 0xd0200000 - 0xdfffffff
[ 9.769902] yenta_cardbus 0000:02:00.0: pcmcia: parent PCI bridge Memory window: 0xf0000000 - 0xf7ffffff
[ 9.774085] yenta_cardbus 0000:02:00.1: CardBus bridge found [1014:0185]
[ 9.787319] irda_init()
[ 9.787356] NET: Registered protocol family 23
[ 9.800585] IBM TrackPoint firmware: 0x0e, buttons: 3/3
[ 9.823072] input: TPPS/2 IBM TrackPoint as /devices/platform/i8042/serio1/input/input7
[ 9.900513] yenta_cardbus 0000:02:00.1: ISA IRQ mask 0x0438, PCI irq 11
[ 9.900525] yenta_cardbus 0000:02:00.1: Socket status: 30000410
[ 9.900544] yenta_cardbus 0000:02:00.1: pcmcia: parent PCI bridge I/O window: 0x4000 - 0x8fff
[ 9.900555] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x4000-0x8fff: clean.
[ 9.905791] yenta_cardbus 0000:02:00.1: pcmcia: parent PCI bridge Memory window: 0xd0200000 - 0xdfffffff
[ 9.905801] yenta_cardbus 0000:02:00.1: pcmcia: parent PCI bridge Memory window: 0xf0000000 - 0xf7ffffff
[ 10.222220] nsc-ircc 00:0c: activated
[ 10.222235] nsc_ircc_pnp_probe() : From PnP, found firbase 0x2F8 ; irq 3 ; dma 1.
[ 10.222439] nsc-ircc, chip->init
[ 10.222456] nsc-ircc, Found chip at base=0x02e
[ 10.222488] nsc-ircc, driver loaded (Dag Brattli)
[ 10.230862] IrDA: Registered device irda0
[ 10.230875] nsc-ircc, Using dongle: IBM31T1100 or Temic TFDS6000/TFDS6500
[ 10.566344] pcmcia_socket pcmcia_socket1: pccard: PCMCIA card inserted into slot 1
[ 10.784059] pcmcia_socket pcmcia_socket1: cs: memory probe 0xf0000000-0xf7ffffff: excluding 0xf0000000-0xf7ffffff
[ 10.784116] pcmcia_socket pcmcia_socket1: cs: memory probe 0xd0200000-0xdfffffff: excluding 0xd0200000-0xd11fffff 0xd1a00000-0xd21fffff 0xd2a00000-0xd31fffff 0xd3a00000-0xdc1fffff 0xdca00000-0xdd1fffff 0xdda00000-0xde1fffff 0xdea00000-0xdf1fffff 0xdfa00000-0xe01fffff
[ 10.790506] pcmcia 1.0: pcmcia: registering new device pcmcia1.0
[ 11.016094] eth1: Asix AX88790: io 0x4100, irq 3, hw_addr 00:10:60:f3:48:ca
[ 11.294086] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3af: clean.
[ 11.295585] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7
[ 11.296718] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[ 11.298214] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7
[ 11.298904] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 11.299497] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 11.300618] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 11.303237] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x820-0x8ff: clean.
[ 11.303891] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcf7: clean.
