Dear forum users, please tell us how to work with timers in the PLC program at this rack, how and where is the time set?
What does the PLC command "= N" mean? And how is it applied?
Heidenhain iTNC 530
Re: Heidenhain iTNC 530
MOD -> Clock setting -> use touchpad and two buttons next to touchpad to set correct time, and after Enter machine will reboot PLC.sarabanda pisze:Dear forum users, please tell us how to work with timers in the PLC program at this rack, how and where is the time set?
STELMI, tell me please what machine parameter is the timer T69 set?STELMI pisze:MOD -> Clock setting -> use touchpad and two buttons next to touchpad to set correct time, and after Enter machine will reboot PLC.sarabanda pisze:Dear forum users, please tell us how to work with timers in the PLC program at this rack, how and where is the time set?
Timer T69? Can you explain what it is, becouse I thought, that you just wanted to set correct Time on PLCsarabanda pisze: STELMI, tell me please what machine parameter is the timer T69 set?
Here is the subroutine "Lubrication", in which I want to understand.STELMI pisze:Timer T69? Can you explain what it is, becouse I thought, that you just wanted to set correct Time on PLCsarabanda pisze: STELMI, tell me please what machine parameter is the timer T69 set?
In the 530 Service Manual I did not find what parameter T69 is set, so I would like to understand where it can be tuned in order to understand the logic of the program.
GLOBAL LUBRICATION
LBL LUBRICATION
L I9 ;TLAKOVY SPINAC MAZANI PRICNIK
O I8 ;TLAKOVY SPINAC MAZANI OSY
AN T69 ;PRODLOUZENI CASU PO TLAK SPIN
O M4819 ;NIZKA HL MAZACIHO OLEJE
ON I3
R O21 ;MOTOR MAZANI
R O20 ;MAGNET
L O10 ;UVOLNIT W
O M7103 ;MAZANI W
S O21 ;MOTOR MAZANI
S O20 ;MAGNET
R M4818 ;PORUCHA MAZANI
L W1056 ;START MAZANI PODRAZE
== K1
= M7100 ;MAZANI X
L W1056
== K2
= M7101
L W1056
== K4
= M7102 ;MAZANI Z
L W1056
== K8
= M7103 ;MAZANI W
L M7100
O M7101
O M7102
O M6020 ;SK MAZANI
S O21 ;MOTOR MAZANI
L M4818 ;PORUCHA MAZANI
ON I3
R O21 ;MOTOR MAZANI
R O20
L O21 ;MOTOR MAZANI
IFT
L K31
= W1058 ;RESET MAZANI PO DRAZE
ENDI
LN O21 ;MOTOR MAZANI
IFT
L K0
= W1058 ;RESET MAZANI PODRAZE
ENDI
=N T21 ;PRODLOUZENI CASU PO TLAK SPIN
EM
