Witam, czy jest ktoś chętny do kupienia licencji do Mach3 na spółkę ?
Max. 4 osoby
Mach3
roman_ows
- Stały bywalec (min. 70)
Koszt Mach-a to około 750 zł. Trzeba w swoim banku zlecić przelew i zapłacić w przeliczeniu na $ za:
-koszty "naszego" banku
-cenę programu
-koszty "ichniejszego" banku.
Produkt otrzymuje się po 24 godz.
Hallo:
Thank you for registering your copy of Mach2 or Mach3. Enclosed is your license
file. To load it, simply copy it into your Mach2/3 program folder. You may check that it
is loaded by using the Help/About selection on the menu when the program is reset and
running.
A PDF file of the Mach2/3's manual's are available on the Main Web site,
and further information is available on the posts of the Yahoo Mach1Mach2CNC
web group, also available from the main web page's download section. You are highly
encouraged to download this book, it has earned high praise from all that use it.
MachX comes in three forms on the download page.
Mach2:
Version 4.xx , This version is the first version of Mach2 and runs well on some slower computers.
Version 6.xx , This version is the latest full release and incorporates many enhancements. Current
Documentation levels refer to this version of the program.
Mach3RC 1.x This version is a release Candidate. IT is undergoing final testing and revisions
prior to full release. It is being used by several hundred people and the results
are great so far. It may be used with caution, and dry runs are encouraged while
the final work is begin done..
It is recommended to use the 6.xx version as no serious bugs are known to exist for most users.
Mach2 is a co-development using the knowledge and interests of the Yahoo group Mach1Mach2CNC,
it is highly recommended that you join this group, it has over 3000 members who are happy to assist in
application questions on the many uses Mach2 is currently in operation for. It is also the forum used to
request new features and allows the priority of such features to be judged by group response.
Welcome to Mach2 and its group of users.
If I can help in any way, please let me know,
Thanks again, Happy Cutting,
email zawiera plik do wczytania do Macha.
-cenę programu
Hallo:
running.
Mach2:
sq9gin
Mach3
Witam, koszt macha to 513zł płacilem Kartą kredytową.
Krzysztof
Krzysztof
roman_ows pisze:Koszt Mach-a to około 750 zł. Trzeba w swoim banku zlecić przelew i zapłacić w przeliczeniu na $ za:
-cenę programu
Hallo:
running.
Mach2:
