Błąd po uruchomieniu LinuxCNC
: 27 sty 2017, 13:08
autor: dalem
Zainstalowałem na starszym komputerze LinuxCNC 2.7, system uruchamia się prawidłowo ale po uruchomieniu axis wyskakuje pewien błąd. Komputer to Pentium 4 1,5 GHz, 512 MB RAM.
Ma ktoś może pomysł gdzie szukać przyczyny?
Błąd:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/mickuj/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis_9axis.ini'
INIFILE=/home/mickuj/linuxcnc/configs/sim.axis/axis_9axis.ini
PARAMETER_FILE=sim-9axis.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(lib): /usr/share/linuxcnc/hallib/core_sim9.hal
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Found file(lib): /usr/share/linuxcnc/hallib/locking_indexer.hal
Starting TASK program: milltask
Starting DISPLAY program: axis
task: main loop took 0.014219 seconds
task: main loop took 0.015005 seconds
Shutting down and cleaning up LinuxCNC...
task: main loop took 0.011961 seconds
Killing task linuxcncsvr, PID=5011
Killing task milltask, PID=5068
task: 2879 cycles, min=0.000044, max=0.015005, avg=0.002024, 3 latency excursions (> 10x expected cycle time of 0.001000s)
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
python: nv04_state_raster.c:126: get_blend_func: Assertion `0' failed.
/usr/bin/linuxcnc: line 857: 5071 Przerwane $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
5011
PID TTY STAT TIME COMMAND
5068
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000cc000 - 00000000000d0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
[ 0.000000] BIOS-e820: 000000001fff0000 - 000000001fff8000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001fff8000 - 0000000020000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] Legacy DMI 2.3 present.
[ 0.000000] DMI: NEC CI MS-6506 /MS-6506 , BIOS 07.00T 04/02/2001
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x1fff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 base 0E0000000 mask FFC000000 write-combining
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fb900] fb900
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-000000001fff0000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001fc00000 page 2M
[ 0.000000] 001fc00000 - 001fff0000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x1ffeffff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 1e851000 - 1f63f000
[ 0.000000] ACPI: RSDP 000fa210 00014 (v00 AMI )
[ 0.000000] ACPI: RSDT 1fff0000 0002C (v01 NEC DModel2A 00000010 MSFT 00000097)
[ 0.000000] ACPI: FACP 1fff0030 00081 (v01 NEC DModel2A 00000011 MSFT 00000097)
[ 0.000000] ACPI: DSDT 1fff0120 0345F (v01 INTEL BROKDALE 00001000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 1fff8000 00040
[ 0.000000] ACPI: APIC 1fff00c0 00054 (v01 NEC DModel2A 00000009 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 511MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1fff0000
[ 0.000000] low ram: 0 - 1fff0000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001fff0
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001fff0
[ 0.000000] On node 0 totalpages: 130943
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map dfbef200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 125968 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000cc000
[ 0.000000] PM: Registered nosave memory: 00000000000cc000 - 00000000000d0000
[ 0.000000] PM: Registered nosave memory: 00000000000d0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:dff00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @dfbda000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129919
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=ea1d0607-ba02-48af-a2a9-339d9b2b90c6 ro quiet
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 1048320 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 498036k/524224k available (3495k kernel code, 25736k reserved, 1237k data, 416k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xe07f0000 - 0xff7fe000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdfff0000 ( 511 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[ 0.000000] CPU 0 irqstacks, hard=de408000 soft=de40a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1494.492 MHz processor.
[ 0.004006] Calibrating delay loop (skipped), value calculated using timer frequency.. 2988.98 BogoMIPS (lpj=5977968)
[ 0.004020] pid_max: default: 32768 minimum: 301
[ 0.004169] Security Framework initialized
[ 0.004190] AppArmor: AppArmor disabled by boot time parameter
[ 0.004240] Mount-cache hash table entries: 512
[ 0.004844] Initializing cgroup subsys cpuacct
[ 0.004857] Initializing cgroup subsys memory
[ 0.004884] Initializing cgroup subsys devices
0.004892] Initializing cgroup subsys freezer
[ 0.004899] Initializing cgroup subsys net_cls
[ 0.004905] Initializing cgroup subsys blkio
[ 0.004926] Initializing cgroup subsys perf_event
[ 0.005011] CPU0: Hyper-Threading is disabled
[ 0.005020] mce: CPU supports 4 MCE banks
[ 0.005043] CPU0: Thermal monitoring enabled (TM1)
[ 0.005196] SMP alternatives: switching to UP code
[ 0.014936] Freeing SMP alternatives: 16k freed
[ 0.014970] ACPI: Core revision 20120320
[ 0.021491] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.021910] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.061618] CPU0: Intel(R) Pentium(R) 4 CPU 1.50GHz stepping 02
[ 0.064003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.064003] ... version: 0
[ 0.064003] ... bit width: 40
[ 0.064003] ... generic registers: 18
[ 0.064003] ... value mask: 000000ffffffffff
[ 0.064003] ... max period: 0000007fffffffff
[ 0.064003] ... fixed-purpose events: 0
[ 0.064003] ... event mask: 000000000003ffff
[ 0.072073] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.072201] Brought up 1 CPUs
[ 0.072209] Total of 1 processors activated (2988.98 BogoMIPS).
