program ?
pltmaxnc
- Posty w temacie: 8
program ?
W jakim środowisku uruchomoć można taki program ?
ę#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <assert.h>
#include <string.h>
extern "C"
#include <jpeglib.h>
#include <jerror.h>
#include <math.h>
/* USER EDITABLE SECTION: Change these to suit your scanner */
#define CAMERA_HFOV 50.0f /* Degrees */
#define CAMERA_VFOV (CAMERA_HFOV*4.0f/5.0f) /* Degrees */
#define CAMERA_DISTANCE 0.30f /* Meters */
#define LASER_OFFSET 15.0f /* Degrees */
#define HORIZ_AVG 10 /* Num horizontal points to average */
#define VERT_AVG 10 /* Num vertical points to average */
#define FRAME_SKIP 1 /* Use every n'th frame for speed */
#define POINT_SKIP 1 /* Use every n'th scanline for speed*/
#define RADIANS_TO_DEGREES (180.0f / 3.14159f )
#define DEGREES_TO_RADIANS (3.14159f / 180.0f )
class Image
protected:
int width ;
int height ;
unsigned char *buffer ;
public:
Image ( int w, int h )
width = w ;
height = h ;
buffer = new unsigned char [ w * h * 3 ] ;
Image ()
width = height = 0 ;
buffer = NULL ;
virtual ~Image () ;
int getWidth () { return width ; }
int getHeight () { return height ; }
unsigned char *getPixels () { return buffer ; }
unsigned int getPixelArea ( float x1, float y1,
float x2, float y2,
unsigned int keyColour ) ;
itd...............................................................................................
ę#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <assert.h>
#include <string.h>
extern "C"
#include <jerror.h>
#include <math.h>
class Image
protected:
int width ;
int height ;
public:
width = w ;
height = h ;
Image ()
buffer = NULL ;
virtual ~Image () ;
float x2, float y2,
gaspar
Pod linuksem gcc sobie z tym poradzi. Właśnie próbowałem i gdybyś dał cały plik to można go skompilować. To jest źródło do kompilacji w c.
pltmaxnc
calość
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <assert.h>
#include <string.h>
extern "C"
#include <jerror.h>
#include <math.h>
class Image
protected:
int width ;
int height ;
public:
width = w ;
height = h ;
Image ()
buffer = NULL ;
virtual ~Image () ;
float x2, float y2,
unsigned char getPixelRed ( int x, int y )
return (unsigned int) buffer [ ( y * width + x ) * 3 + 0 ] ;
unsigned char getPixelGreen ( int x, int y )
return (unsigned int) buffer [ ( y * width + x ) * 3 + 1 ] ;
unsigned char getPixelBlue ( int x, int y )
return (unsigned int) buffer [ ( y * width + x ) * 3 + 2 ] ;
unsigned int getPixel ( float x, float y )
return getPixel ( (int) x, (int) y ) ;
unsigned int getPixel ( int x, int y )
int p = ( y * width + x ) * 3 ;
return ( (unsigned int) buffer [ p + 0 ] << 24 ) +
( (unsigned int) buffer [ p + 1 ] << 16 ) +
( (unsigned int) buffer [ p + 2 ] << 8 ) + 255 ;
void setPixel ( float x, float y, unsigned int rgba )
setPixel ( (int) x, (int) y, rgba ) ;
void setPixel ( int x, int y, unsigned int rgba )
if ( ( rgba & 0xFF ) == 0 )
return ;
if ( ( rgba & 0xFF ) == 255 )
buffer [ p + 0 ] = ( rgba >> 24 ) & 0xFF ;
buffer [ p + 1 ] = ( rgba >> 16 ) & 0xFF ;
buffer [ p + 2 ] = ( rgba >> 8 ) & 0xFF ;
else
unsigned int r = ( rgba >> 24 ) & 0xFF ;
unsigned int g = ( rgba >> 16 ) & 0xFF ;
unsigned int b = ( rgba >> 8 ) & 0xFF ;
unsigned int a = ( rgba >> 0 ) & 0xFF ;
unsigned int ac = 255 - a ;
buffer [ p + 0 ] = (unsigned char)((int)(buffer [ p + 0 ]) * ac / 255 + r * a / 255 ) ;
buffer [ p + 1 ] = (unsigned char)((int)(buffer [ p + 1 ]) * ac / 255 + g * a / 255 ) ;
buffer [ p + 2 ] = (unsigned char)((int)(buffer [ p + 2 ]) * ac / 255 + b * a / 255 ) ;
virtual int load ( char *fname ) = NULL ;
class JPEG : public Image
public:
JPEG () : Image () {}
JPEG ( int w, int h ) : Image ( w, h ) {}
virtual int load ( char *fname ) ;
static const int _endianTest = 1;
#define isLittleEndian (*((char *) &_endianTest ) != 0)
#define isBigEndian (*((char *) &_endianTest ) == 0)
Image::~Image ()
delete buffer ;
int JPEG::load ( char * filename )
jpeg_decompress_struct cinfo ;
jpeg_error_mgr jerr ;
FILE *fd ;
JSAMPARRAY linebuffer ;
int row_stride ;
if ( ( fd = fopen ( filename, "rb" ) ) == NULL )
perror ( "readJPEG" ) ;
fprintf ( stderr, "readJPEG: Can't open %s for reading\n", filename ) ;
return 0 ;
cinfo.err = jpeg_std_error ( &jerr ) ;
jpeg_create_decompress ( &cinfo ) ;
jpeg_stdio_src ( &cinfo, fd ) ;
jpeg_read_header ( &cinfo, TRUE ) ;
jpeg_start_decompress ( &cinfo ) ;
row_stride = cinfo.output_width * cinfo.output_components ;
if ( cinfo.output_components != 3 )
fprintf ( stderr, "readJPEG: %s has %d components?!?\n", filename,
cinfo.output_components ) ;
return 0 ;
linebuffer = (*cinfo.mem->alloc_sarray)
( (j_common_ptr) &cinfo, JPOOL_IMAGE, row_stride, 1 ) ;
delete buffer ;
height = cinfo.output_height ;
width = cinfo.output_width ;
buffer = new unsigned char [ width * height * 3 ] ;
while (cinfo.output_scanline < cinfo.output_height)
int y = cinfo.output_scanline ;
jpeg_read_scanlines expects an array of pointers to scanlines.
Here the array is only one element long, but you could ask for
more than one scanline at a time if that's more convenient.
jpeg_read_scanlines ( &cinfo, linebuffer, 1 ) ;
memcpy ( & buffer [ y * row_stride ], linebuffer[0], row_stride ) ;
jpeg_finish_decompress ( &cinfo ) ;
jpeg_destroy_decompress ( &cinfo ) ;
fclose ( fd ) ;
return 1 ;
unsigned int Image::getPixelArea ( float x1, float y1,
float x2, float y2,
if ( x2-x1 <= 0.0f || y2-y1 <= 0.0f )
return 0x00000000 ;
unsigned int r = ( keyColour >> 24 ) & 0xFF ;
unsigned int g = ( keyColour >> 16 ) & 0xFF ;
unsigned int b = ( keyColour >> 8 ) & 0xFF ;
float area_tot = (x2-x1) * (y2-y1) ;
float r_tot = 0.0f ;
float g_tot = 0.0f ;
float b_tot = 0.0f ;
float rgb_area = 0.0f ;
for ( int i = (int)floor(x1) ; i <= (int)ceil(x2) ; i++ )
for ( int j = (int)floor(y1) ; j <= (int)ceil(y2) ; j++ )
if ( i < 0 || i >= width ||
j < 0 || j >= height ||
getPixel( i, j ) == keyColour )
continue ;
float xa = ( x1 > (float) i ) ? x1 : (float) i ;
float xb = ( x2 < (float)(i+1)) ? x2 : (float) (i+1) ;
float ya = ( y1 > (float) j ) ? y1 : (float) j ;
float yb = ( y2 < (float)(j+1)) ? y2 : (float) (j+1) ;
if ( xb-xa <= 0.0f || yb-ya <= 0.0f )
continue ;
float area = (xb-xa) * (yb-ya) ;
rgb_area += area ;
r_tot += getPixelRed ( i, j ) * area ;
g_tot += getPixelGreen ( i, j ) * area ;
b_tot += getPixelBlue ( i, j ) * area ;
if ( rgb_area <= 0.0f )
return 0x00000000 ;
r_tot /= rgb_area ;
g_tot /= rgb_area ;
b_tot /= rgb_area ;
float a_tot = rgb_area * 255.0f / area_tot ;
if ( r_tot > 255.0f ) r_tot = 255.0f ;
if ( g_tot > 255.0f ) g_tot = 255.0f ;
if ( b_tot > 255.0f ) b_tot = 255.0f ;
if ( a_tot > 255.0f ) a_tot = 255.0f ;
if ( r_tot <= 0.0f ) r_tot = 0.0f ;
if ( g_tot <= 0.0f ) g_tot = 0.0f ;
if ( b_tot <= 0.0f ) b_tot = 0.0f ;
if ( a_tot <= 0.0f ) a_tot = 0.0f ;
return ( (unsigned int) r_tot << 24 ) +
( (unsigned int) g_tot << 16 ) +
( (unsigned int) b_tot << 8 ) +
( (unsigned int) a_tot << 0 ) ;
void ASAtoSAS ( float angA, float lenB, float angC,
float *lenA, float *angB, float *lenC )
/* Find the missing angle */
float bb = 180.0f - (angA + angC) ;
if ( angB ) *angB = bb ;
/* Convert everything to radians */
angA *= DEGREES_TO_RADIANS ;
angC *= DEGREES_TO_RADIANS ;
bb *= DEGREES_TO_RADIANS ;
/* Use Sine Rule */
float sinB = sin ( bb ) ;
if ( sinB == 0.0f )
if ( lenA ) *lenA = lenB / 2.0f ; /* One valid interpretation */
if ( lenC ) *lenC = lenB / 2.0f ;
else
if ( lenA ) *lenA = lenB * sin(angA) / sinB ;
if ( lenC ) *lenC = lenB * sin(angC) / sinB ;
float *processRawFrame ( char *fname, int f, int num_frames, int *num_points )
JPEG *jpg = new JPEG ;
jpg -> load ( fname ) ;
int np = jpg->getHeight() / POINT_SKIP ;
*num_points = np ;
float *res = new float [ 3 * np ] ;
float frame_angle = ((float) f) * (360.0f / (float) num_frames) ;
for ( int j = 0 ; j < np ; j++ )
/* Find the brightest pixel */
float max = 0.0f ;
int maxpos = -1 ;
for ( int i = 0 ; i < jpg -> getWidth () ; i++ )
unsigned int px = jpg -> getPixel ( i, j*POINT_SKIP ) ;
float brightness = ((float)(( px >> 24 ) & 0xFF)) / 255.0f +
((float)(( px >> 16 ) & 0xFF)) / 255.0f +
((float)(( px >> 8 ) & 0xFF)) / 255.0f ;
if ( brightness > max )
max = brightness ;
maxpos = i ;
float radius ;
float camera_angle = CAMERA_HFOV *
(0.5f - (float)maxpos / (float)jpg -> getWidth ()) ;
ASAtoSAS ( camera_angle, CAMERA_DISTANCE, LASER_OFFSET,
& radius, NULL, NULL ) ;
float x = radius * sin ( frame_angle * DEGREES_TO_RADIANS ) ;
float y = radius * cos ( frame_angle * DEGREES_TO_RADIANS ) ;
float z = atan ( (CAMERA_VFOV * DEGREES_TO_RADIANS / 2.0f) ) *
2.0f * CAMERA_DISTANCE * (float) j / (float) np ;
// if ( max < 1.50 )
// x = y = 0.0f ;
res [ 3 * j + 0 ] = x ;
res [ 3 * j + 1 ] = y ;
res [ 3 * j + 2 ] = z ;
delete jpg ;
return res ;
void outputFrames ( int num_points, int num_frames, float **vertices )
int num_outframes = num_frames / HORIZ_AVG ;
int num_outpoints = num_points / VERT_AVG ;
printf ( "AC3Db\n" ) ;
printf ( "MATERIAL \"ac3dmat1\" rgb 1 1 1 amb 0.2 0.2 0.2 "
"emis 0 0 0 spec 0.5 0.5 0.5 shi 10 trans 0\n" ) ;
printf ( "OBJECT world\n" ) ;
printf ( "kids 1\n" ) ;
printf ( "OBJECT poly\n" ) ;
printf ( "name \"scan3d\"\n" ) ;
printf ( "loc 0.0 0.0 0.0\n" ) ;
