DoubleCAD XT Bezpłatny cad 2D
: 16 gru 2009, 07:40
Odpowiednik TurboCAD 16 w wersji 2D. Działa jak AutoCAD LE. Czyta i zapisuje dwg/dxf/dwf wersje R14 do 2009. Otwiera pliki SketchUp Google oraz PRO, wersje 5/6/7.
Drawing Tools - Arc, Bezier Curve, Circles, Command Line, Construction Lines, Double Line, Ellipse, Line, Multiline, Parallel Line, Perpendicular Line, Points, Polygon, Polyline, Trim, Wall
Editing/Modification Tools - Align, Array, Boolean operations, Chamfer, Distribute, Erase, Fillet, Join Polyline, Meet two lines, Mirror, Multi shrink/extend line, Offset, Rotate, Scale, Split, Stretch, Shrink/extend line, Trim
Dimension Types - Angular,Baseline, Continuous, Datum, Diameter, Incremental, Leader, Orthogonal, Parallel, Quick, Radius, Rotated, Smart
http://www.doublecad.com/Products/Doubl ... fault.aspx