[ 0.073082] devtmpfs: initialized
[ 0.073781] PM: Registering ACPI NVS region [mem 0x1fff8000-0x1fffffff] (32768 bytes)
[ 0.074131] dummy:
[ 0.074304] NET: Registered protocol family 16
[ 0.074640] ACPI: bus type pci registered
[ 0.077219] PCI: PCI BIOS revision 2.10 entry at 0xfdb81, last bus=2
[ 0.077228] PCI: Using configuration type 1 for base access
[ 0.079090] bio: create slab <bio-0> at 0
[ 0.079395] ACPI: Added _OSI(Module Device)
[ 0.079405] ACPI: Added _OSI(Processor Device)
[ 0.079413] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.079420] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.082126] ACPI: EC: Look up EC in DSDT
[ 0.092894] ACPI: Interpreter enabled
[ 0.092940] ACPI: (supports S0 S3 S4 S5)
[ 0.093015] ACPI: Using IOAPIC for interrupt routing
[ 0.099017] ACPI: Power Resource [URP1] (off)
[ 0.099149] ACPI: Power Resource [URP2] (off)
[ 0.099272] ACPI: Power Resource [FDDP] (off)
[ 0.099400] ACPI: Power Resource [LPTP] (off)
[ 0.105647] ACPI: No dock devices found.
[ 0.105677] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.105953] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.106237] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.106246] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.106254] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.106262] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[ 0.106270] pci_root PNP0A03:00: host bridge window [mem 0x20000000-0xffdfffff] (ignored)
[ 0.106278] pci_root PNP0A03:00: host bridge window [mem 0xfee01000-0xffdfffff] (ignored)
[ 0.106287] PCI: root bus 00: using default resources
[ 0.106396] PCI host bridge to bus 0000:00
[ 0.106406] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.106414] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.106455] pci 0000:00:00.0: [8086:1a30] type 00 class 0x060000
[ 0.106477] pci 0000:00:00.0: reg 10: [mem 0xe0000000-0xe3ffffff pref]
[ 0.106575] pci 0000:00:01.0: [8086:1a31] type 01 class 0x060400
[ 0.106699] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[ 0.106780] pci 0000:00:1f.0: [8086:2440] type 00 class 0x060100
[ 0.106926] pci 0000:00:1f.1: [8086:244b] type 00 class 0x010180
[ 0.107003] pci 0000:00:1f.1: reg 20: [io 0xfc00-0xfc0f]
[ 0.107068] pci 0000:00:1f.2: [8086:2442] type 00 class 0x0c0300
[ 0.107146] pci 0000:00:1f.2: reg 20: [io 0xe000-0xe01f]
[ 0.107212] pci 0000:00:1f.3: [8086:2443] type 00 class 0x0c0500
[ 0.107292] pci 0000:00:1f.3: reg 20: [io 0x0c00-0x0c0f]
[ 0.107355] pci 0000:00:1f.4: [8086:2444] type 00 class 0x0c0300
[ 0.107435] pci 0000:00:1f.4: reg 20: [io 0xe400-0xe41f]
[ 0.107504] pci 0000:00:1f.5: [8086:2445] type 00 class 0x040100
[ 0.107532] pci 0000:00:1f.5: reg 10: [io 0xec00-0xecff]
[ 0.107554] pci 0000:00:1f.5: reg 14: [io 0xe800-0xe83f]
[ 0.107682] pci 0000:01:00.0: [10de:002d] type 00 class 0x030000
[ 0.107717] pci 0000:01:00.0: reg 10: [mem 0xde000000-0xdeffffff]
[ 0.107736] pci 0000:01:00.0: reg 14: [mem 0xda000000-0xdbffffff pref]
[ 0.107795] pci 0000:01:00.0: reg 30: [mem 0xdfdf0000-0xdfdfffff pref]
[ 0.107895] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.107910] pci 0000:00:01.0: bridge window [mem 0xddd00000-0xdfdfffff]
[ 0.107923] pci 0000:00:01.0: bridge window [mem 0xd9a00000-0xddafffff pref]
[ 0.108030] pci 0000:02:01.0: [8086:1229] type 00 class 0x020000
[ 0.108064] pci 0000:02:01.0: reg 10: [mem 0xdfeff000-0xdfefffff]
[ 0.108083] pci 0000:02:01.0: reg 14: [io 0xbc00-0xbc3f]
[ 0.108105] pci 0000:02:01.0: reg 18: [mem 0xdfec0000-0xdfedffff]
[ 0.108163] pci 0000:02:01.0: reg 30: [mem 0xdfee0000-0xdfeeffff pref]
[ 0.108200] pci 0000:02:01.0: supports D1 D2
[ 0.108208] pci 0000:02:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.108285] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.108298] pci 0000:00:1e.0: bridge window [io 0xb000-0xbfff]