[ 11.304949] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
[ 11.766403] type=1505 audit(1407944648.846:2): operation="profile_load" pid=589 name="/sbin/dhclient3"
[ 11.767758] type=1505 audit(1407944648.846:3): operation="profile_load" pid=589 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 11.768362] type=1505 audit(1407944648.848:4): operation="profile_replace" pid=593 name="/sbin/dhclient3"
[ 11.769739] type=1505 audit(1407944648.848:5): operation="profile_replace" pid=593 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 11.770501] type=1505 audit(1407944648.848:6): operation="profile_load" pid=593 name="/usr/lib/connman/scripts/dhclient-script"
[ 11.771625] type=1505 audit(1407944648.848:7): operation="profile_replace" pid=620 name="/sbin/dhclient3"
[ 11.773062] type=1505 audit(1407944648.852:8): operation="profile_replace" pid=620 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 11.773832] type=1505 audit(1407944648.852:9): operation="profile_replace" pid=620 name="/usr/lib/connman/scripts/dhclient-script"
[ 11.774895] type=1505 audit(1407944648.852:10): operation="profile_replace" pid=651 name="/sbin/dhclient3"
[ 11.776319] type=1505 audit(1407944648.856:11): operation="profile_replace" pid=651 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 12.457935] thinkpad_acpi: ThinkPad ACPI Extras v0.24
[ 12.457945] thinkpad_acpi: http://ibm-acpi.sf.net/
[ 12.457952] thinkpad_acpi: ThinkPad BIOS 1GET41WW (1.13 ), EC 1GHT14WW-1.01
[ 12.457959] thinkpad_acpi: WARNING: Outdated ThinkPad BIOS/EC firmware
[ 12.457966] thinkpad_acpi: WARNING: This firmware may be missing critical bug fixes and/or important features
[ 12.509738] Registered led device: tpacpi::thinklight
[ 12.511081] Registered led device: tpacpi::power
[ 12.514399] Registered led device: tpacpi::standby
[ 12.546830] thinkpad_acpi: Console audio control enabled, mode: monitor (read only)
[ 12.567360] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input8
[ 12.926936] Intel ICH 0000:00:1f.5: PCI INT B -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 12.926972] Intel ICH 0000:00:1f.5: setting latency timer to 64
[ 13.344074] intel8x0_measure_ac97_clock: measured 54778 usecs (2632 samples)
[ 13.344085] intel8x0: clocking to 48000
[ 16.825454] __ratelimit: 33 callbacks suppressed
[ 16.825465] type=1505 audit(1407944653.904:23): operation="profile_load" pid=790 name="/usr/sbin/tcpdump"
[ 17.730406] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.016032] ------------[ cut here ]------------
[ 18.016059] WARNING: at /home/moses/Projects/emc2/ubuntu-lucid/net/sched/sch_generic.c:261 dev_watchdog+0x1ee/0x200()
[ 18.016068] Hardware name: 2652AG2
[ 18.016075] NETDEV WATCHDOG: eth1 (axnet_cs): transmit queue 0 timed out
[ 18.016082] Modules linked in: dm_crypt snd_intel8x0 snd_ac97_codec ac97_bus snd_pcm_oss thinkpad_acpi snd_mixer_oss snd_pcm snd_seq_dummy snd_seq_oss snd_seq_midi snd_rawmidi axnet_cs snd_seq_midi_event snd_seq pcmcia nsc_ircc snd_timer snd_seq_device irda yenta_socket ppdev snd rsrc_nonstatic lp parport_pc crc_ccitt soundcore pcmcia_core led_class psmouse snd_page_alloc nvram shpchp serio_raw parport dm_raid45 xor fbcon tileblit font bitblit softcursor vga16fb vgastate radeon ttm drm_kms_helper usbhid intel_agp video e100 drm hid floppy i2c_algo_bit mii output agpgart