printf ( "numvert %d\n", num_outpoints*num_outframes ) ;
for ( int f = 0 ; f < num_outframes ; f++ )
for ( int i = 0 ; i < num_outpoints ; i++ )
float avg [ 3 ] = { 0.0f, 0.0f, 0.0f } ;
for ( int ff = 0 ; ff < HORIZ_AVG ; ff++ )
for ( int ii = 0 ; ii < VERT_AVG ; ii++ )
avg [ 0 ] += vertices[f*HORIZ_AVG+ff][(i*VERT_AVG+ii)*3+0] ;
avg [ 1 ] += vertices[f*HORIZ_AVG+ff][(i*VERT_AVG+ii)*3+1] ;
avg [ 2 ] += vertices[f*HORIZ_AVG+ff][(i*VERT_AVG+ii)*3+2] ;
avg [ 0 ] /= (float)( HORIZ_AVG*VERT_AVG ) ;
avg [ 1 ] /= (float)( HORIZ_AVG*VERT_AVG ) ;
avg [ 2 ] /= (float)( HORIZ_AVG*VERT_AVG ) ;
printf ( "%f %f %f\n", avg [ 0 ], avg [ 1 ], avg [ 2 ] ) ;
printf ( "numsurf %d\n", num_outframes * (num_outpoints-1) * 2 ) ;
int ff = (f==num_outframes-1) ? 0 : f+1 ;
for ( int i = 0 ; i < num_outpoints-1 ; i++ )
int ii = i+1 ;
printf ( "SURF 0x10\n" ) ;
printf ( "mat 0\n" ) ;
printf ( "refs 3\n" ) ;
printf ( "%d %f %f\n", ff * num_outpoints + ii,
(float) ff / (float) num_outframes,
(float) ii / (float) num_outpoints ) ;
printf ( "%d %f %f\n", ff * num_outpoints + i,
(float) i / (float) num_outpoints ) ;
printf ( "%d %f %f\n", f * num_outpoints + i,
(float) f / (float) num_outframes,
printf ( "%d %f %f\n", f * num_outpoints + ii,
printf ( "kids 0\n" ) ;
int main ( int argc, char **argv )
float **vertices ;
int num_frames = 0 ;
for ( int i = 0 ; true ; i++ )
FILE *tmp ;
char fname [ 100 ] ;
sprintf ( fname, "%08d.jpg", i*FRAME_SKIP ) ;
fprintf ( stderr, "Checking %s\r", fname ) ;
if ( (tmp = fopen ( fname, "r" )) == NULL )
break ;
fclose ( tmp ) ;
num_frames = i+1 ;
fprintf ( stderr, "\nProcessing %d frames...\n", num_frames ) ;
vertices = new float * [ num_frames ] ;
int npoints = -1 ;
for ( int i = 0 ; i < num_frames ; i++ )
int np ;
fprintf ( stderr, "Processing frame %d/%d '%s'\r",
i, num_frames, fname ) ;
vertices [ i ] = processRawFrame ( fname, i, num_frames, &np ) ;
assert ( npoints == -1 || np == npoints ) ;
npoints = np ;
fprintf ( stderr, "\nOutputting...\n", num_frames ) ;
outputFrames ( npoints, num_frames, vertices ) ;
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <assert.h>
#include <string.h>
extern "C"
#include <jerror.h>
#include <math.h>
class Image
protected:
int width ;
int height ;
public:
width = w ;
height = h ;
Image ()
buffer = NULL ;
virtual ~Image () ;
float x2, float y2,
return ;
else
public:
Image::~Image ()
delete buffer ;
FILE *fd ;
int row_stride ;
return 0 ;
return 0 ;
delete buffer ;
fclose ( fd ) ;
return 1 ;
float x2, float y2,
return 0x00000000 ;
continue ;
continue ;
rgb_area += area ;
return 0x00000000 ;
r_tot /= rgb_area ;
g_tot /= rgb_area ;
b_tot /= rgb_area ;
/* Use Sine Rule */
if ( sinB == 0.0f )
else
*num_points = np ;
float max = 0.0f ;
int maxpos = -1 ;
max = brightness ;
maxpos = i ;
float radius ;
// x = y = 0.0f ;
delete jpg ;
return res ;
int ii = i+1 ;
float **vertices ;
FILE *tmp ;
break ;
fclose ( tmp ) ;
num_frames = i+1 ;
int npoints = -1 ;
int np ;
npoints = np ;
Ostatnio zmieniony 21 gru 2006, 18:36 przez pltmaxnc, łącznie zmieniany 1 raz.