[ 0.108310] pci 0000:00:1e.0: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.108324] pci 0000:00:1e.0: bridge window [mem 0xddb00000-0xddbfffff pref]
[ 0.108335] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.108348] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.108372] pci_bus 0000:00: on NUMA node 0
[ 0.108385] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.108615] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.ICHB._PRT]
[ 0.108990] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.129417] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.129612] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.129797] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.130002] ACPI: PCI Interrupt Link [LNKD] (IRQs 9) *10
[ 0.130170] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.130357] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.130541] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.130729] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.131075] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.131087] vgaarb: loaded
[ 0.131092] vgaarb: bridge control possible 0000:01:00.0
[ 0.131184] PCI: Using ACPI for IRQ routing
[ 0.131195] PCI: pci_cache_line_size set to 64 bytes
[ 0.131298] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.131308] reserve RAM buffer: 000000001fff0000 - 000000001fffffff
[ 0.131868] pnp: PnP ACPI init
[ 0.131910] ACPI: bus type pnp registered
[ 0.132235] pnp 00:00: [bus 00-ff]
[ 0.132245] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.132253] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.132268] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.132276] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.132284] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.132292] pnp 00:00: [mem 0x20000000-0xffdfffff window]
[ 0.132299] pnp 00:00: [mem 0xfee01000-0xffdfffff window]
[ 0.132449] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.132594] pnp 00:01: [io 0x0010-0x001f]
[ 0.132602] pnp 00:01: [io 0x0020-0x003f]
[ 0.132608] pnp 00:01: [io 0x0044-0x005f]
[ 0.132615] pnp 00:01: [io 0x0062-0x0063]
[ 0.132621] pnp 00:01: [io 0x0065-0x006f]
[ 0.132628] pnp 00:01: [io 0x0072-0x007f]
[ 0.132634] pnp 00:01: [io 0x0080]
[ 0.132640] pnp 00:01: [io 0x0084-0x0086]
[ 0.132647] pnp 00:01: [io 0x0088]
[ 0.132653] pnp 00:01: [io 0x008c-0x008e]
[ 0.132660] pnp 00:01: [io 0x0090-0x009f]
[ 0.132666] pnp 00:01: [io 0x00a0-0x00bf]
[ 0.132673] pnp 00:01: [io 0x00e0-0x00ef]
[ 0.132679] pnp 00:01: [io 0x0290-0x0297]
[ 0.132686] pnp 00:01: [io 0x03f0-0x03f1]
[ 0.132693] pnp 00:01: [io 0x04d0-0x04d1]
[ 0.132700] pnp 00:01: [mem 0xfee00000-0xfeefffff]
[ 0.132841] system 00:01: [io 0x0290-0x0297] has been reserved
[ 0.132852] system 00:01: [io 0x03f0-0x03f1] has been reserved
[ 0.132862] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 0.132873] system 00:01: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.132883] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.132919] pnp 00:02: [mem 0xffb00000-0xffbfffff]
[ 0.132984] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.133074] pnp 00:03: [dma 4]
[ 0.133083] pnp 00:03: [io 0x0000-0x000f]
[ 0.133089] pnp 00:03: [io 0x0081-0x0083]
[ 0.133096] pnp 00:03: [io 0x0087]
[ 0.133102] pnp 00:03: [io 0x0089-0x008b]
[ 0.133108] pnp 00:03: [io 0x008f]
[ 0.133115] pnp 00:03: [io 0x00c0-0x00df]
[ 0.133189] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.133234] pnp 00:04: [io 0x0070-0x0071]
[ 0.133270] pnp 00:04: [irq 8]
[ 0.133343] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.133379] pnp 00:05: [io 0x0061]
[ 0.133449] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.133489] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.133506] pnp 00:06: [irq 13]
[ 0.133581] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.133774] pnp 00:07: [io 0x0060]
