The right grinding mill and for your completely needs
binqcrusher
Post napisał: binqcrusher » 21 wrz 2010, 09:22
As a leading grinding machine manufacturers, WE offers lots of grinding mills, such as ball mill, raymond mill, coal mill, trapezium grinding mill, vertical mill, etc. WE Grinding Machine can be used for wet and dry processes in open and closed circuits for Bulk Materials, Minerals, etc...
Our service and support is the best, and our grinding mill is the best too. Before, during and after the sale, you can count on the experts to provide the best service and support in the world - all over the world. You can count on us to help you make sure it is the right grinding mill for your precise needs.
Grinding Plant
Grinding Plant is made of jaw crusher, bucket elevator, electro vibrating feeder, main unit, optional equipment, blower, centrally electric control system, etc. According to customer’s specific requirement, we can choose high pressure suspension grinding mill or MTM medium speed trapezium mill.
Ball mill is an efficient tool for fine powder grinding. The Ball Mill is used to grind many kinds of mine and other materials, or to select the mine. Ball mill is widely used in building material, chemical industry, etc. There are two ways of grinding: the dry way and the wet way. It can be divided into tabular type and flowing type according to different expelling mine.
We MTM Series Trapezium Mill is the world leading grinding mill. It is designed by our own engineers and technical workers based on many years’ industrial mill research and it adopted world leading powder processing technology. Our MTM mill absorbs many advantages from various mills all over the world, such as trapeziums working surface, flexible connection, roll linked pressure boost, etc. It has overcome the traditional mills defect completely in aspects of application, capacity, fineness, energy consumption, service life, etc.
It is the ideal substitute of the traditional mill like Raymond mill, high pressure suspension mill, ball mill, etc. Nowadays, our MTM mills have been widely used in metallurgy industry, electric power industrial, chemical, building, steel industry, coal industry, etc. And it has brought large economic benefits to our customers and the society.
LM series vertical mill is the newest grinding machine of vertical mill professional manufacturer-WE, which is designed specially to solve the problems of low capacity and high consumption of traditional industry mills. With a decade of years’ research of mills, our vertical mill is designed and manufactured based on advanced design idea, and integrates the advanced international technology and years of mill-producing experience. LM series vertical mill adopts reliable structure and reasonable process flow; it is ideal equipment that integrated with drying, milling, classifier, and elevator. Especially, this vertical mill can fully meets the requirement of clients in the high production of powder and its main technical and economy indicator reaches the international level.
c0n0c
Post napisał: c0n0c » 21 wrz 2010, 11:33
Is it the proper website of your company?
http://www.mill-in-china.com/
:shock:
