Kod: Zaznacz cały
# Wygenerowane przez Stepconf o Thu Apr 4 00:04:25 2013
# Jeśli zmodyfikujesz ten plik zmainy zostaną
# nadpisane gdy uruchomisz ponownie Stepconf
[EMC]
MACHINE = moja-frezarka1
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
PYVCP = custompanel.xml
TKPKG = Ngcgui 1.0
TKPKG = Ngcguittt 1.0
NGCGUI_FONT = Helvetica -12 normal
NGCGUI_PREAMBLE = mm_std.ngc
NGCGUI_SUBFILE = ""
TTT = truetype-tracer
TTT_PREAMBLE = mm_std.ngc
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = ../../../nc_files/ngcgui_lib:../../../nc_files/ngcgui_lib/utilitysubs
USER_M_PATH = ../../../nc_files/ngcgui_lib/mfile
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 40000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = moja-frezarka1.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 100.00
MAX_LINEAR_VELOCITY = 1000.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 14.84375
MAX_ACCELERATION = 140.0
STEPGEN_MAXACCEL = 175.0
SCALE = 1600.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 140.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
SCALE = 1600.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 11.875
MAX_ACCELERATION = 100.0
STEPGEN_MAXACCEL = 125.0
SCALE = 2000.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -70.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0[ Dodano: 2013-04-06, 09:19 ]
Ok, doszedłem. Nie wiem czy to jest ogólnie poprawny sposób, ale dopisałem w pliku ini w subroutine patch:
Kod: Zaznacz cały
:/usr/share/linuxcnc/ncfiles/ngcgui_lib/utilitysubs