[ 0.133782] pnp 00:07:
[io 0x0064]
[ 0.133797] pnp 00:07: [irq 1]
[ 0.133893] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.134136] pnp 00:08: [io 0x03f2-0x03f3]
[ 0.134144] pnp 00:08: [io 0x03f4-0x03f5]
[ 0.134151] pnp 00:08: [io 0x03f7]
[ 0.134166] pnp 00:08: [irq 6]
[ 0.134175] pnp 00:08: [dma 2]
[ 0.134346] pnp 00:08: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.134944] pnp 00:09: [io 0x03f8-0x03ff]
[ 0.134964] pnp 00:09: [irq 4]
[ 0.135161] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.135737] pnp 00:0a: [io 0x02f8-0x02ff]
[ 0.135757] pnp 00:0a: [irq 3]
[ 0.135943] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.137026] pnp 00:0b: [io 0x0378-0x037f]
[ 0.137035] pnp 00:0b: [io 0x0778-0x077b]
[ 0.137058] pnp 00:0b: [irq 7]
[ 0.137066] pnp 00:0b: [dma 3]
[ 0.137339] pnp 00:0b: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.137753] pnp 00:0c: [io 0x0200-0x0207]
[ 0.137870] pnp 00:0c: Plug and Play ACPI device, IDs PNPb02f (active)
[ 0.138682] pnp: PnP ACPI: found 13 devices
[ 0.138690] ACPI: ACPI bus type pnp unregistered
[ 0.138704] PnPBIOS: Disabled by ACPI PNP
[ 0.178584] Switching to clocksource acpi_pm
[ 0.178696] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.178712] pci 0000:00:01.0: bridge window [mem 0xddd00000-0xdfdfffff]
[ 0.178723] pci 0000:00:01.0: bridge window [mem 0xd9a00000-0xddafffff pref]
[ 0.178737] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
[ 0.178746] pci 0000:00:1e.0: bridge window [io 0xb000-0xbfff]
[ 0.178759] pci 0000:00:1e.0: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.178770] pci 0000:00:1e.0: bridge window [mem 0xddb00000-0xddbfffff pref]
[ 0.178815] pci 0000:00:1e.0: setting latency timer to 64
[ 0.178826] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.178834] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.178842] pci_bus 0000:01: resource 1 [mem 0xddd00000-0xdfdfffff]
[ 0.178850] pci_bus 0000:01: resource 2 [mem 0xd9a00000-0xddafffff pref]
[ 0.178858] pci_bus 0000:02: resource 0 [io 0xb000-0xbfff]
[ 0.178865] pci_bus 0000:02: resource 1 [mem 0xdfe00000-0xdfefffff]
[ 0.178873] pci_bus 0000:02: resource 2 [mem 0xddb00000-0xddbfffff pref]
[ 0.178880] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[ 0.178888] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[ 0.179081] NET: Registered protocol family 2
[ 0.179266] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.179694] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.179902] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.179902] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.179902] TCP: reno registered
[ 0.179902] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.179902] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.179902] NET: Registered protocol family 1
[ 0.179902] pci 0000:01:00.0: Boot video device
[ 0.179902] pci 0000:02:01.0: Firmware left e100 interrupts enabled; disabling
[ 0.179902] PCI: CLS 32 bytes, default 64
[ 0.179902] Unpacking initramfs...
[ 1.018555] Freeing initrd memory: 14264k freed
[ 1.059808] audit: initializing netlink socket (disabled)
[ 1.059859] type=2000 audit(1485458115.055:1): initialized
[ 1.083390] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 1.083813] VFS: Disk quotas dquot_6.5.2
[ 1.083886] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.084178] msgmni has been set to 1000
[ 1.084724] alg: No test for stdrng (krng)
[ 1.084837] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.084850] io scheduler noop registered
[ 1.084856] io scheduler deadline registered
[ 1.084893] io scheduler cfq registered (default)
[ 1.085137] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.085190] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.085197] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.086053] GHES: HEST is not enabled!
