czujnik długość narzędzia, freza
: 28 lut 2013, 11:12
Znalazłem na forum taki oto skrypt ale po jego zastosowaniu nie uwzględnia grubości czujnika "płytki" , jak tą wielkość wprowadzić by poprawnie skrypt robił co powinien ?
PlateThickness = GetUserDRO(1151) 'Z-plate thickness DRO
If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Code "G4 P5" ' this delay gives me time to get from computer to hold probe in place
Code "G31Z-30 F100" 'probing move, can set the feed rate here as well as how far to move
While IsMoving() 'wait while it happens
Wend
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
While IsMoving ()
Wend
Call SetDro (2, PlateThickness) 'set the Z axis DRO to whatever is set as plate thickness
Code "G4 P0.25" 'Pause for Dro to update.
Code "G0 Z25.4" 'put the Z retract height you want here
Code "(Oś Z jest wyzerowana)" 'puts this message in the status bar - Z axis is now zeroed
Else
Code "(Z-Plate is grounded, Sprawdź połączenie i spróbój ponownie)" 'this goes in the status bar if aplicable
Exit Sub
End If
Wend
While IsMoving ()
Wend
Else
Exit Sub
End If
