GRBL alarm 9 przy homingu
pawel039
Post napisał: pawel039 » 11 lut 2017, 16:04
Cześć, tak jak w temacie mam problem z działaniem homingu w moim cnc. Silnik od osi z pracuje po czym zatrzymuje się i wyskakuje alarm 9. Czy wie ktoś jak rozwiązać ten problem?
nie wiem czy potrzebne ale dodam ustawienia grbl;
$0 = 10 (Step pulse time, microseconds)
$1 = 25 (Step idle delay, milliseconds)
$2 = 1 (Step pulse invert, mask)
$3 = 0 (Step direction invert, mask)
$4 = 0 (Invert step enable pin, boolean)
$5 = 0 (Invert limit pins, boolean)
$6 = 0 (Invert probe pin, boolean)
$10 = 1 (Status report options, mask)
$11 = 0.010 (Junction deviation, millimeters)
$12 = 0.002 (Arc tolerance, millimeters)
$13 = 0 (Report in inches, boolean)
$20 = 1 (Soft limits enable, boolean)
$21 = 1 (Hard limits enable, boolean)
$22 = 1 (Homing cycle enable, boolean)
$23 = 0 (Homing direction invert, mask)
$24 = 200.000 (Homing locate feed rate, mm/min)
$25 = 200.000 (Homing search seek rate, mm/min)
$26 = 250 (Homing switch debounce delay, milliseconds)
$27 = 1.000 (Homing switch pull-off distance, millimeters)
$30 = 1000 (Maximum spindle speed, RPM)
$31 = 0 (Minimum spindle speed, RPM)
$32 = 0 (Laser-mode enable, boolean)
$100 = 200.000 (X-axis travel resolution, step/mm)
$101 = 200.000 (Y-axis travel resolution, step/mm)
$102 = 200.000 (Z-axis travel resolution, step/mm)
$110 = 200.000 (X-axis maximum rate, mm/min)
$111 = 200.000 (Y-axis maximum rate, mm/min)
$112 = 200.000 (Z-axis maximum rate, mm/min)
$120 = 20.000 (X-axis acceleration, mm/sec^2)
$121 = 20.000 (Y-axis acceleration, mm/sec^2)
$122 = 20.000 (Z-axis acceleration, mm/sec^2)
$130 = 110.000 (X-axis maximum travel, millimeters)
$131 = 75.000 (Y-axis maximum travel, millimeters)
$132 = 15.000 (Z-axis maximum travel, millimeters)
Wróć do „CNC podstawy”