[ 1.086091] isapnp: Scanning for PnP cards...
[ 1.440741] isapnp: No Plug & Play device found
[ 1.440917] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.461357] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.481831] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.502830] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.523414] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.523839] Linux agpgart interface v0.103
[ 1.524190] agpgart-intel 0000:00:00.0: Intel i845 Chipset
[ 1.528523] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xe0000000
[ 1.528863] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.528871] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.529979] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.530318] mousedev: PS/2 mouse device common for all mice
[ 1.530469] rtc_cmos 00:04: RTC can wake from S4
[ 1.530727] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.530775] rtc0: alarms up to one month, y3k, 114 bytes nvram
[ 1.531125] TCP: cubic registered
[ 1.531240] NET: Registered protocol family 10
[ 1.531870] Mobile IPv6
[ 1.531886] NET: Registered protocol family 17
[ 1.531906] Registering the dns_resolver key type
[ 1.532114] Using IPI No-Shortcut mode
[ 1.532446] PM: Hibernation image not present or could not be loaded.
[ 1.532491] registered taskstats version 1
[ 1.533073] rtc_cmos 00:04: setting system clock to 2017-01-26 19:15:16 UTC (1485458116)
[ 1.533328] Freeing unused kernel memory: 416k freed
[ 1.534510] Write protecting the kernel text: 3496k
[ 1.534555] Write protecting the kernel read-only data: 984k
[ 1.560807] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.588740] udevd[45]: starting version 175
[ 1.755277] Floppy drive(s): fd0 is 1.44M
[ 1.812132] FDC 0 is a post-1991 82077
[ 1.897786] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.897798] e100: Copyright(c) 1999-2006 Intel Corporation
[ 1.902520] SCSI subsystem initialized
[ 1.910296] usbcore: registered new interface driver usbfs
[ 1.910375] usbcore: registered new interface driver hub
[ 1.916222] usbcore: registered new device driver usb
[ 1.917928] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.919193] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.919363] uhci_hcd 0000:00:1f.2: setting latency timer to 64
[ 1.919374] uhci_hcd 0000:00:1f.2: UHCI Host Controller
[ 1.919457] uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
[ 1.919545] uhci_hcd 0000:00:1f.2: irq 19, io base 0x0000e000
[ 1.919670] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.919679] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.919687] usb usb1: Product: UHCI Host Controller
[ 1.919693] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.919699] usb usb1: SerialNumber: 0000:00:1f.2
[ 1.936381] hub 1-0:1.0: USB hub found
[ 1.936403] hub 1-0:1.0: 2 ports detected
[ 1.938385] uhci_hcd 0000:00:1f.4: setting latency timer to 64
[ 1.938399] uhci_hcd 0000:00:1f.4: UHCI Host Controller
[ 1.938428] uhci_hcd 0000:00:1f.4: new USB bus registered, assigned bus number 2
[ 1.938525] uhci_hcd 0000:00:1f.4: irq 23, io base 0x0000e400
[ 1.938644] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.938653] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.938660] usb usb2: Product: UHCI Host Controller
[ 1.938667] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.938673] usb usb2: SerialNumber: 0000:00:1f.4
[ 1.940632] hub 2-0:1.0: USB hub found
[ 1.940653] hub 2-0:1.0: 2 ports detected
[ 1.940817] libata version 3.00 loaded.
[ 1.955256] ata_piix 0000:00:1f.1: version 2.13
[ 1.955426] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.964672] scsi0 : ata_piix
[ 1.966940] microcode: CPU0 sig=0xf12, pf=0x4, revision=0x28
[ 1.968137] scsi1 : ata_piix
[ 1.991743] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[ 1.991755] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfc08 irq 15
[ 2.068100] Refined TSC clocksource calibration: 1494.460 MHz.
[ 2.068121] Switching to clocksource tsc
[ 2.152725] ata1.00: ATA-6: ST320410A, 3.93, max UDMA/100
[ 2.152737] ata1.00: 39102336 sectors, multi 16: LBA
[ 2.164485] ata2.00: ATAPI: CRD-8484B, 1.05, max MWDMA2
[ 2.168541] ata1.00: configured for UDMA/100
[ 2.168914] scsi 0:0:0:0: Direct-Access ATA ST320410A 3.93 PQ: 0 ANSI: 5
[ 2.180450] ata2.00: configured for MWDMA2
[ 2.182981] scsi 1:0:0:0: CD-ROM GoldStar CD-ROM CRD-8484B 1.05 PQ: 0 ANSI: 5
[ 2.214101] microcode: CPU0 updated to revision 0x2e, date = 2003-05-02
[ 2.215199] microcode: Microcode Update Driver: v2.00 <[email protected]>, Peter Oruba
[ 2.230754] sd 0:0:0:0: [sda] 39102336 512-byte logical blocks: (20.0 GB/18.6 GiB)
[ 2.230969] sd 0:0:0:0: [sda] Write Protect is off
[ 2.230979] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.231069] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.236300] sr0: scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
[ 2.236314] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.238272] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.252068] usb 2-2: new low-speed USB device number 2 using uhci_hcd
[ 2.264145] sda: sda1 sda2 < sda5 >
[ 2.265332] sd 0:0:0:0: [sda] Attached SCSI disk
2.276824] e100 0000:02:01.0: eth0: addr 0xdfeff000, irq 21, MAC addr 00:02:b3:ac:a1:5e
[ 2.293543] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.293938] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.416567] usb 2-2: New USB device found, idVendor=04f3, idProduct=0232
[ 2.416581] usb 2-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.416589] usb 2-2: Product: OM
[ 2.456371] input: OM as /devices/pci0000:00/0000:00:1f.4/usb2/2-2/2-2:1.0/input/input1
[ 2.457034] generic-usb 0003:04F3:0232.0001: input,hidraw0: USB HID v1.11 Mouse [OM] on usb-0000:00:1f.4-2/input0
[ 2.457872] usbcore: registered new interface driver usbhid
[ 2.457883] usbhid: USB HID core driver
[ 2.927157] PM: Starting manual resume from disk
[ 2.927174] PM: Hibernation image partition 8:5 present
[ 2.927179] PM: Looking for hibernation image.
[ 2.951450] PM: Image not found (code -22)
[ 2.951459] PM: Hibernation image not present or could not be loaded.
[ 3.043191] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.040674] udevd[298]: starting version 175
[ 6.652596] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 6.652618] ACPI: Power Button [PWRB]
[ 6.652840] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
[ 6.652856] ACPI: Sleep Button [SLPB]
[ 6.653002] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 6.653014] ACPI: Power Button [PWRF]
[ 6.719352] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 6.746577] parport_pc 00:0b: reported by Plug and Play ACPI
[ 6.746723] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[ 6.854640] gameport gameport0: NS558 PnP Gameport is pnp00:0c/gameport0, io 0x200, speed 784kHz
[ 7.159282] intel_rng: FWH not detected
[ 7.198371] iTCO_vendor_support: vendor-support=0
[ 7.443439] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 7.443637] iTCO_wdt: Found a ICH2 TCO device (Version=1, TCOBASE=0x0860)
[ 7.443819] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 8.026911] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[ 8.083263] [drm] Initialized drm 1.1.0 20060810
[ 8.315532] wmi: Mapper loaded
[ 8.355531] intel8x0_measure_ac97_clock: measured 59413 usecs (2854 samples)
[ 8.355542] intel8x0: clocking to 48000
[ 8.430790] [drm] nouveau 0000:01:00.0: Detected an NV 4 generation card (0x20154000)
[ 8.438519] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 8.470907] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 8.470920] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 8.471053] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 8.471061] [drm] nouveau 0000:01:00.0: BMP version 5.17
[ 8.471070] [drm] nouveau 0000:01:00.0: Bios version 03.05.00.10
[ 8.471079] [drm] nouveau 0000:01:00.0: No DCB data found in VBIOS
[ 8.471706] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 8.472979] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0x0198
[ 8.487053] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0x02A1
[ 8.487396] [TTM] Zone kernel: Available graphics memory: 256366 kiB
[ 8.487404] [TTM] Initializing pool allocator
[ 8.487447] [drm] nouveau 0000:01:00.0: Detected 16MiB VRAM (SDRAM)
[ 8.487752] agpgart-intel 0000:00:00.0: AGP 2.0 bridge
[ 8.487797] agpgart-intel 0000:00:00.0: putting AGP V2 device into 4x mode
[ 8.487843] nouveau 0000:01:00.0: putting AGP V2 device into 4x mode
[ 8.487862] [drm] nouveau 0000:01:00.0: 64 MiB GART (aperture)
[ 8.488167] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 8.542861] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 8.542872] [drm] No driver support for vblank timestamp query.
