Jak usunąć pauzy dziesięcio sekundowe
jarcys
Post napisał: jarcys » 19 sie 2010, 17:24
Witam mam taki mały problem a dokładnie mam płytkę z eagla następnie podaje to PCB gcode do tworzenia g-kod i mam plik ngc zapuszczam to w EMC2 i tu wszystko ładnie, tylko co chwilkę program staje muszę klikać co chwile, proszę o wyjaśnienie jak mam usunąć pauzę dzieśięcio sekundową .
To jest część gkodu
(X/Y/Z home should be at upper left corner of the board, with the tip just touching board)
(Mm, Absolute mode, lift cutter above work, rapid to X/Y home, spindle on.)
G21
G90
G00 Z10.000
G00 X0.000 Y0.000
M00
G00 Z0.000
M00
G00 Z0.500
(Bit changed, zero set.)
G00 Z1.000
G00 X47.998 Y-45.734
G01 Z-0.280000 F150.0
G01 X48.051 Y-45.897 F150.0
G01 X48.078 Y-46.066 F150.0
G01 X48.078 Y-47.914 F150.0
G01 X48.051 Y-48.083 F150.0
G01 X47.998 Y-48.246 F150.0
G01 X47.921 Y-48.399 F150.0
G01 X47.820 Y-48.537 F150.0
G01 X47.699 Y-48.658 F150.0
G01 X47.560 Y-48.759 F150.0
G01 X47.408 Y-48.837 F150.0
G01 X47.245 Y-48.890 F150.0
G01 X47.076 Y-48.916 F150.0
G01 X46.904 Y-48.916 F150.0
G01 X46.735 Y-48.890 F150.0
G01 X46.572 Y-48.837 F150.0
G01 X46.420 Y-48.759 F150.0
G01 X46.281 Y-48.658 F150.0
G01 X46.160 Y-48.537 F150.0
G01 X46.059 Y-48.399 F150.0
G01 X45.982 Y-48.246 F150.0
G01 X45.929 Y-48.083 F150.0
G01 X45.908 Y-47.951 F150.0
G01 X45.625 Y-47.951 F150.0
G01 X44.545 Y-47.951 F150.0
G01 X43.275 Y-47.951 F150.0
G01 X43.085 Y-47.951 F150.0
G01 X42.005 Y-47.951 F150.0
G01 X41.815 Y-47.951 F150.0
G01 X40.545 Y-47.951 F150.0
G01 X40.360 Y-47.914 F150.0
G01 X40.185 Y-47.842 F150.0
G01 X40.027 Y-47.736 F150.0
G01 X39.893 Y-47.603 F150.0
G01 X39.788 Y-47.445 F150.0
G01 X39.716 Y-47.270 F150.0
G01 X39.679 Y-47.085 F150.0
G01 X39.679 Y-46.895 F150.0
G01 X39.679 Y-27.845 F150.0
G01 X39.679 Y-23.258 F150.0
G01 X38.972 Y-22.551 F150.0
G01 X31.655 Y-22.551 F150.0
G01 X31.470 Y-22.514 F150.0
G01 X31.295 Y-22.442 F150.0
G01 X31.137 Y-22.337 F150.0
G01 X31.003 Y-22.203 F150.0
G01 X30.898 Y-22.045 F150.0
G01 X30.826 Y-21.870 F150.0
G01 X30.789 Y-21.685 F150.0
G01 X30.789 Y-21.495 F150.0
G01 X30.789 Y-20.225 F150.0
G01 X30.789 Y-16.908 F150.0
G01 X30.082 Y-16.201 F150.0
G01 X16.605 Y-16.201 F150.0
G01 X16.415 Y-16.201 F150.0
G01 X16.230 Y-16.164 F150.0
G01 X16.055 Y-16.092 F150.0
G01 X15.897 Y-15.987 F150.0
G01 X15.763 Y-15.853 F150.0
G01 X15.658 Y-15.695 F150.0
G01 X15.586 Y-15.520 F150.0
G01 X15.549 Y-15.335 F150.0
G01 X15.549 Y-8.185 F150.0
G01 X15.513 Y-8.149 F150.0
G01 X15.398 Y-7.991 F150.0
G01 X15.309 Y-7.817 F150.0
G01 X15.249 Y-7.631 F150.0
