rozbieranie wrzecniona i wyjęcie chwytaka
: 16 wrz 2017, 12:31
Czy ktoś wykonywał taką operację lub zna serwis który rozbierał to ?
Może jest ktoś w posiadaniu schematu tej części lub całej okolicy ?
Serwis manual opisuje czynność ale niestety nie mam obrazków.
Drgs. 0612629090000, 0612629100000, 0612629110000, 0612629120000.
Drawbar Removal
1. Remove drawbar cylinder assembly as previously described and
remove Cylinder Plate. See “Drive Belt Removal”.
2. If fitted, remove coolant rotary coupling.
3. For machines with TSC remove coolant deflector ring and coolant tray.
4. Slacken off grub screw and unscrew spring collar (12)(8).
5. Remove disc springs (11)(7) together with spring plate (10)(6).
Note: The disc springs are a critical part and as such must be replaced as
a complete pack. Individual springs MUST NOT be replaced. It
is important that the springs are kept stacked as shown on Drg.
61262420. This item MUST be purchased through Cincinnati Milacron
Spares/Service Departments.
6. With the drawbar supported, use spanner (Fig. 43) to unscrew push rod
(13)(9) from drawbar (14)(10).The drawbar and steel balls (18)(14) are
extracted from the spindle nose.
Note: The drawbar is a Critical Part. If a replacement is required, it must
be obtained form Cincinnati Machine.
Drawbar Removal