[ 8.543035] [drm] nouveau 0000:01:00.0: 0 available performance level(s)
[ 8.543046] [drm] nouveau 0000:01:00.0: c: core 125MHz memory 143MHz
[ 8.591634] [drm] nouveau 0000:01:00.0: allocated 1920x1080 fb: 0x44000, bo df160400
[ 8.592193] fbcon: nouveaufb (fb0) is primary device
[ 8.731984] Console: switching to colour frame buffer device 240x67
[ 8.735965] fb0: nouveaufb frame buffer device
[ 8.735974] drm: registered panic notifier
[ 8.735993] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 11.571346] Adding 842748k swap on /dev/sda5. Priority:-1 extents:1 across:842748k
[ 11.629972] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 12.109133] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 12.351085] loop: module loaded
[ 16.386828] RPC: Registered named UNIX socket transport module.
[ 16.386841] RPC: Registered udp transport module.
[ 16.386846] RPC: Registered tcp transport module.
[ 16.386852] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 16.438757] FS-Cache: Loaded
[ 16.522090] NFS: Registering the id_resolver key type
[ 16.522167] FS-Cache: Netfs 'nfs' registered for caching
[ 16.545666] Installing knfsd (copyright (C) 1996 [email protected]).
[ 19.709969] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 23.370569] Bluetooth: Core ver 2.16
[ 23.371680] NET: Registered protocol family 31
[ 23.371693] Bluetooth: HCI device and connection manager initialized
[ 23.371702] Bluetooth: HCI socket layer initialized
[ 23.371708] Bluetooth: L2CAP socket layer initialized
[ 23.371735] Bluetooth: SCO socket layer initialized
[ 23.688726] Bluetooth: RFCOMM TTY layer initialized
[ 23.688747] Bluetooth: RFCOMM socket layer initialized
[ 23.688755] Bluetooth: RFCOMM ver 1.11
[ 23.820164] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 23.820175] Bluetooth: BNEP filters: protocol multicast
[ 24.112692] lp0: using parport0 (interrupt-driven).
[ 24.198915] ppdev: user-space parallel port driver
[ 27.414202] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 27.416346] e100 0000:02:01.0: eth0: NIC Link is Up 100 Mbps Full Duplex
[ 27.416934] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 37.976087] eth0: no IPv6 routers present
[ 114.739941] I-pipe: head domain RTAI registered.
[ 114.739967] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 114.739986] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 114.739996] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6226890, CLK_FREQ 1494492000, CPU_FREQ 1494492000
[ 114.740866] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 114.740884] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6226890, 6226890, 6092500
[ 114.948657] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 114.951363] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 114.951385] RTAI[sched]: hard timer type/freq = APIC/6226890(Hz); default timing: oneshot; linear timed lists.
[ 114.951396] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1494492000 hz.
[ 114.951404] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 115.248352] RTAI[math]: loaded.
[ 116.259182] config string '0 out'
[ 128.331416] RTAI[math]: unloaded.
[ 128.347484] SCHED releases registered named ALIEN PEDV$D
[ 128.361670] RTAI[malloc]: unloaded.
[ 128.460090] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 128.469026] I-pipe: head domain RTAI unregistered.
[ 128.469056] RTAI[hal]: unmounted.
[ 156.311574] I-pipe: head domain RTAI registered.
[ 156.311599] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 156.311619] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 156.311629] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6226890, CLK_FREQ 1494492000, CPU_FREQ 1494492000
[ 156.311637] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 156.311647] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6226890, 6226890, 6113250
[ 156.347533] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 156.347701] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 156.347715] RTAI[sched]: hard timer type/freq = APIC/6226890(Hz); default timing: oneshot; linear timed lists.
[ 156.347725] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1494492000 hz.
[ 156.347732] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 156.401160] RTAI[math]: loaded.
[ 166.379362] RTAI[math]: unloaded.
[ 166.393417] SCHED releases registered named ALIEN PEDV$D
[ 166.416616] RTAI[malloc]: unloaded.
[ 166.516063] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 166.526779] I-pipe: head domain RTAI unregistered.
[ 166.526810] RTAI[hal]: unmounted.
[ 309.647986] I-pipe: head domain RTAI registered.
[ 309.648009] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 309.648036] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 309.648036] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6226890, CLK_FREQ 1494492000, CPU_FREQ 1494492000
[ 309.648036] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 309.648036] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6226890, 6226890, 6152000
[ 309.697476] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 309.697643] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 309.697659] RTAI[sched]: hard timer type/freq = APIC/6226890(Hz); default timing: oneshot; linear timed lists.