G01 X15.219 Y-7.438 F150.0
G01 X15.219 Y-5.262 F150.0
G01 X15.249 Y-5.069 F150.0
G01 X15.309 Y-4.883 F150.0
G01 X15.398 Y-4.709 F150.0
G01 X15.513 Y-4.551 F150.0
G01 X15.651 Y-4.413 F150.0
G01 X15.809 Y-4.298 F150.0
G01 X15.983 Y-4.210 F150.0
G01 X16.169 Y-4.149 F150.0
G01 X16.361 Y-4.119 F150.0
G01 X16.557 Y-4.119 F150.0
G01 X16.750 Y-4.149 F150.0
G01 X16.935 Y-4.210 F150.0
G01 X17.109 Y-4.298 F150.0
G01 X17.267 Y-4.413 F150.0
G01 X17.405 Y-4.551 F150.0
G01 X17.520 Y-4.709 F150.0
G01 X17.609 Y-4.883 F150.0
G01 X17.669 Y-5.069 F150.0
G01 X17.700 Y-5.262 F150.0
G01 X17.700 Y-7.438 F150.0
G01 X17.669 Y-7.631 F150.0
G01 X17.609 Y-7.817 F150.0
G01 X17.520 Y-7.991 F150.0
G01 X17.471 Y-8.058 F150.0
G01 X17.471 Y-14.279 F150.0
G01 X30.385 Y-14.279 F150.0
G01 X30.575 Y-14.279 F150.0
G01 X31.655 Y-14.279 F150.0
G01 X31.845 Y-14.279 F150.0
G01 X33.115 Y-14.279 F150.0
G01 X34.385 Y-14.279 F150.0
G01 X34.570 Y-14.316 F150.0
G01 X34.745 Y-14.388 F150.0
G01 X34.903 Y-14.493 F150.0
G01 X35.037 Y-14.627 F150.0
G01 X35.142 Y-14.785 F150.0
G01 X35.214 Y-14.960 F150.0
G01 X35.251 Y-15.145 F150.0
G01 X35.251 Y-15.335 F150.0
G01 X35.251 Y-17.382 F150.0
G01 X35.958 Y-18.089 F150.0
G01 X41.815 Y-18.089 F150.0
G01 X42.005 Y-18.089 F150.0
G01 X44.545 Y-18.089 F150.0
G01 X44.730 Y-18.126 F150.0
G01 X44.905 Y-18.198 F150.0
G01 X45.063 Y-18.303 F150.0
G01 X45.197 Y-18.437 F150.0
G01 X45.302 Y-18.595 F150.0
G01 X45.374 Y-18.770 F150.0
G01 X45.411 Y-18.955 F150.0
G01 X45.411 Y-19.145 F150.0
G01 X45.411 Y-26.272 F150.0
G01 X46.118 Y-26.979 F150.0
G01 X46.895 Y-26.979 F150.0
G01 X48.165 Y-26.979 F150.0
G01 X50.402 Y-26.979 F150.0
G01 X51.109 Y-26.272 F150.0
G01 X51.109 Y-24.035 F150.0
G01 X51.146 Y-23.850 F150.0
G01 X51.218 Y-23.675 F150.0
G01 X51.323 Y-23.517 F150.0
G01 X51.457 Y-23.383 F150.0
G01 X51.615 Y-23.278 F150.0
G01 X51.790 Y-23.206 F150.0
G01 X51.975 Y-23.169 F150.0
G01 X52.165 Y-23.169 F150.0
G01 X53.245 Y-23.169 F150.0
G01 X55.785 Y-23.169 F150.0
G01 X55.975 Y-23.169 F150.0
G01 X56.160 Y-23.206 F150.0
G01 X56.335 Y-23.278 F150.0
G01 X56.493 Y-23.383 F150.0
G01 X56.627 Y-23.517 F150.0
G01 X56.732 Y-23.675 F150.0
G01 X56.804 Y-23.850 F150.0
G01 X56.841 Y-24.035 F150.0
G01 X56.841 Y-24.930 F150.0
G01 X56.892 Y-24.981 F150.0
G01 X56.892 Y-25.819 F150.0
G01 X56.841 Y-25.870 F150.0
G01 X56.841 Y-28.035 F150.0
G01 X56.804 Y-28.220 F150.0
G01 X56.732 Y-28.395 F150.0
G01 X56.627 Y-28.553 F150.0
G01 X56.493 Y-28.687 F150.0
G01 X56.335 Y-28.792 F150.0
G01 X56.160 Y-28.864 F150.0
G01 X55.975 Y-28.901 F150.0
G01 X55.785 Y-28.901 F150.0