[ 18.016235] Pid: 0, comm: swapper Not tainted 2.6.32-122-rtai #rtai
[ 18.016242] Call Trace:
[ 18.016259] [<c0143112>] warn_slowpath_common+0x72/0xa0
[ 18.016273] [<c04b80de>] ? dev_watchdog+0x1ee/0x200
[ 18.016283] [<c04b80de>] ? dev_watchdog+0x1ee/0x200
[ 18.016293] [<c014318b>] warn_slowpath_fmt+0x2b/0x30
[ 18.016302] [<c04b80de>] dev_watchdog+0x1ee/0x200
[ 18.016316] [<c016de0e>] ? tick_program_event+0x2e/0x40
[ 18.016330] [<c0151e68>] run_timer_softirq+0x138/0x2b0
[ 18.016340] [<c04b7ef0>] ? dev_watchdog+0x0/0x200
[ 18.016352] [<c0149b07>] __do_softirq+0x97/0x1c0
[ 18.016361] [<c0164c36>] ? sched_clock_tick+0x76/0xb0
[ 18.016371] [<c014a50d>] do_softirq+0x6d/0x80
[ 18.016381] [<c014a665>] irq_exit+0x65/0x70
[ 18.016394] [<c056e01d>] do_IRQ+0x5d/0xe0
[ 18.016403] [<c056dfc0>] ? do_IRQ+0x0/0xe0
[ 18.016415] [<c0198847>] __ipipe_sync_stage+0x1f7/0x1fc
[ 18.016424] [<c056dfc0>] ? do_IRQ+0x0/0xe0
[ 18.016436] [<c01100e0>] ? __hw_perf_event_init+0x140/0x300
[ 18.016446] [<c019884c>] ? __xirq_end+0x0/0x57
[ 18.016456] [<c0198c1e>] __ipipe_walk_pipeline+0xde/0xf0
[ 18.016467] [<c0193edf>] ? __ipipe_ack_level_irq+0x1f/0x60
[ 18.016480] [<c011fe1f>] __ipipe_handle_irq+0xef/0x240
[ 18.016489] [<c011fb60>] ? __ipipe_ack_irq+0x0/0x10
[ 18.016499] [<c0103a51>] common_interrupt+0x31/0x40
[ 18.016509] [<c011fd15>] ? __ipipe_halt_root+0x25/0x40
[ 18.016518] [<c0109cb0>] default_idle+0x40/0x90
[ 18.016527] [<c01021c2>] cpu_idle+0xa2/0xe0
[ 18.016539] [<c0558b38>] rest_init+0x58/0x60
[ 18.016553] [<c075192a>] start_kernel+0x393/0x399
[ 18.016562] [<c07513c3>] ? unknown_bootoption+0x0/0x19e
[ 18.016573] [<c07510aa>] i386_start_kernel+0xaa/0xb1
[ 18.016580] ---[ end trace 078701c13cc9e7ad ]---
[ 18.016592] eth1: Tx timed out, lost interrupt? TSR=0x1, ISR=0x42, t=77.
[ 18.700797] eth1: found link beat
[ 18.700809] eth1: autonegotiation complete: 100baseT-FD selected
[ 19.700032] eth1: interrupt(s) dropped!
[ 27.188032] eth1: interrupt(s) dropped!
[ 27.788031] eth1: no IPv6 routers present
[ 49.188053] eth1: interrupt(s) dropped!
[ 53.188034] eth1: interrupt(s) dropped!
[ 75.937299] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 76.948253] halcmd[1539]: segfault at 8 ip 009446bc sp bf9c4540 error 6 in liblinuxcnchal.so.0[93f000+8000]
[ 76.985259] halcmd[1540]: segfault at 8 ip 00f426bc sp bfa318c0 error 6 in liblinuxcnchal.so.0[f3d000+8000]
[ 77.018751] halcmd[1543]: segfault at 8 ip 008006bc sp bf8f39b0 error 6 in liblinuxcnchal.so.0[7fb000+8000]
[ 77.285094] halcmd[1547]: segfault at 8 ip 0029b6bc sp bffaeb00 error 6 in liblinuxcnchal.so.0[296000+8000]
[ 77.505765] halcmd[1551]: segfault at 8 ip 003326bc sp bff67a40 error 6 in liblinuxcnchal.so.0[32d000+8000]
[ 77.727680] halcmd[1555]: segfault at 8 ip 006646bc sp bfb0a000 error 6 in liblinuxcnchal.so.0[65f000+8000]
[ 77.952847] halcmd[1559]: segfault at 8 ip 00fb06bc sp bfd6ce90 error 6 in liblinuxcnchal.so.0[fab000+8000]
[ 78.173763] halcmd[1563]: segfault at 8 ip 00d906bc sp bfcd5ce0 error 6 in liblinuxcnchal.so.0[d8b000+8000]
[ 78.396168] halcmd[1567]: segfault at 8 ip 00e8f6bc sp bfe473a0 error 6 in liblinuxcnchal.so.0[e8a000+8000]