gaspar
Poproś Marcomp o kompilacje, ja nie mam odpowiednich bibliotek i jednak nie bardzo mi to się chce skompilować (na serwerze nie wszystko było potrzebne)
Błędy:
/tmp/ccrD8cO8.o(.text+0x19): In function `Image::~Image [not-in-charge]()':
: undefined reference to `operator delete(void*)'
/tmp/ccrD8cO8.o(.text+0x33): In function `Image::~Image [not-in-charge]()':
/tmp/ccrD8cO8.o(.text+0x55): In function `Image::~Image [in-charge]()':
/tmp/ccrD8cO8.o(.text+0x6f): In function `Image::~Image [in-charge]()':
/tmp/ccrD8cO8.o(.text+0x91): In function `Image::~Image [in-charge deleting]()':
/tmp/ccrD8cO8.o(.text+0xab): more undefined references to `operator delete(void*)' follow
/tmp/ccrD8cO8.o(.text+0x123): In function `JPEG::load(char*)':
: undefined reference to `jpeg_std_error'
/tmp/ccrD8cO8.o(.text+0x142): In function `JPEG::load(char*)':
: undefined reference to `jpeg_CreateDecompress'
/tmp/ccrD8cO8.o(.text+0x15a): In function `JPEG::load(char*)':
: undefined reference to `jpeg_stdio_src'
/tmp/ccrD8cO8.o(.text+0x16e): In function `JPEG::load(char*)':
: undefined reference to `jpeg_read_header'
/tmp/ccrD8cO8.o(.text+0x180): In function `JPEG::load(char*)':
: undefined reference to `jpeg_start_decompress'
/tmp/ccrD8cO8.o(.text+0x1fd): In function `JPEG::load(char*)':
/tmp/ccrD8cO8.o(.text+0x250): In function `JPEG::load(char*)':
: undefined reference to `operator new[](unsigned)'
/tmp/ccrD8cO8.o(.text+0x289): In function `JPEG::load(char*)':
: undefined reference to `jpeg_read_scanlines'
/tmp/ccrD8cO8.o(.text+0x2ca): In function `JPEG::load(char*)':
: undefined reference to `jpeg_finish_decompress'
/tmp/ccrD8cO8.o(.text+0x2dc): In function `JPEG::load(char*)':
: undefined reference to `jpeg_destroy_decompress'
/tmp/ccrD8cO8.o(.text+0x3a9): In function `Image::getPixelArea(float, float, float, float, unsigned)':
: undefined reference to `floor'
/tmp/ccrD8cO8.o(.text+0x3d4): In function `Image::getPixelArea(float, float, float, float, unsigned)':
: undefined reference to `ceil'
/tmp/ccrD8cO8.o(.text+0x40c): In function `Image::getPixelArea(float, float, float, float, unsigned)':
/tmp/ccrD8cO8.o(.text+0x437): In function `Image::getPixelArea(float, float, float, float, unsigned)':
/tmp/ccrD8cO8.o(.text+0x828): In function `ASAtoSAS(float, float, float, float*, float*, float*)':
: undefined reference to `sin'
/tmp/ccrD8cO8.o(.text+0x892): In function `ASAtoSAS(float, float, float, float*, float*, float*)':
/tmp/ccrD8cO8.o(.text+0x8c2): In function `ASAtoSAS(float, float, float, float*, float*, float*)':
/tmp/ccrD8cO8.o(.text+0x8e6): In function `processRawFrame(char*, int, int, int*)':
: undefined reference to `operator new(unsigned)'
/tmp/ccrD8cO8.o(.text+0x920): In function `processRawFrame(char*, int, int, int*)':
/tmp/ccrD8cO8.o(.text+0x97a): In function `processRawFrame(char*, int, int, int*)':
/tmp/ccrD8cO8.o(.text+0xaf5): In function `processRawFrame(char*, int, int, int*)':
/tmp/ccrD8cO8.o(.text+0xb1e): In function `processRawFrame(char*, int, int, int*)':
: undefined reference to `cos'