G01 X54.705 Y-28.901 F150.0
G01 X54.515 Y-28.901 F150.0
G01 X53.245 Y-28.901 F150.0
G01 X52.165 Y-28.901 F150.0
G01 X50.705 Y-28.901 F150.0
G01 X48.658 Y-28.901 F150.0
G01 X47.951 Y-29.608 F150.0
G01 X47.951 Y-45.641 F150.0
G01 X47.998 Y-45.734 F150.0
G00 Z1.000
G00 X6.532 Y-47.914
G01 X6.532 Y-46.066 F150.0
G01 X6.559 Y-45.897 F150.0
G01 X6.612 Y-45.734 F150.0
G01 X6.659 Y-45.641 F150.0
G01 X6.659 Y-44.545 F150.0
G01 X6.659 Y-43.275 F150.0
G01 X6.659 Y-30.575 F150.0
G01 X6.659 Y-30.385 F150.0
G01 X6.696 Y-30.200 F150.0
G01 X6.768 Y-30.025 F150.0
G01 X6.873 Y-29.867 F150.0
G01 X7.007 Y-29.733 F150.0
G01 X7.165 Y-29.628 F150.0
G01 X7.340 Y-29.556 F150.0
G01 X7.525 Y-29.519 F150.0
G01 X8.985 Y-29.519 F150.0
G01 X10.065 Y-29.519 F150.0
G01 X11.335 Y-29.519 F150.0
G01 X12.605 Y-29.519 F150.0
G01 X12.795 Y-29.519 F150.0
G01 X13.875 Y-29.519 F150.0
G01 X14.065 Y-29.519 F150.0
G01 X15.145 Y-29.519 F150.0
G01 X15.335 Y-29.519 F150.0
G01 X16.415 Y-29.519 F150.0
G01 X17.685 Y-29.519 F150.0
G01 X17.875 Y-29.519 F150.0
G01 X18.060 Y-29.556 F150.0
G01 X18.235 Y-29.628 F150.0
G01 X18.393 Y-29.733 F150.0
G01 X18.527 Y-29.867 F150.0
G01 X18.632 Y-30.025 F150.0
G01 X18.704 Y-30.200 F150.0
G01 X18.741 Y-30.385 F150.0
G01 X18.741 Y-43.275 F150.0
G01 X18.704 Y-43.460 F150.0
G01 X18.632 Y-43.635 F150.0
G01 X18.527 Y-43.793 F150.0
G01 X18.393 Y-43.927 F150.0
G01 X18.235 Y-44.032 F150.0
G01 X18.060 Y-44.104 F150.0
G01 X17.875 Y-44.141 F150.0
G01 X17.685 Y-44.141 F150.0
G01 X16.605 Y-44.141 F150.0
G01 X15.710 Y-44.141 F150.0
G01 X15.659 Y-44.192 F150.0
G01 X14.821 Y-44.192 F150.0
G01 X14.770 Y-44.141 F150.0
G01 X14.065 Y-44.141 F150.0
G01 X13.875 Y-44.141 F150.0
G01 X12.605 Y-44.141 F150.0
G01 X11.525 Y-44.141 F150.0
G01 X11.335 Y-44.141 F150.0
G01 X10.255 Y-44.141 F150.0
G01 X9.288 Y-44.141 F150.0
G01 X8.581 Y-44.848 F150.0
G01 X8.581 Y-45.641 F150.0
G01 X8.628 Y-45.734 F150.0
G01 X8.681 Y-45.897 F150.0
G01 X8.708 Y-46.066 F150.0
G01 X8.708 Y-47.914 F150.0
G01 X8.681 Y-48.083 F150.0
G01 X8.628 Y-48.246 F150.0
G01 X8.551 Y-48.399 F150.0
G01 X8.450 Y-48.537 F150.0
G01 X8.329 Y-48.658 F150.0
G01
micges
Post napisał: micges » 19 sie 2010, 17:45
Pauze usuniesz usuwając wszystkie wystąpienia 'M00'
Nie widze nigdzie pauzy dokładnie 10 sekundowej więc wklej caly gkod na pastebin.com
jarcys
Post napisał: jarcys » 19 sie 2010, 17:48
To dlaczego mi zatrzymuje sie co chwile, co mam nie tak.
[ Dodano: 2010-08-19, 18:05 ]
I zrobiłem jak mi doradziłeś(Pauze usuniesz usuwając wszystkie wystąpienia 'M00' ) i biega dzięki .
Wróć do „CNC podstawy”