[ 309.697669] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1494492000 hz.
[ 309.697675] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
309.741164] RTAI[math]: loaded.
[ 309.996055] config string '0 out'
[ 318.953292] RTAI[math]: unloaded.
[ 318.961547] SCHED releases registered named ALIEN PEDV$D
[ 318.977821] RTAI[malloc]: unloaded.
[ 319.076155] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 319.096168] I-pipe: head domain RTAI unregistered.
[ 319.096197] RTAI[hal]: unmounted.
[ 1390.680285] I-pipe: head domain RTAI registered.
[ 1390.680304] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1390.680323] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1390.680333] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6226890, CLK_FREQ 1494492000, CPU_FREQ 1494492000
[ 1390.680341] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1390.680352] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6226890, 6226890, 6093750
[ 1390.722035] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1390.722203] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1390.722218] RTAI[sched]: hard timer type/freq = APIC/6226890(Hz); default timing: oneshot; linear timed lists.
[ 1390.722228] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1494492000 hz.
[ 1390.722234] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1390.759500] RTAI[math]: loaded.
[ 1400.047243] RTAI[math]: unloaded.
[ 1400.055521] SCHED releases registered named ALIEN PEDV$D
[ 1400.071263] RTAI[malloc]: unloaded.
[ 1400.168047] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1400.176345] I-pipe: head domain RTAI unregistered.
[ 1400.176373] RTAI[hal]: unmounted.
[ 1504.276197] I-pipe: head domain RTAI registered.
[ 1504.276215] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1504.276233] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1504.276243] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6226890, CLK_FREQ 1494492000, CPU_FREQ 1494492000
[ 1504.276251] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1504.276261] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6226890, 6226890, 6106750
[ 1504.329515] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1504.329684] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1504.329698] RTAI[sched]: hard timer type/freq = APIC/6226890(Hz); default timing: oneshot; linear timed lists.
[ 1504.329709] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1494492000 hz.
[ 1504.329716] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1504.363468] RTAI[math]: loaded.
[ 1542.816635] RTAI[math]: unloaded.
[ 1542.834217] SCHED releases registered named ALIEN PEDV$D
[ 1542.859534] RTAI[malloc]: unloaded.
[ 1542.956052] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1542.966162] I-pipe: head domain RTAI unregistered.
[ 1542.966193] RTAI[hal]: unmounted.
[ 1571.731841] I-pipe: head domain RTAI registered.
[ 1571.731866] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1571.731886] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1571.731896] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6226890, CLK_FREQ 1494492000, CPU_FREQ 1494492000
[ 1571.731904] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1571.731915] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6226890, 6226890, 6112000
[ 1571.767737] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1571.767913] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1571.767928] RTAI[sched]: hard timer type/freq = APIC/6226890(Hz); default timing: oneshot; linear timed lists.
[ 1571.767938] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1494492000 hz.
[ 1571.767945] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1571.802724] RTAI[math]: loaded.
[ 1580.744729] RTAI[math]: unloaded.
[ 1580.758574] SCHED releases registered named ALIEN PEDV$D
[ 1580.774160] RTAI[malloc]: unloaded.
[ 1580.872059] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1580.880346] I-pipe: head domain RTAI unregistered.
[ 1580.880375] RTAI[hal]: unmounted.
[ 1628.169387] Thunar[3206]: segfault at 1c ip b76fcb74 sp bfebab5c error 4 in Thunar[b76c8000+bb000]
[ 1649.366484] I-pipe: head domain RTAI registered.
[ 1649.366509] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1649.366529] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1649.366539] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 6226890, CLK_FREQ 1494492000, CPU_FREQ 1494492000
[ 1649.366548] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1649.366558] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6226890, 6226890, 6120250
[ 1649.402304] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1649.402474] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1649.402489] RTAI[sched]: hard timer type/freq = APIC/6226890(Hz); default timing: oneshot; linear timed lists.
[ 1649.402500] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1494492000 hz.
[ 1649.402506] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1649.439292] RTAI[math]: loaded.
[ 1659.179993] RTAI[math]: unloaded.
[ 1659.193872] SCHED releases registered named ALIEN PEDV$D
[ 1659.209629] RTAI[malloc]: unloaded.
[ 1659.308043] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1659.316367] I-pipe: head domain RTAI unregistered.
[ 1659.316396] RTAI[hal]: unmounted.
Problem rozwiązany.
Przyczyną okazała się zbyt słaba karta graficzna.