/tmp/ccrD8cO8.o(.text+0xb3b): In function `processRawFrame(char*, int, int, int*)':
: undefined reference to `atan'
/tmp/ccrD8cO8.o(.text+0x113a): In function `main':
/tmp/ccrD8cO8.o(.gnu.linkonce.r._ZTV5Image+0x10): undefined reference to `__cxa_pure_virtual'
/tmp/ccrD8cO8.o(.gnu.linkonce.t._ZN4JPEGD0Ev+0x30): In function `JPEG::~JPEG [in-charge deleting]()':
/tmp/ccrD8cO8.o(.gnu.linkonce.t._ZN4JPEGD1Ev+0x30): In function `JPEG::~JPEG [in-charge]()':
/tmp/ccrD8cO8.o(.gnu.linkonce.r._ZTI5Image+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
/tmp/ccrD8cO8.o(.gnu.linkonce.r._ZTI4JPEG+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/tmp/ccrD8cO8.o(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
collect2: ld returned 1 exit status
Błędy:
x
- Posty w temacie: 9
To jest program C++, potrzebuje tylko biblioteki libjpeg. Polecenie kompilacji:
(zfcnc to oczywiście nazwa pod jaką zapisałem skopiowany stąd kod)
U mnie kompiluje się bez żadnych problemów. Tylko wytłumaczcie mi: co ten program robi? Podawałem mu nawet dwa pliki które nazwałem 00000000.jpg i 00000001.jpg, cuś tam wyświetla (w większości napisy "na sztywno" wpisane do printf()), i to wszystko, żadnego fizycznego efektu w postaci pliku wynikowego.
Kod: Zaznacz cały
g++ -o zfcnc zfcnc.cpp -ljpegU mnie kompiluje się bez żadnych problemów. Tylko wytłumaczcie mi: co ten program robi? Podawałem mu nawet dwa pliki które nazwałem 00000000.jpg i 00000001.jpg, cuś tam wyświetla (w większości napisy "na sztywno" wpisane do printf()), i to wszystko, żadnego fizycznego efektu w postaci pliku wynikowego.
gaspar
no po zainstalowaniu libjpeg, skompilowałem.
Processing 1 frames...
Processing frame 0/1 '00000000.jpg'
Outputting...
AC3Db
MATERIAL "ac3dmat1" rgb 1 1 1 amb 0.2 0.2 0.2 emis 0 0 0 spec 0.5 0.5 0.5 shi 10 trans 0
OBJECT world
kids 1
OBJECT poly
name "scan3d"
loc 0.0 0.0 0.0
numvert 0
numsurf 0
kids 0
faktycznie nie wiele to wyjaśnia
Outputting...
AC3Db
OBJECT world
kids 1
OBJECT poly
name "scan3d"
loc 0.0 0.0 0.0
numvert 0
numsurf 0
kids 0
x
Potem się okaże, że to rootkit.
A tak na serio, to wygląda na wersję 0.0.1-pre-alpha, prawie wszystko wpisane "na sztywno", 500 linii kodu, jakaś użyteczna funkcjonalność pojawi się pewnie kilkanaście wersji później. Ale w wolnej chwili przejrzę ten kod.
Rzeczywiście, to już taki odruch żeby sprawdzić czy się skompiluje.a linuksiarze juz za kompilacje się biorą ...
yoyer
Zakladam, ze jest to program wykorzystywany do zczytywania geometrii obiektu z pliku graficznego (tzn jest to jakis modul wiekszego projektu) przy skanowaniu za pomoca kamery (aparatu) i lasera - swiatlo lasera w postaci "prazka" rzutowane jest na obiekt... co bede pduzo pisal... wiecie o co chodzi...
dla przykladu:
npoints - to moze byc zmienna do liczenia "nodow"; etc
[ Dodano: 2006-12-21, 22:24 ]
PS. Ktos pewnie na "wyzszej uczelni" dostal prace przejsciowa i sie teraz produkuje
dla przykladu:
Hooah!
markcomp77
to jest "The Scan_Extract Tool" ze strony:
http://www.sjbaker.org/projects/scanner/
The program I used to extract 3D images is included here and the 'Makefile' for it is here.
